查看: 1694|回复: 0
[NI软件产品] NI PXIe-7899 API and Design Files 2022 Q4 Win11 32/64bitEng NI PXIe-7899应用程序接口和设计文件22.8
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-11-23 12:33:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    PXIe-7899 API and Design Files包含一个socketed CLIP节点和API,可帮助您设计和控制PXIe-7899。
    PXIe-7899 API and Design Files是一款实用程序软件,可结合LabVIEW FPGA模块对PXIe-7899 PXIe XC网络控制器模块进行编程。使用PXIe-7899 API and Design Files需要先安装LabVIEW、LabVIEW FPGA模块和NI FlexRIO驱动软件。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    语言:中文, 德语, 日语, 法语, 英文, 韩语
    文件大小: 8355880960 字节 (7.78 GB)
    修改日期: 2022-10-13 09:53
    MD5: e4a113b7ce7022f6f3bc9a9e80a2199b
    SHA1: 650dd52c4f31b3ac35a7ad2063d743826763d306
    SHA256: 206ee0d36dae11da39e4911b8d3c3e09f76d709ab78958e27f31481bd3adf5be
    CRC32: 371ebe80
    请注册登录视觉论坛,购买附件后查看下载地址
    PXIe-7899 API and Design Files22.8.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    PXIe-7899 API and Design Files 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for PXIe-7899 API and Design Files 2022 Q4.
    • PXIe-7899 API and Design Files Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • FlexRIO Release Notes: Known issues, bugs fixed since the last release, and other notes about FlexRIO
    The PXIe-7899 API and Design Files package includes the PXIe-7899 Socketed CLIP node for programming in LabVIEW FPGA and APIs that enable a host VI to control the PXIe-7899 I/O module.
    PXIe-7899 API and Design Files 2022 Q4 has the following requirements:
    • 2 GHz or faster 64-bit (x64) processor (Quad core or higher recommended)
    • 4 GB RAM (8 GB or more recommended)
    • 6 GB of disk space (at a minimum)
    • 1,024 x 768 screen resolution
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    PXIe-7899 API and Design Files 2022 Q4 supports the following operating system:
    PXIe-7899 API and Design Files 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by the PXIe-7899 API and Design Files
    LabVIEW2019, 2020, 2021, 2022
    LabVIEW FPGA2019, 2020, 2021, 2022
    LabVIEW FPGA Compilation Tool for Vivado2019, 2020, 2021, 2022
    Download the PXIe-7899 API and Design Files installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation method of the Suite or Bundle.
    The "PXIe-7899 API and Design Files Support for LabVIEW" package supports applications using PXIe-7899 API and Design Files ​with LabVIEW 2019 or later. When installing PXIe-7899 API and Design Files, this package will be recommended if you have already installed LabVIEW 2019.
    • Added support for LabVIEW 2022
    The PXIe-7899 API and Design Files supports the PXIe-7899.
    For more information and guidance on the PXIe-7899 API and Design Files, refer to the PXIe-7899 Getting Started Guide at ni.com/docs.
    PXIe-7899 API and Design Files no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2020–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:28
