查看: 1674|回复: 0
[NI软件产品] NI RFmx CDMA2000 2022 Q4 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版下载22.8
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-11-24 10:39:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版/运行版,版本号22.8.0
    64位完整版校验和:
    文件大小: 722728960 字节 (689.25 MB)
    修改日期: 2022-10-13 09:53
    MD5: b58b621049c0c8f2b63621b97481cff2
    SHA1: 3bf91e3bd6883f561e17113d4a784a37ed30cf61
    SHA256: e001db186c33b6283ecf23367cbd0a19c2598e570d8cc80c824981e2c4e96261
    CRC32: c768e20b
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K 2022Q4Full.txt (550 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 609923072 字节 (581.67 MB)
    MD5: 3d65e36d4c23dcb1c9a7ad02be9bb962
    SHA1: 9bfccbf0c095d9baf3afd07695b389368ec47301
    SHA256: c51a3932bf72b8ee13de0e35e5b2239240c0b83404eb463b1a7a2842809a000a
    CRC32: a8562c51
    RFmx CDMA2K 2022Q4RTE.txt (573 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx CDMA2k 2022 Q4 Readme
    October 2022
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2022 Q3 includes the following new feature:
    RFmx CDMA2k 21.3 includes the following new feature:
    RFmx CDMA2k 2022 Q4 supports the following 64-bit operating systems:
    Note NI-USRP no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:31
