查看: 1630|回复: 0
[NI软件产品] NI TestStand 2016 Semiconductor Module Win64Eng Teststand2016半导体模块扩展
    7 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
     楼主| 发表于 2022-11-28 15:53:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    TestStand Semiconductor模块
    TestStand Semiconductor模块扩展了TestStand环境,可帮助您开发、调试、部署和维护半导体测试系统。
    TestStand Semiconductor模块通过引脚/通道匹配、分箱、分选器/探针台驱动程序、限制值导入/导出和多站点编程,扩展了TestStand环境,可帮助您开发和维护半导体系统,包括晶圆级和最终封装测试应用程序。
    发布日期:2016/8/8
    包含的版本:2016完整版
    受支持的操作系统
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    文件大小: 301829831 字节 (287.85 MB)
    修改日期: 2022-03-26 00:26
    MD5: 89932ae0c2a0938bd0a807d5ae63b898
    SHA1: 02db8ea19fcd309d0a1de5364a7f86a711d8a873
    SHA256: a6524e9ddfbc4a4994db84bccde8a71ce59fbe6ace0fd1a698986bf45450d911
    CRC32: 67aa271d
    请注册登录视觉论坛账号,购买附件查看下载地址
    TestStand 2016 Semiconductor x64.txt (526 Bytes, 下载次数: 0, 售价: 10 圆)
    TestStand 2016 Semiconductor Module Readme
    August 2016
    This file contains important information about getting started with the TestStand 2016 Semiconductor Module, including system requirements, installation instructions, and licensing information. Refer to the What's New in the TestStand 2016 Semiconductor Module topic in the TestStand Semiconductor Module Help for information about new features and changes introduced since TestStand 2014 Semiconductor Module SP1. Select Help»TestStand Help and navigate to the Semiconductor Module book in the table of contents of the TestStand Help to launch the TestStand Semiconductor Module Help.
    Getting Started
    The TestStand Semiconductor Module adds the following features and functionality to TestStand for developing semiconductor test system software:
    • Multisite pin map file, TestStand Semiconductor Module Code Module APIs, and Semiconductor Multi Test step type for developing a semiconductor test program that runs on multiple test system hardware configurations with a variable number of test sites at a high parallel test efficiency.
    • Support for binning devices under test (DUTs) based on test results.
    • Support for exporting and importing test limits with text files.
    • Data types, configurable callbacks, and dialog boxes for specifying test program settings, test lot information, and test station settings.
    • Plug-in architecture for handler and prober communication using Semiconductor Module handler/prober drivers.
    • Result processing plug-ins for generating report and data log files for the test lot.
    • Customizable operator interface for executing test programs, enabling or disabling test sites, displaying statistics, and configuring test lot information and test station settings.
    New TestStand Users
    If you are a new TestStand user, NI recommends that you complete the tasks listed in the New Users section of the Guide to Documentation topic of the TestStand Help, which is located by default at \Doc\Help\TSHelp.chm. Select Help»TestStand Help to launch the TestStand Help.
    New TestStand Semiconductor Module Users
    To familiarize yourself with the TestStand Semiconductor Module, review the topics in the Getting Started book in the TestStand Semiconductor Module Help, which is located by default at \Doc\Help\TSSemiconductor.chm. Select Help»TestStand Help and navigate to the Semiconductor Module book in the table of contents of the TestStand Help to launch the TestStand Semiconductor Module Help. The TestStand Semiconductor Module Help also contains information about all module features and functionality.
    Upgrade Users
    If you are upgrading from an earlier version of the TestStand Semiconductor Module, refer to the TestStand 2016 Semiconductor Module New Features and the TestStand 2016 Semiconductor Module Compatibility and Known Issues topics in the TestStand Semiconductor Module Help for compatibility information and major feature changes. Select Help»TestStand Help and navigate to the Semiconductor Module book in the table of contents of the TestStand Help to launch the TestStand Semiconductor Module Help.
    Note  If you are upgrading from an earlier version of TestStand Semiconductor Module and use a custom operator interface based on the TestStand Semiconductor Module 2013 or earlier operator interface source code, NI recommends that you re-implement the custom operator interface to use the latest TestStand Semiconductor Module operator interface source code, which includes improvements for performance, customization, and maintenance.
    Recommended System Requirements
    NI recommends the following system requirements for use with the TestStand Semiconductor Module.
    Requirement
    Recommended
    Minimum
    Comments
    TestStand (32- or 64-bit)
    2016
    Refer to the Recommended System Requirements section of the TestStand Version 2016 Release Notes for information about the recommended system requirements for TestStand.
    LabVIEW (32- or 64-bit)
    2016
    2013
    • TestStand Semiconductor Module APIs are compiled in LabVIEW 2013, 2014 SP1, 2015 SP1, and 2016
    • The LabVIEW operator interface, Lot and Station Settings dialog boxes, and simulated handler are compiled in LabVIEW 2015 SP1
    • The LabVIEW examples are built in LabVIEW 2013
    Free hard disk space
    40 MB
    This value is in addition to the free hard disk space TestStand requires.
    Windows 10 (32- and 64-bit)
    Windows 8.1 (32- and 64-bit) Professional, Ultimate
    NI software installs VC2015 Runtime and .NET 4.6.1. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Windows 7 SP1 (32- and 64-bit) Professional, Ultimate
    NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Refer to the Migrating to TestStand 2012 and Windows 7/Vista section of the NI TestStand Version 2012 Release Notes for more information about using TestStand on Windows 7.
    Windows Server 2012 R2 (64-bit) Enterprise
    Windows Server 2008 R2 SP1(64-bit) Enterprise
    Note: TestStand does not support Guest user accounts on Windows. TestStand supports Administrator and Limited accounts on Windows 7.
    The TestStand Semiconductor Module installation program installs files for TestStand and LabVIEW.
    Notes:
    • NI recommends that you exit all programs before running the TestStand Semiconductor Module installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than average to complete.
    • Visit ni.com/info and enter the Info Code rddrau to access the latest software drivers and updates.
    Complete the following steps to install the TestStand Semiconductor Module:
    • Insert the TestStand Semiconductor Module installation media and follow the instructions that appear on the screen. If no instructions appear on the screen, run the AutoRun executable, autorun.exe.
    The TestStand Semiconductor Module installs the following components:
    • LabVIEW 2013 SP1 Run-Time Engine
    • LabVIEW 2015 SP1 Run-Time Engine
    Licensing
    Note  You must have a valid TestStand 2016 license to use this version of the TestStand Semiconductor Module. You can also run TestStand in Evaluation Mode to use the TestStand Semiconductor Module.
    After you install TestStand Semiconductor Module, you must use the NI Activation Wizard to activate the software or initiate the evaluation period for the software. You must have the serial number and the name of the software kit to activate TestStand Semiconductor Module. You can find both of these items on the Certificate of Ownership card included in your software kit.
    Refer to the TestStand Semiconductor Module Licensing Options topic in the TestStand Semiconductor Module Help for more information about licensing in TestStand Semiconductor Module. Refer to the Activating Your Software topic in the TestStand Help for more information about how to activate TestStand Semiconductor Module. Select Help»TestStand Help to launch the TestStand Help.
    Upgrading TestStand 2014 Semiconductor Module SP1 to TestStand 2016 Semiconductor Module
    Use the following guidelines when you upgrade to TestStand 2016 Semiconductor Module:
    • You can install TestStand 2016 Semiconductor Module over a previous TestStand Semiconductor Module version or install on a system without TestStand 2016 Semiconductor Module.
    • If you installed a previous version of TestStand Semiconductor Module in a non-default directory, you can uninstall the previous version of TestStand Semiconductor Module and install TestStand 2016 Semiconductor Module to that directory.
    Refer to the Migrating to the Current Version of TestStand section in the TestStand 2016 Release Notes for more information about upgrading to TestStand 2016.
    Notes  If you are upgrading from an earlier version of TestStand Semiconductor Module and use a custom operator interface based on the TestStand Semiconductor Module 2013 or earlier operator interface source code, NI recommends that you re-implement the custom operator interface to use the latest TestStand Semiconductor Module operator interface source code, which includes improvements for performance, customization, and maintenance.
    When you close a TestStand Semiconductor Module LabVIEW 2013 SP1 Operator Interface, you might receive a "Cannot create TestStand Engine" error. Visit ni.com/info and enter the Info Code exw5iv to access the National Instruments KnowledgeBase article 7BAE48D9, "Cannot create TestStand Engine" Error when Closing TestStand Semiconductor Module LabVIEW 2013 SP1 Operator Interface, for more information about this issue.
    Refer to the Semiconductor Module book in the TestStand Help, accessible from the Help menu in the TestStand Sequence Editor, for information about TestStand 2016 Semiconductor Module.
    The TestStand Semiconductor Module includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can open an example sequence file from the subdirectories of the \Examples\NI_SemiconductorModule directory.
    © 2013–2016 National Instruments. All rights reserved.
    375326C-01
    GMT+8, 2026-2-5 17:39
