查看: 1434|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2022 Q4 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试22.8
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-11-25 10:28:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版/运行版,版本号22.8.0
    64位完整版校验和:
    文件大小: 1111576576 字节 (1.04 GB)
    修改日期: 2022-10-13 09:53
    MD5: 5d37116d5fe8327fdd8d36bbdd13b7f5
    SHA1: a6e2f960f3deb6b35e67080d1ae0ff4469642788
    SHA256: 92c6849e02a2c0d0aa2640593e40aed12167d3103bc643218c3fe2d3dc726b87
    CRC32: dd03c1d1
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx W-CDMA 2022Q4Full.txt (548 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 609966080 字节 (581.71 MB)
    MD5: 1a059d923bdce345413088e070c08b34
    SHA1: 8d2302c97828a40a5f03e4bbe96740c119c9011f
    SHA256: 6045e44770989e00480eb971da95c9cbc73e05d63959727cc7bcc19a206b71b9
    CRC32: 3e29ae43
    RFmx W-CDMA 2022Q4RTE.txt (572 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 2022 Q4 Readme
    October 2022
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2022 Q3 includes the following new feature:
    RFmx WCDMA 21.8 includes the following new feature:
    • Support for Downlink in Link Direction property of ModAcc measurement
    RFmx WCDMA 2022 Q4 supports the following 64-bit operating systems:
    Note NI-USRP no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:29
