NI Pulsed RF Measurement Library 1.2.0 Win11 32/64bitEng NI脉冲射频测量库1.2.0
Pulsed RF Measurement Library脉冲射频测量库
脉冲射频测量库可对电子扫描阵列系统中使用的元件进行脉冲射频测量。
脉冲射频测量库是一个软件附加软件,可以与PXI硬件和NI软件一起使用,对功率放大器(PA)、发射接收模块(TRM)等进行射频测量。利用该软件,您可以执行脉冲设计和稳定性、2端口S参数和功率附加效率的测量,其可用于PA和TRM的设计验证、特性分析和生产测试。脉冲射频测量库包括配置和测量功能以及编程实例,可作为构建您的自动测试应用程序的编程模板。附带VI参考指南还提供了系统的描述和第三方硬件组件的建议,如耦合器、开关、线缆、适配器和校准套件。
发布日期:2022/8/16
包含的版本:1.2.0完整版
文件大小: 9404876800 字节 (8.76 GB)
修改日期: 2022-08-17 09:49
MD5: b5dbe7c801a2a4972fd1fab4f00c9a91
SHA1: 27edbc21477887df8d5df316047b7a320a92845f
SHA256: a6e44cf19620a5a387163530d2ab46bf24de8b66e8af6e2b2bdf910792b4ffd4
CRC32: 4312d48c
请注册登录视觉论坛,购买附件后查看下载地址
Pulsed RF Measurement Library1.2.0.txt
(530 Bytes, 下载次数: 0, 售价: 20 圆)
Pulsed RF Measurement Library 1.2 ReadmeJuly 2022 This file contains important information about the Pulsed RF Measurement Library, including system requirements, and installation instructions. You can find more release information on ni.com. - Pulsed RF Measurement Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- Electronically Scanned Array Characterization Reference Architecture User Manual: New features, behavior changes, and other documentation
Overview Included Components System Requirements Supported Operating Systems Required Software Installation Instructions Accessing the VIs Accessing the C API Accessing the Calibration Kit SNP File Creator Tool Product Security and Critical Updates Supported Hardware Accessing the Help Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information OverviewThe Pulsed RF Measurement Library is a component of the Electronically Scanned Array Characterization Reference Architecture that includes configuration and measurement functions for S-parameter, pulse stability, pulse profile, and power-added efficiency (PAE) measurements. The Pulsed RF Measurement Library also contains interactive panels for benchtop characterization and programming examples that serve as a template for building automated applications for testing power amplifiers and transmit-receive modules. Included ComponentsThe Pulsed RF Measurement Library includes the following major components: - A software library of configuration and measurement VIs
- Interactive examples that enable benchtop characterization of DUTs
- Programming examples that serve as a template for building automated test applications
System RequirementsThe Pulsed RF Measurement Library 1.2 has the following requirements: - Intel Xeon quad-core processor
- At least 512 GB of disk space
- At least 16 GB/s controller bandwidth
- 8 GB RAM
- 64-bit version of Windows 10 (version 1903)
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2019 SP1 and LabVIEW 2020 SP1. Required SoftwareThe Pulsed RF Measurement Library 1.2 requires the following software versions. Software | Versions Supported by Pulsed RF Measurement Library 1.2 | | LabVIEW | 2019 SP1, 2020 SP1 | Installation InstructionsDownload the Pulsed RF Measurement Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
Use the serial number that is included with your software to activate the Pulsed RF Measurement Library. For more information on activating the Pulsed RF Measurement Library, refer to Activating a Product.
Accessing the VIsPulsed RF Measurement Library VIs are available from the \vi.lib\addons\PRFMsc directory. Accessing the C APIThe header files, import libraries, and .dll that make up the C API are available from the \PRFM Library\C Support directory. Accessing the Calibration Kit SNP File Creator ToolThe Calibration Kit SNP File Creator executable is available from the \PRFM Library directory. You can copy the executable to and run it from any location. You must have a 64-bit LabVIEW runtime engine version 2020 or later to run the Calibration Kit SNP File Creator tool. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Supported HardwareFor information on supported hardware, refer to the Hardware Overview section of the Electronically Scanned Array Characterization Reference Architecture User Manual. Accessing the HelpRefer to the Electronically Scanned Array Characterization Reference Architecture User Manual, accessible from \PRFM Library directory, for information about the Pulsed RF Measurement Library. Finding ExamplesProgramming examples for the Pulsed RF Measurement Library are located in the labview\examples\PRFMsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. Interactive panels for the Pulsed RF Measurement Library are located in the \PRFM Library directory. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Legal InformationCopyright © 2021-2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
