查看: 1458|回复: 0
[NI软件产品] NI RFmx Demod/Analog Modulation/Digital Modulation 2022 Q4 Win11 64bitEng NI RFmx解调/模拟调制/数字调制22.8
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-11-24 10:55:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    RFmx数字调制
    RFmx数字変調提供测试应用数字変調信号生成和分析。
    RFmx Digital Modulation是RFmx Demod内运行的应用软件,该软件与RFmx Digital Modulation一起安装。该软件可扩展NI RF仪器对于数字调制信号的生成和分析能力。您可以使用这个软件,通过对误差矢量幅度(EVM)、调制误差率(MER)、rho、振幅下降等的测量,分析ASK、FSK、PSK和QAM信号。此外,您可以分析同步化和应用化的灵活均衡、脉冲形状过滤、测量过滤和损伤补偿的解调比特。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版/运行版,版本号22.8.0
    64位完整版校验和:
    文件大小: 719773696 字节 (686.43 MB)
    修改日期: 2022-10-13 09:53
    MD5: e7a7b0af14523ae8470dda75597a8250
    SHA1: ac36ce98bdb2fab640053ff4097f6ce327841d9a
    SHA256: 931f9630d1469055febb47064950012dba0010b3715ecbaeb516c27fa9e6e474
    CRC32: b8aa9ecd
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx Demod 2022Q4Full.txt (581 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 604753920 字节 (576.74 MB)
    MD5: ef6936aebaefdcc26900c2fd56322467
    SHA1: d3d4401427428e976a2b785a271260d74b7c3079
    SHA256: dcf8a9b2cd48e275e21da7879566ee75c4eed8e769f10d79b83505ddd04727d4
    CRC32: de14a3e6
    NI官方下载和百度网盘下载地址:
    RFmx Demod 2022Q4RTE.txt (604 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Demod 2022 Q4 Readme
    October 2022
    This file contains important information about the RFmx Demod, including system requirements, and installation instructions.
    • RFmx Analog Modulation Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Digital Modulation Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Analog Modulation Manuals: New features, behavior changes, and other documentation
    • RFmx Digital Modulation Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx Demod 2022 Q3 includes the following new features:
    RFmx Demod 21.3 includes the following new features:
    RFmx Demod 2022 Q4 supports the following 64-bit operating systems:
    Versions Supported by RFmx Demod (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021, 2022 Q3
    Required Software
    • NI-RFSG 14.0.1 or later
    • RFmx Demod installs the following licensed products
      • Analog Modulation: This will enable demodulation support of Analog Modulation (AM), Frequency Modulation (FM), and Phase Modulation (PM).
      • Digital Modulation: This will enable demodulation support of Amplitude-Shift Keying (ASK), Frequency-Shift Keying (FSK), Minimum-Shift Keying (MSK), Phase-Shift Keying (PSK), and Quadrature Amplitude Modulation (QAM).
    • Use the serial number that is included with your software to activate RFmx Demod. For more information on RFmx Demod activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMx.Fx40.dll
    Select Start » National Instruments» RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    RFmx Demod palette VIs are available from the Functions » Measurement I/O » RFmx » Demod palette.
    Documentation for RFmx Demod is located at Start » National Instruments » RFmx Demod Documentation.
    You can access all the installed RFmx Demod examples at Start » National Instruments » RFmx Demod Examples.
    The following is the behavior change in RFmx Demod 2022 Q4 from RFmx Demod 2022 Q3
    • RFmx Demod drops support for 32-bit user mode.
    The following items are behavior changes in RFmx Demod 20.7 from RFmx Demod 20.6.
    © 2014–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:28
