查看: 1989|回复: 0
[NI软件产品] NI TestStand 2020 Semiconductor Module 2021 Q4 x64Win10 64bitEng Teststand2020半导体模块扩展20.1.0
    7 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
     楼主| 发表于 2022-11-28 16:37:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    TestStand Semiconductor模块
    TestStand Semiconductor模块扩展了TestStand环境,可帮助您开发、调试、部署和维护半导体测试系统。
    TestStand Semiconductor模块通过引脚/通道匹配、分箱、分选器/探针台驱动程序、限制值导入/导出和多站点编程,扩展了TestStand环境,可帮助您开发和维护半导体系统,包括晶圆级和最终封装测试应用程序。
    发布日期:2021/11/4
    包含的版本:2021 Q4完整版,版本号20.1.0
    受支持的操作系统
    文件大小: 518836224 字节 (494.80 MB)
    修改日期: 2022-03-25 19:26
    MD5: e413b55185ff5d2bd797d494ec33570e
    SHA1: 79d427d2c2657c982e194d818e4ceca82fef74de
    SHA256: 56fa824b77f78cb970c597dd66587f3d41ca33824aa5780dfb2025b249c9d876
    CRC32: fe7d877e
    请注册登录视觉论坛账号,购买附件查看下载地址
    TestStand 2020 Semiconductor x64 2021Q4.txt (636 Bytes, 下载次数: 1, 售价: 10 圆)
    TestStand 2020 Semiconductor Module 2021 Q4 Readme
    October 2021
    This file contains installation instructions and compatibility information for TestStand 2020 Semiconductor Module 2021 Q4.
    • TestStand Semiconductor Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • TestStand 2020 Semiconductor Module 2021 Q4 Manual: New features, behavior changes, and other documentation for TestStand 2020 Semiconductor Module 2021 Q4
    • TestStand Semiconductor Module Manuals: New features, behavior changes, and other documentation for other TestStand Semiconductor Module releases
    TestStand Semiconductor Module adds the following features and functionality to TestStand for developing semiconductor test system software:
    • Multisite pin map file, TestStand Semiconductor Module Code Module APIs, and Semiconductor Multi Test step type for developing a semiconductor test program that runs on multiple test system hardware configurations with a variable number of test sites at a high parallel test efficiency
    • Support for binning devices under test (DUTs) based on test results
    • Support for exporting and importing test limits with text files
    • Data types, configurable callbacks, and dialog boxes for specifying test program settings, test station settings, and test lot information
    • Plug-in architecture for handler and prober communication using TestStand Semiconductor Module handler/prober drivers
    • Result processing plug-ins for generating report and data log files for the test lot, such as Standard Test Data Format (STDF) log files
    • Plug-in architecture for performing part average testing
    • Customizable operator interface for executing test programs, enabling or disabling test sites, displaying statistics, and configuring test lot information and test station settings
    • A set of step types with template code to perform common operations, such as setting up and closing instruments, powering up a DUT, or executing common tests
    • Customizable pin- and site-aware instrument panel VIs for debugging instruments during test program execution at a breakpoint
    New TestStand Users
    If you are a new TestStand user, NI recommends that you complete the tasks listed in the New Users section of the Guide to Documentation topic of the TestStand Help, which is located by default at \Doc\Help\TSHelp.chm. Select Help»TestStand Help to launch the TestStand Help.
    New TestStand Semiconductor Module Users
    To familiarize yourself with TestStand Semiconductor Module, review the topics in the Getting Started book in the TestStand Semiconductor Module Help, which is located by default at \Doc\Help\TSSemiconductor.chm. Select Help»TestStand Help and navigate to the TestStand Semiconductor Module book in the table of contents. The TestStand Semiconductor Module Help also contains information about all module features and functionality.
    Upgrade Users
    If you are upgrading from an earlier version of TestStand Semiconductor Module, refer to the TestStand 2020 Semiconductor Module 2021 Q4 New Features and the TestStand 2020 Semiconductor Module 2021 Q4 Compatibility and Known Issues topics in the TestStand Semiconductor Module Help for compatibility information and major feature changes. Select Help»TestStand Help and navigate to the TestStand Semiconductor Module book in the table of contents.
    Note  If you are upgrading from an earlier version of TestStand Semiconductor Module and use a custom operator interface based on the TestStand Semiconductor Module 2013 or earlier operator interface source code, you must re-implement the custom operator interface to use the latest TestStand Semiconductor Module operator interface source code, which includes improvements for performance, customization, and maintenance.
    TestStand 2020 Semiconductor Module 2021 Q4 has the following requirements:
    • Pentium 4/M or equivalent (Pentium G1 or higher recommended)
    • At least 300 MB of disk space. This value is in addition to the free hard disk space TestStand requires.
    • 1 GB RAM (2 GB or more recommended)
    TestStand 2020 Semiconductor Module 2021 Q4 supports the following operating systems:
    • Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    • TestStand does not support Guest user accounts on Windows.
    • TestStand Semiconductor Module no longer supports Windows 7/8.x, Windows Server 2012, or any 32-bit Windows operating system. TestStand 2020 Semiconductor Module 2021 Q4 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use TestStand 2020 Semiconductor Module 2021 Q4 to an unsupported OS. Additionally, after installing TestStand 2020 Semiconductor Module 2021 Q4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    TestStand 2020 Semiconductor Module 2021 Q4 supports the following application software versions, including service packs. If you are using Microsoft Visual Studio, refer to Microsoft Visual Studio Support.
    Requirement
    Recommended
    Minimum
    Comments
    TestStand (32- or 64-bit)
    2020
    2020
    Refer to the Recommended System Requirements section of the TestStand Version 2020 Release Notes for information about the recommended system requirements for TestStand.
    LabVIEW (32- or 64-bit)
    2020
    2017
    TestStand Semiconductor Module APIs are compiled for the LabVIEW 2017, 2018, 2019, and 2020 Run-Time Engines. The LabVIEW operator interface, Lot and Station Settings dialog boxes, and simulated handler are compiled for the LabVIEW 2019 Run-Time Engine.
    (Optional) NI-DAQmx 16.1.0f2 or later .NET API
    The TestStand Semiconductor Module NI-DAQmx .NET Code Module API requires the NI-DAQmx 16.1.0f2 or later .NET API.
    If you are using the TestStand Semiconductor Module .NET Class Library, .NET Framework 4.0 (minimum) is required. The TestStand Semiconductor Module .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    Download the TestStand Semiconductor Module installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate TestStand Semiconductor Module. For more information on TestStand Semiconductor Module activation, refer to Activating a Product.
    The TestStand Semiconductor Module installation program installs files for TestStand and LabVIEW, including the LabVIEW 2020 Run-Time Engine.
    • TestStand 2020 Semiconductor Module 2021 Q4 installs SeqEdit.exe.config in the \Bin directory and overwrites any existing file with the same filename in that directory. If you have created a custom SeqEdit.exe.config file, complete the following steps to preserve the custom file.
      • Move the existing SeqEdit.exe.config file to a location outside the directory.
      • Install TestStand 2020 Semiconductor Module 2021 Q4.
      • Compare the SeqEdit.exe.config file TestStand 2020 Semiconductor Module 2021 Q4 installed to the custom version of the file and merge the custom changes into the file TestStand 2020 Semiconductor Module 2021 Q4 installed.
    • If you are installing more than one NI product, visit ni.com/r/tsminstall for information about installation order. If you install or update LabVIEW after you install TestStand or TestStand Semiconductor Module, close and restart TestStand or run the TestStand Version Selector to properly configure LabVIEW, TestStand, and TestStand Semiconductor Module.
    • NI recommends that you exit all programs before running the TestStand Semiconductor Module installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than necessary to complete.
    • Visit ni.com/info and enter the Info Code rddrau to access the latest software drivers and updates.
    Refer to the TestStand Semiconductor Module book in the TestStand Help, accessible from the Help menu in the TestStand Sequence Editor, for information about TestStand 2020 Semiconductor Module 2021 Q4.
    TestStand Semiconductor Module includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can open an example sequence file from the subdirectories of the \Examples\NI_SemiconductorModule directory.
    TestStand Semiconductor Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2013-2021 National Instruments Corporation. All rights reserved.
    375326H-01
    GMT+8, 2026-2-5 17:40
