查看: 1225|回复: 0
[NI软件套件] NI Battery Test System Software 2022 Q2 Pacth 1 x64Win10 64bitEng 电池测试系统软件套件BTSS22.0.1
    7 小时前
  • 签到天数: 3556 天
     楼主| 发表于 2022-11-22 11:50:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    电池测试系统软件可帮助您使用电池测试系统硬件创建和执行测试。
    电池测试系统软件是一款应用程序软件,其可用于创建用于电池测试的软件架构并优化电池测试工作流程。该软件包括针对电池测试应用程序的附加软件、设备驱动程序、示例和分析IP,可与电池测试系统硬件配合使用。此外,该电池测试系统软件还包括TestStand和VeriStand软件。
    NI Battery Test System Software 2022 Q2 Patch 1
    发布日期:2022/9/5
    包含的版本:22.0.1完整版
    文件大小: 13956468736 字节 (13.00 GB)
    修改日期: 2022-09-05 09:53
    MD5: ae03968d386ba19247060d8c88065157
    SHA1: 5230e7199b3cd44a6c368bfb3b0a35727d13439f
    SHA256: 4762fbdc0327b9528eb12e4b22415db65987b6c2a1a4586ea4eeed0e055d73d9
    CRC32: 5f8486d6
    请注册登录视觉论坛账号,购买附件查看下载地址
    BTSS22.0.1.txt (664 Bytes, 下载次数: 0, 售价: 30 元)
    Battery Test System Software 2022 Q2 Patch 1 Readme
    August 2022
    This file contains important information about Battery Test System Software 2022 Q2 Patch 1.
    Refer to the Battery Test System Software Release Notes for additional information about this release, such as known issues and bugs fixed since the last release.
    Included Components
    Battery Test System Software is a collection of NI software for developing, executing, debugging, and deploying test programs to an NI Linux Real-Time CompactRIO target in the Battery Test System measurement rack.
    Battery Test System Software 2022 Q2 Patch 1 includes the following new feature:
    • Added support for the Battery Test System Software Toolkit 2022 Q2 Patch 1
    Included Components
    Battery Test System Software 2022 Q2 Patch 1 includes the following major components:
    • Required Components:
      • TestStand 2021 (64-bit)
      • VeriStand 2021
      • Battery Test System Software Toolkit 2022 Q2 Patch 1
        • SystemLink Client 2022 Q1 Patch 2
        • NI SystemLink Test Monitor Support for TestStand 2021 (64-bit)
      • NI-DAQmx 21.3.0
      • NI CompactRIO 21.0.0
      • NI Industrial Communications for EtherCAT 21.5.0
      • NI-VISA 21.5.0
      • NI-XNET 21.5.0
      • NI-SLSC 21.3.0
      • NI R Series Multifunction RIO 21.5.0
      • NI GPIB-Serial Converter 19.0.0
    • Optional Components:
      • LabVIEW 2021 SP1 (64-bit)
      • NI-Sync 21.3
    • LabVIEW is not included in the Battery Test System Software license.
    • You must have a dedicated SystemLink server. Refer to the Battery Test System User Manual for more information.
    • Several VeriStand Custom Devices are also installed with the Battery Test System Software Toolkit. Refer to the Battery Test System Software Toolkit Readme for more information.
    Battery Test System Software supports Windows 10 (64-bit).
    Download the Battery Test System Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Use the serial number that is listed on the Certificate of Ownership that shipped with your system to activate VeriStand, TestStand, NI-VCOM, and the Battery Test System Software Toolkit.
    • For more information on Battery Test System Software activation, refer to Activating a Product.
    • You can also install the Battery Test System Software Toolkit separately from ni.com/downloads. You can deselect items for installation, however the default selected items are required to use the Battery Test System Software Toolkit. If you do not currently have a license for VeriStand and TestStand, NI recommends that you use the default installation process using the evaluation period to obtain the appropriate license.
    • Refer to the Battery Test System User Manual for more information about installing and configuring your software.
    Refer to the following documents to learn more about the Battery Test System, Battery Test System Software, Battery Test System Server Software, and measurement rack. You can find this documentation on your host computer at: %Public%\Documents\National Instruments\Battery Test System\Documentation.
    Document
    Description
    Battery Test System User ManualContains primary help information for the Battery Test System, including:
    • Site preparation and uncrating instructions
    • Hardware reference information
    • Maintenance and service procedures
    • Battery Test System software setup, configuration, and usage
    BTS-16101 Battery Test System Measurement Rack SpecificationsLists the technical specifications for the Battery Test System.
    BTS-16101 Battery Test System Measurement Rack Safety, Environmental, and Regulatory InformationDetails important compliance precautions and connection information for your measurement rack.
    Battery Test System Software Toolkit ReadmeProvides installation instructions, system requirements, and other information for the Battery Test System Software Toolkit.
    Battery Test System Server Software ReadmeProvides installation instructions, system requirements, and other information for Battery Test System Server Software.
    © 2020–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-6-3 15:26
