查看: 1154|回复: 0
[NI软件产品] NI Battery Test System Server Software 2022 Q4 Win11 64bitEng 电池测试系统服务器软件BTSSS22.1.0
    昨天 10:01
  • 签到天数: 3599 天
    连续签到: 7 天
     楼主| 发表于 2022-11-22 11:12:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    电池测试系统服务器软件可帮助您控制电池测试环境(包括Web UI)的功能。
    电池测试系统服务器软件是一个软件附加软件,可作为电池测试系统软件的必需组件,其可用于创建电池测试的软件架构并优化电池测试工作流程。该附加软件包括电池测试系统Web UI以及电池测试系统的自定义UI开发平台。
    发布日期:2022/10/11
    包含的版本:22.1.0完整版
    文件大小: 770037760 字节 (734.37 MB)
    修改日期: 2022-10-11 21:48
    MD5: 65d3bf39ad80befa9f2672df400cb608
    SHA1: f29f5cdc91ebe50bfab238452195196d230ba54b
    SHA256: 06a4961de0054034e2e047b6d2a34b90be4018d80f15963171a2480520dcceab
    CRC32: e289093e
    请注册登录视觉论坛账号,购买附件查看下载地址
    BTSSS22.1.0.txt (621 Bytes, 下载次数: 0, 售价: 10 元)
    Battery Test System Server Software 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for Battery Test System Server Software 2022 Q4.
    Refer to the Battery Test System Server Software Release Notes for additional information about this release, such as known issues and bugs fixed since the last release.
    Included Components
    Battery Test System Server Software controls the functionality of your Battery Test System environment and is necessary to use Battery Test System Software. Battery Test System Server Software includes the Battery Test System Web UI, a custom UI development platform for the Battery Test System.
    Battery Test System Software Server 2022 Q4 includes the following new features:
    • Added publishing DUT port channels as SystemLink tags
    • Added Web UI performance improvements for large channel-count systems
    • Added ability for common files to be shared across multiple Test Station and DUT packages
    • Added attaching the socket number and test sequence name as metadata to the data log files
    • Added ability to specify a custom name to be displayed for test parameters in the Web UI
    • Added reconnecting from the Web UI to a running test
    Included Components
    Battery Test System Server Software 2022 Q4 includes the following major components:
    • Battery Test System Web Server
    • Battery Test System Web UI Example Plug-Ins
    • Battery Test System System Definition Web API
    • Battery Test System Compiler Plug-Ins
    • NI SystemLink Client 2022 Q1 Patch 2
    Note  You must have a dedicated SystemLink server. Refer to the Battery Test System User Manual for more information.
    Battery Test System Server Software 2022 Q4 has the following minimum system requirements:
    Server Requirements
    OS (64-bit only)
    Windows Server 2019
    Windows 10
    Processor
    8-core recommended or higher
    RAM
    32 GB minimum
    64+ GB recommended
    Disk
    16+ GB recommended
    Target Requirements (Managed Nodes)
    OS
    Windows 10 (64-bit) or higher
    Processor
    Pentium 4 G1 (or equivalent) or later
    RAM
    2 GB minimum
    4 GB recommended
    Disk
    1 GB minimum
    2+ GB recommended
    Additional Requirements for Servers and Targets
    • Latest version of one of the following browsers:
      • Chrome
      • Firefox
      • Edge (Chromium)
    Note  Battery Test System Server Software 2022 Q4 does not support Microsoft Edge Legacy versions (version 44 and below).
    Note  For more information about the changes to our OS support, visit https://www.ni.com/r/win32bitsupport.
    Download the Battery Test System Server Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  Refer to the Battery Test System User Manual for more information about installing and configuring your software.
    Refer to the following documents to learn more about the Battery Test System, Battery Test System Software, Battery Test System Server Software, and measurement rack. You can find this documentation on your host computer at: %Public%\Documents\National Instruments\Battery Test System\Documentation.
    Document
    Description
    Battery Test System User ManualContains primary help information for the Battery Test System, including:
    • Site preparation and uncrating instructions
    • Hardware reference information
    • Maintenance and service procedures
    • Battery Test System software setup, configuration, and usage
    Battery Test System Software Toolkit ReadmeProvides installation instructions, system requirements, and other information for the Battery Test System Software Toolkit.
    Battery Test System Software ReadmeProvides installation instructions, system requirements, and other information for Battery Test System Software.
    © 2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-21 07:49
