NI RFmx GSM/EDGE+ 2022 Q4 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件22.8
RFmx GSM/EDGE+
RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2022/10/12
包含的版本:2022 Q4完整版/运行版,版本号22.8.0
64位完整版校验和:
文件大小: 1170182144 字节 (1.09 GB)
修改日期: 2022-07-23 09:53
MD5: eccdcaf5d4156c67adab2f9ffb3d1c48
SHA1: 7e5c6d81a2fcd1d6ce4599e921f4d66e92909cee
SHA256: c1bb0ac7bdf623db0c42ffc86382c96dba3e3deb34431407e153ba88d30f63f1
CRC32: faa13e4c
NI官方下载和百度网盘下载地址:
注册登录视觉论坛账号,购买附件查看下载地址
RFmx GSMEDGE 2022Q4Full.txt
(541 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 595595264 字节 (568.00 MB)
修改日期: 2022-07-23 09:56
MD5: 596ffc0df6ea49ee024e6e39f9b04ceb
SHA1: eefb8ffadacf807592697127a77bff216c8b98a7
SHA256: aec1a99bd1c86d4902e1b4627917b129cceb14a9d53e4e78eed5c2a46c7ad885
CRC32: 8af2003a
NI官方下载和百度网盘下载地址:
RFmx GSMEDGE 2022Q4RTE.txt
(565 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx GSM 2022 Q4 ReadmeOctober 2022 This file contains important information about the RFmx GSM, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx GSM Manuals: New features, behavior changes, and other documentation
Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Legal Information OverviewRFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. New FeaturesRFmx GSM 2022 Q4 includes the following new features: - Support for PXIe-5842
- Support for configurable RBW in PVT measurement.
RFmx GSM 2022 Q3 includes the following new feature: - Support for LabVIEW 2022 Q3 (32-bit and 64-bit)
RFmx GSM 21.3 includes the following new feature: - Support for LabVIEW 2021 (32-bit and 64-bit)
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx GSM has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx GSM 2022 Q4 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportRFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx GSM (64-bit only) | | LabVIEW | 2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette. Accessing the DocumentationDocumentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation. Finding ExamplesYou can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3 - RFmx GSM drops support for 32-bit user mode.
The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2 - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6. - Obsoleted RFmxInstr Configure Automatic SG SA Shared LO API and RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Legal InformationCopyright © 2015–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
