查看: 1782|回复: 0
[NI驱动程序] NI-VISA 2022 Q4 Driver Mac64Eng 美国国家仪器虚拟仪器软件架构NI-VISA22.8 MAC系统驱动下载
    昨天 14:24
  • 签到天数: 3584 天
    连续签到: 4 天
     楼主| 发表于 2022-11-21 17:35:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA 2022 Q4
    发布日期:2022/10/10
    包含的版本:22.8.0
    受支持的操作系统:Mac OS
    Full完整版:
    文件大小: 61468213 字节 (58.62 MB)
    修改日期: 2021-07-20 22:31
    MD5: 9e712490fb29da06a1b821213717d487
    SHA1: c1db3d75590e2a01cb44c6e87835db3c1d4238c7
    SHA256: e8b0f83aad2a69d292bc2b971a253b129209e697d4b47a31f77fa94ffddee16b
    CRC32: 9fc8721e
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-VISA 2022Q4 MAC Full.txt (503 Bytes, 下载次数: 0, 售价: 10 元)
    RTE运行版:
    文件大小: 5813427 字节 (5.54 MB)
    修改日期: 2022-10-07 09:49
    MD5: b46e0a1c22bf3e3320def7af46c95752
    SHA1: 1d6fbe630df1ee021f3eb713d9faf9a1f13eb96f
    SHA256: 789dd282c3f71d535bb25832b7a8839086a4ab5f6565d2ed236e1f5c7b506eb8
    CRC32: f8262a95
    NI-VISA 2022Q4 MAC RTE.txt (533 Bytes, 下载次数: 0, 售价: 5 元)
    NI-VISA 2022 Q4 for macOS Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-VISA 2022 Q4 for macOS.
    • NI-VISA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-VISA Documentation: New features, behavior changes, and other documentation
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising VXI, Serial, Ethernet, and/or USB interfaces.
    NI-VISA 2022 Q4 for macOS supports the following platforms:
    • macOS 12.3
    • macOS 11.6
    Note  The online version of this readme supersedes the readme provided with the installation media to contain an updated list of supported macOS platforms.
    NI-VISA for macOS currently supports the following resource types and utilities:
    • Serial
    • TCPIP
    • Remote Client
    • Remote Server
    • ENET Serial
    • USB
    • VISA Interactive Control
    • NI I/O Trace
    Note  NI-VISA for macOS supports only 64-bit applications.
    Note  NI-VISA for macOS no longer supports GPIB and PCI/PXI passports.
    The following table lists the NI application software versions supported by NI-VISA:
    Versions Supported by NI-VISA
    NI LabVIEW2019 and later
    You must perform a clean install (uninstall any previous installed versions of NI-VISA) on systems using macOS 11 and later before installing NI-VISA 2022 Q4. Upgrading from previous versions of NI-VISA on systems using macOS 11 and later to the latest version of NI-VISA will result in a system crash.
    The "NI-VISA Support for LabVIEW" package supports applications using NI-VISA ​with LabVIEW 2022 or later. When installing NI-VISA, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    LVAddons directory location: /Library/Application Support/National Instruments/LVAddons
    Installed Files and Paths
    There are three main locations where NI-VISA installs files.
    • The local /Library/Frameworks folder contains the VISA.framework folder. This folder contains all needed headers and supporting Passport libraries that NI-VISA uses.
    • In the local /Applications/National Instruments folder, there is an NI-VISA folder. This folder includes the NI-VISA Help, as well as several groups of C examples using NI-VISA. This NI-VISA folder also includes a graphical utility called NI-VISA Configuration to configure VISA options and the VISA Interactive Control (VISAIC).
    • Finally, the /Library/Preferences folder contains an NIvisa folder with .ini files. These files are used for NI-VISA settings and status codes.
    New FeaturesNI-VISA 2022 Q4
    Added support for M1 processors.
    NI-VISA 15.0
    Added support for NI MAX.
    NI-VISA 14.0
    Added support for 64-bit versions of LabVIEW.
    Added support for the System Configuration API.
    Added support for viGpibControlREN on TCPIP resources that use the VXI-11 protocol.
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    © 1995–2022 National Instruments Corporation. All rights reserved.
    Third-Party Legal Notices
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    举报
    GMT+8, 2025-7-5 02:42
