查看: 2851|回复: 0
[NI软件产品] NI VeriStand 2021R3 and Drivers Win11 64bitEng PC版完整版及运行版NIVS2021R3 21.3.0含驱动版8.86GB
    6 小时前
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-11-25 15:36:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VeriStand 2021 R3 and Drivers
    发布日期:2022/10/12
    包含的版本:2021 PC版,完整版,运行版,版本号21.3.0
    受支持的操作系统
    文件大小: 2737532928 字节 (2.55 GB)
    修改日期: 2022-04-18 10:16
    MD5: 1a8d7e990eac17915f3077b494b5466e
    SHA1: f69fe0372926b21f530487be171980895b85a6d6
    SHA256: cae5cd1addb852716af1b89d3b9c5aa6069245a0e98724f79a3fa6a1719ea1fe
    CRC32: 7c36a26b
    请注册登录视觉论坛账号,购买附件查看下载地址
    VeriStand2021R3 and Drivers.txt (584 Bytes, 下载次数: 3, 售价: 20 圆)
    VeriStand 2021 R3 Readme
    October 2022
    This file contains installation instructions and compatibility information for VeriStand 2021 R3.
    • VeriStand Documentation: New features, behavior changes, and other documentation
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools. Use VeriStand's run-time editable user interface to implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand 2021 R3 installs with the following:
    • NI-DAQmx 2022 Q4
    • NI-VISA 2022 Q4
    • NI-SLSC 2022 Q4
    • NI-XNET 2022 Q3
    • NI R Series Multifunction RIO 2022 Q4
    Simulation Models
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2021 R3 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 11 64-bit version
    • Windows 10 64-bit version 21H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2021 R3, select Linux RT System Image 2022 Q4 and enable support for the LabVIEW 2021 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2021 R3.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2021 R3. To access the documents, refer to the VeriStand Release Notes.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2021 R3 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2021 R3 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2021 R3 .NET API Help.
    • VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2021\Projects\Example directory.
    • Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2021\Examples directory.
    • ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2021\Examples directory.
    • LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2021\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2021\examples\NI VeriStand Custom Devices directory.
    © 2009–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-2 16:39
