查看: 1967|回复: 0
[NI软件产品] NI ECU Test System Maintenance Software 22.1.2 Win11 64bitEng NI ECU测试系统维护软件ECUTSMS22.1.2下载
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2022-11-22 15:45:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    ECU测试系统维护软件
    ECU测试系统维护软件可帮助您执行现场诊断测试并管理ECU测试系统(ECUTS)。
    ECU测试系统维护软件是用于管理ECUTS配置(例如仪器资源和校准信息)的应用软件。该软件还包括现场诊断测试仪(FDT)工具,用于现场的诊断和测试。ECUTS随附了ECU测试系统维护软件。
    ECU测试系统维护软件22.1.2
    发布日期:2022/11/4
    包含的版本:22.1.2完整版
    语言:英文
    文件大小: 1289553920 字节 (1.20 GB)
    修改日期: 2022-11-04 21:49
    MD5: fb22950318b798d048e3f2c58337c5ea
    SHA1: 7fe9456e2d40dd4adbf71d98f189a085e8473b2a
    SHA256: e7b19c257fdfa978cb85e41aaa7dc1c64f28e172addb723ad27f14e42a3d1ca2
    CRC32: d16417b1
    请注册登录视觉论坛账号,购买附件查看下载地址
    ECUTSMS22.1.2.txt (609 Bytes, 下载次数: 0, 售价: 10 圆)
    ECU Test System Maintenance Software 22.1 Readme
    July 2022
    This file contains important information about getting started with the ECU Test System Maintenance Software 22.1, including system requirements and installation instructions.
    • ECU Test System Maintenance Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Use the ECU Test System Maintenance Software to interactively test ECU Test System (ECUTS) hardware components. Launch the ECU Test System Maintenance Software from the Test System Maintenance Software desktop shortcut.
    The ECU Test System Maintenance Software has the following requirements:
    • Pentium 4 G1 (or equivalent) or later 64-bit (x64) processor
    • 2 GB of disk space
    • 4 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 pixels screen resolution
    • 64-bit version of Windows 10 (version 1809)
    The ECU Test System Maintenance Software uses the LabVIEW 2019 Run-Time Engine.
    The ECUTS is delivered with the ECU Test System Maintenance Software installed. The delivered installed version is the most recent version available when the configuration was first manufactured.
    If you need to upgrade or downgrade the ECU Test System Maintenance Software yourself, you can do so by upgrading or downgrading the ECU Test System Software Suite. You can download the ECU Test System Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Refer to the Test System Maintenance Software Help, accessible via the Help button in the ECU Test System Maintenance Software, for information about the ECU Test System Maintenance Software.
    © 2020–2022 National Instruments Corporation. All rights reserved.
    • Additional Test System Maintenance Software licenses are located in the \Test System Maintenance directory.
    GMT+8, 2026-4-1 11:07
