查看: 1635|回复: 0
[NI软件产品] NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 2022 Q4 Win11 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数22.8
     楼主| 发表于 2022-11-24 11:41:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版/运行版,版本号22.8.0
    64位完整版校验和:
    文件大小: 1220458496 字节 (1.14 GB)
    修改日期: 2022-10-13 09:53
    MD5: 28c53690ef87a79a94ee246a4471407e
    SHA1: 0fb212b2f2595124e58917fede2a7b99f4603b4c
    SHA256: 9885fa8783d98a030c94f31535e3f7085c1796f520484419091927bab7507179
    CRC32: d0efb0d6
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx SpecAn 2022Q4Full.txt (588 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 615970816 字节 (587.44 MB)
    MD5: 3ea0449b1f9da359fac265415bc81d47
    SHA1: 5064921c0c7615c1dddc95c46259bfe2de0cdf47
    SHA256: 44ef5fba20a8373969604921a8db9eeb5dd05ee25a4e8d48b4094048d723d2e0
    CRC32: 04c5c038
    RFmx SpecAn 2022Q4RTE.txt (612 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx SpecAn 2022 Q4 Readme
    October 2022
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    • RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx SpecAn Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx SpecAn offers simple access to the most advanced optimization techniques such as multi-measurement parallelism, multi-DUT measurements, and high dynamic range noise correction. The result is extremely fast and high-quality measurements with the minimal software development effort.
    RFmx SpecAn 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx SpecAn 2022 Q3 includes the following new feature:
    RFmx SpecAn 21.8 includes the following new features:
    • Support for configuring odd and even coefficients in DPD GMP polynomial in DPD measurement
    • Support for maximum gain and user-defined gain reference modes for compression point computation in AMPM measurement
    • Support for peak reference power and peak reference power gain results in AMPM measurement
    RFmx SpecAn 21.3 includes the following new features:
    • Support for list mode feature on PXIe-5840/5841/5830/5831/5832
    • Support for configuring manual gain reference for compression point computation in AMPM measurement
    • Support for all FFT window types and user-defined overlap (%) for Sequential FFT measurement method in ACP measurement
    • Support for I-Only and Q-Only modes in Spectrum measurement for PXIe-5820
    • Addition of I vs Time and Q vs Time traces in IQ measurement in the RFmx Soft Front Panel
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 2022 Q4 supports the following 64-bit operating systems:
    Note    RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 2022 Q4 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 2022 Q4 to an unsupported OS. Additionally, after installing RFmx SpecAn 2022 Q4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx SpecAn (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 19.1 or later (for DPD examples)
    Download the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx SpecAn installs the following licensed products
      • RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
      • RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
      • RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
    • Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx SpecAn palette VIs are available from the Functions » Measurement I/O » NI-RFmx » SpecAn palette.
    Documentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation.
    Select Help » Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output » Modular Instruments » NI-RFmx » SpecAn. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following is the behavior change in RFmx SpecAn 2022 Q4 from RFmx SpecAn 2022 Q3:
    • RFmx SpecAn drops support for 32-bit user mode.
    The following is the behavior change in RFmx SpecAn 2022 Q3 from RFmx SpecAn 21.8.2:
    The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6.
    © 2014–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-13 13:10
