查看: 1330|回复: 0
[DataPlugin] NI Instron DataPlugin for IST 2022 Q4 Win11 32/64bitEng NI ​Instron​结构​测试​系统IST数据插件22.8
    12 小时前
  • 签到天数: 3595 天
    连续签到: 3 天
     楼主| 发表于 2022-11-22 16:35:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Instron
    Instron DataPlugin for IST支持读取、写入、导入和导出由RS LabSite创建的Instron结构测试系统(IST)文件。
    Instron DataPlugin for IST是一款DataPlugin,支持文件扩展名为.acq的IST文件。借助该DataPlugin,您可以仅保存第一个ChannelGroup的通道,并将组中的所有通道修整为最短通道的长度。此外,您可以在编写Float8或Int4、UInt4和Int2之间切换。
    发布日期:2022/10/17
    扩展:*.ACQ
    方向:读 / 写入
    应用​程序:IST
    包含的版本:21.8完整版
    文件大小: 200284160 字节 (191.01 MB)
    修改日期: 2022-11-07 21:48
    MD5: 94cbf6f1b57434aa0139e04d91188780
    SHA1: 2869cda416127f1373997a10f07d0b8673a22f4d
    SHA256: d8a2b76ec0336e968b7a590d515d551ac7680b93c5e5dacb94f6633053d75b32
    CRC32: 8568394f
    请注册登录视觉论坛账号,购买附件查看下载地址
    Instron DataPlugin for IST22.8.txt (567 Bytes, 下载次数: 0, 售价: 10 元)
    无自述文件,请参考2021 Q4版本:
    NI Instron DataPlugin for IST 2021 Q4 Readme
    October 2021
    This file contains installation instructions and compatibility information for NI Instron DataPlugin for IST 2021 Q4.
    • Instron DataPlugin for IST Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Instron DataPlugin for IST Manuals: New features, behavior changes, and other documentation
    The Instron DataPlugin for IST is a DataPlugin that provides support for IST files in the .acq file extension.
    This DataPlugin supports reading and writing of Instron Structural Testing Systems (IST) formated files. This format is produced by RS LabSite.
    Supported Features (Reading)
    • IST formated files with data compexity 1-3.
    Supported Features (Writing)
    • Saves only the channels of the first channel group.
    • All channels of this channel group are trimmed to the length of the shortest channel.
    • Only numeric channels are saved.
    • Channel property "Data_TYPE" allows switching between writing Float8 or Int4, UInt4, and Int2.
    • Set the channel property "wf_increment" to define the format "SAMPLE INTERVAL" property.
    In the software the DataPlugin name is IST.
    Instron DataPlugin for IST 2021 Q4 supports the following operating systems:
    Note  Instron DataPlugin for IST no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Instron DataPlugin for IST 2021 Q4 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Instron DataPlugin for IST 2021 Q4 to an unsupported OS. Additionally, after installing Instron DataPlugin for IST 2021 Q4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Instron DataPlugin for IST 2021 Q4 supports the application software that support DataPlugins, for example DIAdem, SystemLink and LabVIEW.
    Download the Instron DataPlugin for IST installer from ni.com/dataplugins. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Instron DataPlugin for IST no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2008–2021 National Instruments Corporation. All rights reserved.
    378668a-01
    GMT+8, 2025-7-16 21:20
