查看: 1495|回复: 0
[NI软件产品] NI RFmx 2022 Q4 Win11 64bitEng NI Wireless Test Standard Software ni-rfmx-suite_22.8
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-11-23 15:51:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期:2022/10/12
    包含的版本:2022Q4完整版/运行版,版本号22.8.0
    Full完整版
    文件大小: 2549440512 字节 (2.37 GB)
    修改日期: 2022-10-13 09:53
    MD5: b20ecb72f17d1b00483efe44d072c728(重复一致)
    SHA1: cd876e81ba56625bd17c0dc91f6766cb80eaee0a
    SHA256: 3629a942694796a4b8579d50815f498ce755b4638660d90bbf72ad383dc40c26
    CRC32: 16e29382
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx2022Q4Full.txt (570 Bytes, 下载次数: 0, 售价: 10 圆)
    RTE运行版
    文件大小: 831272960 字节 (792.76 MB)
    MD5: f8dc837257bc89c689c675fe3bf68082
    SHA1: a88c56fbf39f36c7b8931147f515a6fd36cb0fcf
    SHA256: 8c5feb1e93ac869e88d114f98265a440c9d080598ed6b0b1a8a29438cc633c15
    CRC32: 6f889cb4
    RFmx2022Q4RTE.txt (582 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 2022 Q4 Readme
    October 2022
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 2022 Q4 supports the following 64-bit operating systems:
    Note RFmx no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by RFmx (64-bit Only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, or 2022 Q3
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    © 2019–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:29
