查看: 1390|回复: 0
[NI驱动程序] NI-FieldPoint 14.5.0 Win32/64Eng NI Compact FieldPoint可编程自动化控制器驱动程序14.5.0
    昨天 11:15
  • 签到天数: 3597 天
     楼主| 发表于 2022-11-30 14:29:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-FieldPoint
    NI-FieldPoint为Compact FieldPoint可编程自动化控制器提供LabVIEW支持。
    NI-FieldPoint是一款驱动软件,可通过LabVIEW和LabVIEW Real-Time模块创建Compact FieldPoint应用程序和实时任务。LabVIEW可搭配NI-FieldPoint使用,为Compact FieldPoint库中的本地或分布式I/O自动创建FieldPoint I/O标签和读取/写入函数。您还可以使用LabVIEW中的共享变量,将I/O数据自动发布至网络。
    发布日期:2015/2/14
    包含的版本:14.5.0完整版
    受支持的操作系统
    Windows 8 (32-bit and 64-bit)
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP SP3 (32-bit)
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    文件大小: 963715360 字节 (919.07 MB)
    修改日期: 2022-03-25 22:42
    MD5: bb8d9109160797b4f41ac2483f305a21
    SHA1: 100f9549e867a17131536e5e6403da470c760b89
    SHA256: 614fc0a8db5e325f0d1c4785ce9dc448f22dea2da3a0ce6c4ddd30c57421df5e
    CRC32: 0c9d41fe
    请注册登录视觉论坛账号,购买附件查看下载地址
    FieldPoint14.5.0.txt (480 Bytes, 下载次数: 0, 售价: 10 元)
    National Instruments FieldPoint™ 14.5 Readme
    February 2015
    This document contains important information about using the FieldPoint software, including system requirements, installation instructions, new features and changes, and known issues.
    New Features and Changes
    Driver Version Naming Changes
    Upgrading FieldPoint RT Controllers to LabVIEW Real-Time Module 2011 SP1, 2012 SP1, 2013 SP1 and 2014 SP1
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    You can install and run this version of the FieldPoint software on the following operating systems:
    • Windows 8.0/7/Vista (32-bit and 64-bit)*
    • Windows XP SP3 (32-bit)
    • Windows Server 2008 R2 (64-bit)*
    Note  The FieldPoint installer does not support Windows 2000/NT/Me/98/95 or Windows XP x64. Operating system versions marked with an asterisk (*) run within the 32-bit emulation layer, Windows on Windows (WOW64).
    Caution  If you upgrade your system from a previous version of Microsoft Windows to Microsoft Windows Vista, you must uninstall all National Instruments software prior to performing the upgrade. After the upgrade is complete, you can reinstall your National Instruments software.
    Installation InstructionsSupported Software
    The following table lists major versions of LabVIEW that each version of FieldPoint supports.
    FieldPoint LabVIEW Versions
    6.07.1/8.0/8.2/8.5
    6.0.17.1/8.0/8.2/8.5
    6.0.27.1/8.2/8.5/8.6
    6.0.37.1/8.2/8.5/8.6
    6.0.47.1/8.2/8.5/8.6
    6.0.58.2/8.5/8.6/2009
    6.0.68.2/8.5/8.6/2009
    6.0.78.5/8.6/2009/2010
    6.0.88.5/8.6/2009/2010
    6.0.98.6/2009/2010/2011
    6.0.108.6/2009/2010/2011
    6.0.112009/2010/2011/2012
    6.0.122009/2010/2011/2012
    6.12010/2011/2012/2013
    13.12010/2011/2012/2013
    14.52011/2012/2013/2014
    Note  The FieldPoint software will only have two more releases after the 14.5 release. The following table lists the supported LabVIEW versions:
    15.02012/2013/2014/2015
    15.52012/2013/2014/2015/2015 SP1
    FieldPoint IAK Configuration File Included in Application
    In FieldPoint 6.0.2 or later, you can include FieldPoint configuration files in the data directory of a LabVIEW application. Select Include hardware configuration files on the Advanced tab in the Application Properties dialog box to include the files. The built executable uses the IAK configuration file in the data directory instead of the IAK file registered with the system.
    Which IAK file LabVIEW uses for a VI depends on the VI itself and the VI location. The following table shows the IAK file to use in each case.
    VI NameVI in a LabVIEW ProjectVI not in a LabVIEW ProjectVI in an EXE File
    Polymorphic FP Read, FP Write and FP Write/ReadIAK file associated with the ProjectMost recently opened IAK fileIAK file distributed with EXE
    FP Get ConfigurationIAK file associated with the LabVIEW ProjectMost recently opened IAK fileIAK file distributed with EXE
    Legacy VIs (FP Open, FP Create Tag, FP Close)Most recently opened IAK fileMost recently opened IAK fileMost recently opened IAK file
    How to Delete Disconnected Remote Systems Using Measurement & Automation Explorer (MAX) 4.5 or Later
    To delete a disconnected remote system, right-click Remote Systems in MAX and select Delete Disconnected Systems. This operation do not delete offline FieldPoint systems with saved configurations.
    Creating a FieldPoint Distribution Kit
    If you are deploying a FieldPoint executable built with LabVIEW 8.0 or later, you can include FieldPoint 5.0 or later in the installer. Ensure that you copy the .iak file associated with the project to your application.
    To create a FieldPoint executable using LabWindows/CVI, include FPCVIMgr.DLL in the distribution kit. By default this file is installed in the \WINNT\system32 folder for Windows 7/VISTA/XP.
    You must also include .iak file created in MAX with the FieldPoint distribution kit.
    FieldPoint OPC Server
    The latest FieldPoint OPC server supports the OPC Interface Specifications 2.04.
    Note The values returned by tags of type VT_BOOL have been changed from +1 to -1 (0xFFFF - VARIANT_TRUE) to comply with the OPC specifications. All discrete input and output items, except the "All" item, for FieldPoint channels are defined to be of type VT_BOOL. If you have an OPC application that checks for data values equal to +1 for discrete items, change the application to check for -1 or for a non-zero value (recommended).
    • Added support for LabVIEW 2014 SP1
    FieldPoint versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, FieldPoint 14.5 is the version released with LabVIEW 2014 SP1. The last version released under the old numbering scheme is FieldPoint 6.1. The first version released under the new numbering scheme is FieldPoint 13.1.
    FieldPoint 14.5 has the following known issues:
    cFP-180x User LED Is Inaccessible through Serial Port
    The cFP-180x User LED channel is accessible only through an Ethernet connection. You cannot read or control the User LED through a serial connection.
    Remote I/O Error Reporting May Not Match Host VI Error Reporting
    A VI running on an RT controller may report errors for remote I/O. These errors do not match the errors reported by the same VI running on a host computer. For example, if an AI channel is out of range, the FP Read VI running on a host computer reports an Out of Range error. The same VI running on an RT controller returns channel-specific error A or B. Refer to the Attributes, Ranges, and Commands topic of the FieldPoint LabVIEW Interface Help for more information about channel status error messages. Doing remote I/O over serial may result in an Unknown Tag error (32812) if initialization with the module fails.
    The cFP-22xx controllers require LabVIEW Real-Time Module 8.5.1 or later. The cFP-21xx controllers require LabVIEW Real-Time Module 8.0 or later. National Instruments recommends LabVIEW Real-Time Module 7.1.1 for use on the [c]FP-20xx controllers. The [c]FP-20xx controllers do not support LabVIEW Real-Time Module 8.6 or later. Some features of LabVIEW Real-Time Module 8.x require more than 16 MB RAM, and the [c]FP-2000 and some other [c]FP-20xx controllers have only 16 MB RAM. Use the Remote Systems Install Software Wizard in MAX to install LabVIEW and FieldPoint software on FieldPoint controllers. For more information about memory and storage requirements of different LabVIEW versions, visit ni.com/info and enter the Info Code rdlrmf.
    For more information about which versions of the LabVIEW Real-Time Module and FieldPoint software components on the FieldPoint RT controller are compatible with each other, visit ni.com/info and enter the Info Code fpswlist.
    Using NI Launcher
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI FieldPoint Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments FieldPoint will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of FieldPoint that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 1997–2015 National Instruments. All rights reserved.
    GMT+8, 2025-7-19 02:16
