查看: 1930|回复: 0
[NI软件产品] NI OPC Servers 2010 Win32/64Eng NI OPC服务器2010
    13 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2022-12-1 10:31:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    OPC Servers
    OPC服务器提供单一、一致的接口,可通过OPC标准与多个设备通信。
    OPC服务器是LabVIEW的一款附加软件,可将专用工业协议转换为开放式OPC Classic和OPC统一架构(UA)协议。通过该转换,LabVIEW应用程序就可以通过LabVIEW OPC UA工具包附带的OPC UA客户端,与许多不同的可编程逻辑控制器(PLC)和第三方设备进行通信,因而用户只需在一个平台上即可对工业系统进行高性能测量和控制。
    NI OPC Servers 2010
    发布日期:2010/6/20
    包含的版本:2010完整版
    受支持的操作系统
    Windows Server 2008 (32-bit and 64-bit)
    Windows Vista Business/Ultimate (32-bit and 64-bit)
    Windows Server 2003
    Windows XP
    Windows 2000 Server
    Windows 2000 Service Pack 2 or higher
    Windows NT 4.0 Service Pack 6
    文件大小: 79194720 字节 (75.53 MB)
    修改日期: 2022-03-25 06:09
    MD5: e5cde4269b3b111192fbbbfc8dfa4086(重复一致)
    SHA1: 657442a49c5082e66d8b5fc299fdf61553d296c7
    SHA256: 514b773765e3d91de56a814c585cbf2522e386601b4e0418b90f2cbb1f7ea6df
    CRC32: f5fb4930
    请注册登录视觉论坛账号,购买附件查看下载地址
    OPC Server2010.txt (506 Bytes, 下载次数: 1, 售价: 10 圆)
    National Instruments OPC Servers 2010 Readme
    Version 10.0.0
    June 2010
    This file contains important information about the National Instruments OPC Servers, including installing and activating NI OPC Servers.
    Licensing and Activation
    NI OPC Servers provides a single consistent interface to communicate with multiple devices, saving you from learning new communication protocols and spending time understanding new applications. The combination of NI OPC Servers and other NI products, such as LabVIEW, the LabVIEW Datalogging and Supervisory Control (DSC) Module, Lookout, Measurement Studio, and LabWindows™/CVI™, provides a single platform for delivering high-performance measurements and control to new and existing industrial systems.
    You can use NI OPC Servers with the following software applications:
    • LabVIEW 8.6 or later, Full or Professional Development System
    • LabVIEW DSC Module 8.5 or later
    • Lookout 6.2 or later
    • Measurement Studio 8.6 or later
    • LabWindows/CVI 9.0
    By default, NI OPC Servers is installed with the DSC Module and Lookout. NI OPC Servers connects through the OPC client in the DSC Module to enable you to develop a full-fledged Human Machine Interface (HMI) and Supervisory Control and Data Acquisition (SCADA) system with programmable logic controllers (PLCs), programmable automation controllers (PACs), and smart sensors. You can use NI OPC Servers with Measurement Studio, LabWindows/CVI, and LabVIEW by using DataSocket as an OPC client.
    NI OPC Servers has both software and hardware minimum system requirements. This application supports the following Microsoft Windows operating systems:
    • Windows Server 2008 (32-bit and 64-bit)
    • Windows Vista Business/Ultimate (32-bit and 64-bit)
    • Windows Server 2003
    • Windows XP
    • Windows 2000 Server
    • Windows 2000 Service Pack 2 or higher
    • Windows NT 4.0 Service Pack 6
    Note  Because Windows 2003 Server and Windows XP have continuous updates, National Instruments recommends that you run the Windows update feature to get the latest software.
    NI OPC Servers requires the following minimum hardware requirements:
    • Intel Pentium III 400 MHz or equivalent processor that supports Windows
    • 512 MB of RAM
    • 40 MB available disk space
    • Available serial port or Ethernet card
    Complete the following steps to install NI OPC Servers.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert the NI OPC Servers 2010 installation CD and follow the instructions that appear on the screen.
    • Activate NI OPC Servers using the NI License Manager.
    NI OPC Servers installed with Lookout is licensed. NI OPC Servers installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using NI OPC Servers after the evaluation period expires.
    Use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate NI products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the NI License Manager, for information about activating NI products.
    Refer to the National Instruments Web site at ni.com/opc or the NI OPC Servers Help, available by selecting Start»All Programs»National Instruments»NI OPC Servers»NI OPC Servers Help, for more information about NI OPC Servers.
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-1 13:52
