查看: 1165|回复: 0
[NI驱动程序] NI-SWITCH 2022 Q4 Win11 32/64bitEng/Jpn NI开关产品驱动程序22.8下载
    3 小时前
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2022-11-21 16:28:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    NI-SWITCH 2022 Q4
    发布日期:2022/10/12
    包含的版本:22.8.0完整版
    语言:英语,日语
    校验和
    文件大小: 2715561984 字节 (2.53 GB)
    修改日期: 2021-10-23 05:48
    MD5: b2e940fe0681fc36ef7401564e49c19b(官方正确)
    SHA1: ef89f54ce7c16357dea29100960779b6bd288212
    SHA256: 87736aaedfbc63331f252f2fa2fc7f8a5b2dd904ce8204c063fa20a65b61fdea
    CRC32: 166865be
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-SWITCH 2022Q4.txt (522 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SWITCH 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-SWITCH 2022 Q4.
    • NI-SWITCH Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SWITCH Documentation: New features, behavior changes, and other documentation
    NI-SWITCH is an NI instrument driver that you can use to control and configure NI switches. NI-SWITCH is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the switch module and includes an interactive soft front panel and examples.
    NI-SWITCH 2022 Q4 has the following requirements:
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    NI-SWITCH 2022 Q4 supports the following operating systems:
    • NI Linux® Real-Time
    Note  NI-SWITCH no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    NI-SWITCH 2022 Q4 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-SWITCH 2022 Q4
    LabVIEW2019 and later
    LabVIEW Real-Time Module 32-bit2019 and later
    LabVIEW Real-Time Module 64-bit2021 and later
    LabWindows™/CVI™ Real-Time Module2019 and later
    If you are using the NI-SWITCH .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-SWITCH 2022 Q4 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the NI-SWITCH installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    When installing NI-SWITCH, the "NI-SWITCH Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using NI-SWITCH with LabVIEW 2022 or later.
    NI-SWITCH no longer installs IVI Compliance Package (ICP). NI-SWITCH supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    • Added support for LabVIEW 2022 Q3
    The following list details the hardware models supported in NI-SWITCH 2022 Q4.
    Matrix Module for SwitchBlock
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    PXI Carrier Module for SwitchBlock
    • PXI-2800
    PXI Matrix Switch Module
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    PXI Multiplexer Switch Modules
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    PXI Programmable Resistor Module
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    PXI Relay Driver Module
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    PXI RF Matrix Switch Module
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    PXI RF Multiplexer Switch Module
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    PXI Signal Insertion Switch Module
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    PXI Transfer Switch Modules
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    Refer to the NI-SWITCH documentation, accessible from Start»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about the NI-SWITCH.
    You can access all the installed NI-SWITCH examples at Start»National Instruments»NI-SWITCH»NI-SWITCH Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the labview\examples\XXX directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all NI-SWITCH examples.
    NI-SWITCH no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 1998–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-31 13:53
