查看: 1839|回复: 0
[NI软件产品] NI TestStand 2014 SP1 Semiconductor Module Win64Eng Teststand2014SP1半导体模块扩展
    7 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
     楼主| 发表于 2022-11-28 15:49:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    TestStand Semiconductor模块
    TestStand Semiconductor模块扩展了TestStand环境,可帮助您开发、调试、部署和维护半导体测试系统。
    TestStand Semiconductor模块通过引脚/通道匹配、分箱、分选器/探针台驱动程序、限制值导入/导出和多站点编程,扩展了TestStand环境,可帮助您开发和维护半导体系统,包括晶圆级和最终封装测试应用程序。
    发布日期:2016/1/31
    包含的版本:2014SP1完整版
    受支持的操作系统
    Windows 8 64-bit
    Windows Server 2012 R2 64-bit
    Windows 7 64-bit
    Windows Server 2008 R2 64-bit
    Windows 7 (SP1) 64-bi
    zip
    文件大小: 278506067 字节 (265.60 MB)
    修改日期: 2022-03-26 00:26
    MD5: 7d5287f99c48863e968f7fe1b089965c
    SHA1: d6ebd3a7cb3fd12ecab97cde1685caf32aae8214
    SHA256: ba5dc4c4f2df9da6723791f5d46c039a705ce151fedd4e1a743d5807e9d8f595
    CRC32: 0672dae0
    exe
    文件大小: 277647936 字节 (264.79 MB)
    修改日期: 2022-11-28 22:16
    MD5: f6c47544355825e77acabe1ccc015607(秒传)
    SHA1: 48ef6e944589c31589e0f272ebbbc9055d165dab
    SHA256: d3fa76dd675ede35d6a0f5e61e0fb27f4f13ac9fc10deebe635feef22c0e5486
    CRC32: f0ab2648
    请注册登录视觉论坛账号,购买附件查看下载地址
    TestStand 2014SP1 Semiconductor x64.txt (1014 Bytes, 下载次数: 1, 售价: 10 圆)
    TestStand 2014 Semiconductor Module SP1 Readme
    January 2016
    This file contains important information about getting started with the TestStand 2014 Semiconductor Module SP1, including system requirements, installation instructions, and licensing information. Refer to the What's New in the TestStand 2014 Semiconductor Module SP1 topic in the TestStand Semiconductor Module Help for information about new features and changes introduced since TestStand 2014 Semiconductor Module. Select Help»NI TestStand Help and navigate to the Semiconductor Module book in the table of contents of the TestStand Help to launch the TestStand Semiconductor Module Help.
    Getting Started
    Recommended System Requirements
    Licensing
    Upgrading TestStand 2014 Semiconductor Module to TestStand 2014 Semiconductor Module SP1
    Getting Started
    The TestStand Semiconductor Module adds the following features and functionality to TestStand for developing semiconductor test system software:
    • Multisite pin map file, code module development APIs, and Semiconductor Multi Test step type for developing a semiconductor test program that runs on multiple test system hardware configurations with a variable number of test sites at a high parallel test efficiency.
    • Support for binning devices under test (DUTs) based on test results.
    • Support for exporting and importing test limits with text files.
    • Data types, configurable callbacks, and dialog boxes for specifying test program settings, test lot information, and test station settings.
    • Plug-in architecture for handler and prober communication using Semiconductor Module handler/prober drivers.
    • Result processing plug-ins for generating report and data log file for the test lot.
    • Customizable operator interface for executing test programs, enabling or disabling test sites, displaying statistics, and configuring test lot information and test station settings.
    New TestStand Users
    If you are a new TestStand user, NI recommends that you complete the tasks listed in the New Users section of the Guide to Documentation topic of the TestStand Help, which is located by default at \Doc\Help\TSHelp.chm. Select Help»TestStand Help to launch the TestStand Help.
    New TestStand Semiconductor Module Users
    To familiarize yourself with the TestStand Semiconductor Module, review the topics in the Getting Started book in the TestStand Semiconductor Module Help, which is located by default at \Doc\Help\TSSemiconductor.chm. Select Help»TestStand Help and navigate to the Semiconductor Module book in the table of contents of the TestStand Help to launch the TestStand Semiconductor Module Help. The TestStand Semiconductor Module Help also contains information about all module features and functionality.
    Upgrade Users
    If you are upgrading from an earlier version of the TestStand Semiconductor Module, refer to the TestStand 2014 Semiconductor Module SP1 New Features and the TestStand 2014 Semiconductor Module SP1 Compatibility and Known Issues topics in the TestStand Semiconductor Module Help for compatibility information and major feature changes. Select Help»TestStand Help and navigate to the Semiconductor Module book in the table of contents of the TestStand Help to launch the TestStand Semiconductor Module Help.
    NI recommends the following system requirements for use with the TestStand Semiconductor Module.
    Requirement
    Recommended
    Minimum
    Comments
    TestStand (32- or 64-bit)
    2014 SP1
    Refer to the Recommended System Requirements section of the TestStand Version 2014 SP1 Release Notes for information about the recommended system requirements for TestStand.
    LabVIEW (32- or 64-bit)20152013
    • TestStand Semiconductor Module APIs are compiled in LabVIEW 2013, 2014 SP1, and 2015
    • The LabVIEW operator interface, Lot and Station Settings dialog boxes, simulated handler, and report generators are compiled in LabVIEW 2015
    • The LabVIEW examples are built in LabVIEW 2013
    Free hard disk space
    20 MBThis value is in addition to the free hard disk space TestStand requires.
    Windows 8 (32- and 64-bit) Professional, Ultimate
    Windows 7 (32- and 64-bit) Professional, UltimateService Pack 1
    Refer to the Migrating to TestStand 2012 and Windows 7/Vista section of the NI TestStand Version 2012 Release Notes for more information about using TestStand on Windows 7.
    Windows Server 2012 R2 (64-bit) Enterprise
    Windows Server 2008 R2 (64-bit) Enterprise
    HardwareNI PXIe-8135
    Note: TestStand does not support Guest user accounts on Windows. TestStand supports Administrator and Limited accounts on Windows 7.
    The TestStand Semiconductor Module installation program installs files for TestStand and LabVIEW.
    Notes:
    • NI recommends that you exit all programs before running the TestStand Semiconductor Module installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than average to complete.
    • The TestStand 2014 Semiconductor Module SP1 installation will overwrite the user configuration file \Cfg\NI_SemiconductorModule\OISettingsTable.cfg installed by TestStand 2014 Semiconductor Module. If you have made any modifications to the file, create a backup of the file before installing to avoid losing changes.
    • Visit ni.com/info and enter the Info Code rddrau to access the latest software drivers and updates.
    Complete the following steps to install the TestStand Semiconductor Module:
    • Insert the TestStand Semiconductor Module installation media and follow the instructions that appear on the screen. If no instructions appear on the screen, run the AutoRun executable, autorun.exe.
    The TestStand Semiconductor Module installs the following components:
    • LabVIEW 2013 SP1 Run-Time Engine
    • LabVIEW 2015 Run-Time Engine
    Licensing
    Note  You must have a valid TestStand 2014 SP1 license to use this version of the TestStand Semiconductor Module. You can also run TestStand in Evaluation Mode to use the TestStand Semiconductor Module.
    After you install TestStand Semiconductor Module, you must use the NI Activation Wizard to activate the software or initiate the evaluation period for the software. You must have the serial number and the name of the software kit to activate TestStand Semiconductor Module. You can find both of these items on the Certificate of Ownership card included in your software kit.
    Refer to the TestStand Semiconductor Module Licensing Options topic in the TestStand Semiconductor Module Help for more information about licensing in TestStand Semiconductor Module. Refer to the Activating Your Software topic in the TestStand Help for more information about how to activate TestStand Semiconductor Module. Select Help»TestStand Help to launch the TestStand Help.
    Use the following guidelines when you upgrade to TestStand 2014 Semiconductor Module SP1:
    • You can install TestStand 2014 Semiconductor Module SP1 over a previous TestStand Semiconductor Module version, or install on a system without TestStand 2014 Semiconductor Module 2014.
    • If you installed a previous version of TestStand Semiconductor Module in a non-default directory, you can uninstall the previous version of TestStand Semiconductor Module and install TestStand 2014 Semiconductor Module to that directory.
    Refer to the Migrating to the Current Version of TestStand section in the TestStand 2014 SP1 Release Notes for more information about upgrading to TestStand 2014 SP1.
    Refer to the Semiconductor Module book in the TestStand Help, accessible from the Help menu in the TestStand Sequence Editor, for information about TestStand 2014 Semiconductor Module SP1.
    The TestStand Semiconductor Module includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can open an example sequence file from the subdirectories of the \Examples\NI_SemiconductorModule directory.
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Current Application
    Icon Location
    Pin to Action
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    © 2013–2016 National Instruments. All rights reserved.
    375326B-01
    GMT+8, 2026-2-5 17:40
