NI RFmx for Bluetooth Test 2022 Q4 Win11 64bitEng RFmx蓝牙测试NIRFmxBluetooth22.8
RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
发布日期:2022/10/12
包含的版本:2022 Q4完整版/运行版,版本号22.8.0
64位完整版校验和:
文件大小: 1104457728 字节 (1.03 GB)
修改日期: 2022-10-13 09:53
MD5: 05cc056cc6f89c6d2fd987a6e0f02430
SHA1: 04898a64d45908bf5d8bf159df7c50d25792e613
SHA256: 9b75047b70166dfcede91db605265a8cb53f7d745382631adca24f8538a0f3c0
CRC32: a62234d8
请注册登录视觉论坛账号,购买附件查看下载地址
RFmx BluetoothTest2022Q4Full.txt
(568 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 650631168 字节 (620.49 MB)
MD5: d2e3d1650bf413d430f7a0e4157ee8ca
SHA1: 45ac4401c69238dad9ef4f3dda5ea288e7cf9481
SHA256: ceec8c4399fd27b9c150b426824820136ff6fc0743e75eb79c3c38ee6f5d0112
CRC32: c2ee44de
RFmx BluetoothTest2022Q4RTE.txt
(592 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx for Bluetooth® Test 2022 Q4 ReadmeOctober 2022 This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Legal Information OverviewRFmx for Bluetooth® Test supports the following features: - Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.3, and the Bluetooth RF PHY test specifications RF.TS.p32 and RFPHY.TS.p17.
- Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.3.
- Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
- Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
- Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
New FeaturesRFmx for Bluetooth® Test 2022 Q4 includes the following new feature: - Support for DF2 and CFO measurements for Bluetooth LE 500kbps (S=2) packets
- Support for PXIe-5842
RFmx for Bluetooth® Test 2022 Q3 includes the following new feature: - Support for LabVIEW 2022 Q3 (32-bit and 64-bit)
RFmx for Bluetooth® Test 21.8 includes the following new features: - Support for Initial Frequency Error Maximum result for LE packets in ModAcc measurement
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx for Bluetooth® Test has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx for Bluetooth® Test 2022 Q4 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2022 Q4 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2022 Q4 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2022 Q4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx for Bluetooth® Test (64-bit only) | | LabVIEW | 2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette. Accessing the DocumentationDocumentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation. Finding ExamplesYou can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx for Bluetooth® Test 2022 Q4 from RFmx for Bluetooth® Test 2022 Q3: - RFmx for Bluetooth® Test drops support for 32-bit user mode.
The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2: - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7. - Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Legal InformationCopyright © 2019–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
