查看: 1920|回复: 0
[NI软件产品] NI TestStand 2020 Semiconductor Module Win32Eng Teststand2020半导体模块扩展20.0.0
    7 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
     楼主| 发表于 2022-11-28 16:32:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    TestStand Semiconductor模块
    TestStand Semiconductor模块扩展了TestStand环境,可帮助您开发、调试、部署和维护半导体测试系统。
    TestStand Semiconductor模块通过引脚/通道匹配、分箱、分选器/探针台驱动程序、限制值导入/导出和多站点编程,扩展了TestStand环境,可帮助您开发和维护半导体系统,包括晶圆级和最终封装测试应用程序。
    发布日期:2021/2/5
    包含的版本:2021完整版,版本号20.0.0
    受支持的操作系统
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    应用程序位数:32位
    文件大小: 508203008 字节 (484.66 MB)
    修改日期: 2022-03-25 19:26
    MD5: 480d9f3682f7dd8be63d69d47de506cb
    SHA1: e721ccdad3ee8de8d280ceda1992f1eb0352878a
    SHA256: 93aa5bd86d1ff1e903c139e92cd7b853f96240a115e88f7ec1a5042e3fd4b13d
    CRC32: 27c22cd0
    请注册登录视觉论坛账号,购买附件查看下载地址
    TestStand 2020 Semiconductor x86.txt (640 Bytes, 下载次数: 0, 售价: 10 圆)
    NI TestStand 2020 Semiconductor Module Readme
    January 2021
    This file contains important information about the NI TestStand 2020 Semiconductor Module™ (TSM), including system requirements and installation instructions. Refer to the What's New in the NI TestStand 2020 Semiconductor Module topic in the NI TestStand Semiconductor Module Help for information about new features and changes introduced since NI TestStand 2019 Semiconductor Module. Select Help»TestStand Help and navigate to the NI TestStand Semiconductor Module book in the table of contents of the TestStand Help to launch the NI TestStand Semiconductor Module Help. Refer to the TestStand Version 2020 Release Notes and the TestStand 2020 Readme for additional information about TestStand.
    NI TestStand Semiconductor Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    TSM adds the following features and functionality to TestStand for developing semiconductor test system software:
    • Multisite pin map file, TSM Code Module APIs, and Semiconductor Multi Test step type for developing a semiconductor test program that runs on multiple test system hardware configurations with a variable number of test sites at a high parallel test efficiency
    • Support for binning devices under test (DUTs) based on test results
    • Support for exporting and importing test limits with text files
    • Data types, configurable callbacks, and dialog boxes for specifying test program settings, test station settings, and test lot information
    • Plug-in architecture for handler and prober communication using TSM handler/prober drivers
    • Result processing plug-ins for generating report and data log files for the test lot, such as Standard Test Data Format (STDF) log files
    • Plug-in architecture for performing part average testing
    • Customizable operator interface for executing test programs, enabling or disabling test sites, displaying statistics, and configuring test lot information and test station settings
    • A set of step types with template code to perform common operations, such as setting up and closing instruments, powering up a DUT, or executing common tests
    • Customizable pin- and site-aware instrument panel VIs for debugging instruments during test program execution at a breakpoint
    New TestStand Users
    If you are a new TestStand user, NI recommends that you complete the tasks listed in the New Users section of the Guide to Documentation topic of the TestStand Help, which is located by default at \Doc\Help\TSHelp.chm. Select Help»TestStand Help to launch the TestStand Help.
    New TSM Users
    To familiarize yourself with TSM, review the topics in the Getting Started book in the NI TestStand Semiconductor Module Help, which is located by default at \Doc\Help\TSSemiconductor.chm. Select Help»TestStand Help and navigate to the NI TestStand Semiconductor Module book in the table of contents of the TestStand Help to launch the NI TestStand Semiconductor Module Help. The NI TestStand Semiconductor Module Help also contains information about all module features and functionality.
    Upgrade Users
    If you are upgrading from an earlier version of TSM, refer to the NI TestStand 2020 Semiconductor Module New Features and the NI TestStand 2020 Semiconductor Module Compatibility and Known Issues topics in the NI TestStand Semiconductor Module Help for compatibility information and major feature changes. Select Help»TestStand Help and navigate to the NI TestStand Semiconductor Module book in the table of contents of the TestStand Help to launch the NI TestStand Semiconductor Module Help.
    Note  If you are upgrading from an earlier version of TSM and use a custom operator interface based on the NI TestStand Semiconductor Module 2013 or earlier operator interface source code, you must re-implement the custom operator interface to use the latest TSM operator interface source code, which includes improvements for performance, customization, and maintenance.
    TSM has the following requirements:
    • Pentium 4/M or equivalent (Pentium G1 or higher recommended)
    • At least 40 MB of disk space. This value is in addition to the free hard disk space TestStand requires.
    • 1 GB RAM (2 GB or more recommended)
    TSM 2020 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates. Refer to the Migrating to TestStand 2012 and Windows 7/Vista section of the NI TestStand Version 2012 Release Notes for more information about using TestStand on Windows 7.
    Note  Refer to NI TestStand Semiconductor Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  TestStand does not support Guest user accounts on Windows. TestStand supports Administrator and Limited accounts on Windows 7.
    Note  In 2016 TSM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. TSM 2020 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use TSM 2020 to an unsupported OS. Additionally, after installing TSM 2020, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2020, refer to KB 79UC78LS, NI Installer Fails on Windows XP/Vista and Windows Server 2003.
    TSM 2020 supports the following application software versions, including service packs. If you are using Microsoft Visual Studio, refer to Microsoft Visual Studio Support.
    Requirement
    Recommended
    Minimum
    Comments
    TestStand (32- or 64-bit)
    2020
    2020
    Refer to the Recommended System Requirements section of the TestStand Version 2020 Release Notes for information about the recommended system requirements for TestStand.
    LabVIEW (32- or 64-bit)
    2020
    2017
    TSM APIs are compiled for the LabVIEW 2017, 2018, 2019, and 2020 Run-Time Engines. The LabVIEW operator interface, Lot and Station Settings dialog boxes, and simulated handler are compiled for the LabVIEW 2019 Run-Time Engine.
    (Optional) NI-DAQmx 16.1.0f2 or later .NET API
    The TSM NI-DAQmx .NET Code Module API requires the NI-DAQmx 16.1.0f2 or later .NET API.
    If you are using the TSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The TSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    The TSM installation program installs files for TestStand and LabVIEW, including the LabVIEW 2020 Run-Time Engine.
    Notes:
    • TSM 2020 installs SeqEdit.exe.config in the \Bin directory and overwrites any existing file with the same filename in that directory. If you have created a custom SeqEdit.exe.config file, complete the following steps to preserve the custom file.
      • Move the existing SeqEdit.exe.config file to a location outside the directory.
      • Install TSM 2020.
      • Compare the SeqEdit.exe.config file TSM 2020 installed to the custom version of the file and merge the custom changes into the file TSM 2020 installed.
    • If you are installing more than one NI product, visit ni.com/info and enter the Info Code tsminstall to access the NI support article Installation Order for Multiple NI Software Products for more information about this situation. If you install or update LabVIEW after you install TestStand or TSM, close and restart TestStand or run the TestStand Version Selector to properly configure LabVIEW, TestStand, and TSM.
    • NI recommends that you exit all programs before running the TSM installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than average to complete.
    • Visit ni.com/info and enter the Info Code rddrau to access the latest software drivers and updates.
    NI installs TSM using NI Package Manager. If you do not already have NI software installed, TSM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate TSM. For more information on TSM activation, refer to NI Software Activation.
    You can access the software and documentation known issues list online. Visit Known Issues in NI TestStand 2020 Semiconductor Module for an up-to-date list of known issues.
    Refer to the List of Bug Fixes in NI TestStand 2020 Semiconductor Module on the NI website for a list of a subset of issues fixed in NI TestStand 2020 Semiconductor Module. This is not an exhaustive list of issues fixed in NI TestStand 2020 Semiconductor Module. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Refer to the NI TestStand Semiconductor Module book in the TestStand Help, accessible from the Help menu in the TestStand Sequence Editor, for information about NI TestStand 2020 Semiconductor Module.
    TSM includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can open an example sequence file from the subdirectories of the \Examples\NI_SemiconductorModule directory.
    NI TestStand Semiconductor Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2013-2021 National Instruments Corporation. All rights reserved.
    375326G-01
    GMT+8, 2026-2-5 17:40
