查看: 1747|回复: 0
[NI软件产品] NI VeriStand Custom Devices 2022 Q4 Win11 32/64bitEng NI VeriStand自定义设备22.8
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-11-25 15:22:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VeriStand Custom Devices自定义设备
    VeriStand Custom Devices为VeriStand添加了硬件支持。
    VeriStand Custom Devices是VeriStand的附加软件工具。该附加软件为HIL测试应用的其他硬件和总线类型提供支持。您可以使用VeriStand System Explorer来配置自定义设备,以满足实时测试应用的需求。VeriStand Custom Devices包括以下自定义设备:数据共享框架;嵌入式数据记录仪;发动机仿真工具包;FPGA附加软件;仪器附加软件;路由和故障分析(NI-SWITCH和SLSC开关);扫描引擎和EtherCAT;SLSC 12201;SLSC EDS;同步;以及Telemetry和System Monitor。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    文件大小: 657932288 字节 (627.45 MB)
    修改日期: 2022-10-13 09:54
    MD5: 729849b2eacb0f03c302c99056975ff3
    SHA1: bca515c44548ea61b8dbbec5dee5c4b09fb0301d
    SHA256: bf3197867b8b99255740a5e3ecde90a6eca8b21499731d81f04f74c827b46516
    CRC32: 256e4d8f
    请注册登录视觉论坛账号,购买附件查看下载地址
    VeriStand Custom Devices2022Q4.txt (607 Bytes, 下载次数: 0, 售价: 10 圆)
    官方没有针对该软件的自述说明,使用的是Veristand的自述文件。2022 Q4版自述文件暂未更新,参考2021 R3版自述文件。
    VeriStand 2021 R3 Readme
    October 2022
    This file contains installation instructions and compatibility information for VeriStand 2021 R3.
    • VeriStand Documentation: New features, behavior changes, and other documentation
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools. Use VeriStand's run-time editable user interface to implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand 2021 R3 installs with the following:
    • NI-DAQmx 2022 Q4
    • NI-VISA 2022 Q4
    • NI-SLSC 2022 Q4
    • NI-XNET 2022 Q3
    • NI R Series Multifunction RIO 2022 Q4
    Simulation Models
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2021 R3 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 11 64-bit version
    • Windows 10 64-bit version 21H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2021 R3, select Linux RT System Image 2022 Q4 and enable support for the LabVIEW 2021 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2021 R3.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2021 R3. To access the documents, refer to the VeriStand Release Notes.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2021 R3 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2021 R3 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2021 R3 .NET API Help.
    • VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2021\Projects\Example directory.
    • Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2021\Examples directory.
    • ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2021\Examples directory.
    • LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2021\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2021\examples\NI VeriStand Custom Devices directory.
    © 2009–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:31
