查看: 1237|回复: 0
[NI驱动程序] NI RMX-412x Power Supply Driver 2022 Q4 Win11 32bitEng NI RMX-412x可编程电源设备驱动程序22.8版下载 G语言
    3 小时前
  • 签到天数: 3533 天
    连续签到: 3 天
     楼主| 发表于 2022-11-21 14:48:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RMX-412x Power Supply Driver为RMX-412x设备提供支持。
    RMX-412x Power Supply Driver是一款驱动软件,可以与RMX-412x系列可编程电源设备搭配使用。该驱动程序可支持通过将可编程仪器标准命令(SCPI)抽象化来简化常见任务的编程。RMX-412x Power Supply Driver还随附多个示例。
    发布日期:2022/10/12
    编程语言:G语言
    包含的版本:22.8.0完整版
    文件大小: 660463616 字节 (629.87 MB)
    修改日期: 2022-10-13 09:54
    MD5: 3e41b530ffee0bee0e57e36da0bbb98e
    SHA1: 138bffb1620cd8f9446161fb84dc0089b6fb6a01
    SHA256: ce4e226eb58d8a8cde3b6e58d36bee427314678d3a53aa7f26d15d6f067e2dc6
    CRC32: 15885cf5
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-RMX-412x Power Supply Driver 2022Q4.txt (561 Bytes, 下载次数: 0, 售价: 10 元)
    RMX-412x Power Supply Driver 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for RMX-412x Power Supply Driver 2022 Q4.
    • RMX-412x Power Supply Driver Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RMX-412x Power Supply Driver Documentation: New features, behavior changes, and other documentation
    The RMX Power Supply Driver provides support for programming Programmable Power Supply Devices.
    The RMX Power Supply Driver is a plug-and-play NI instrument driver that helps you use LabVIEW to operate Programmable Power Supply Devices. With the RMX Power Supply Driver, you can configure your output power session, program and monitor voltage and current levels, and set up master-slave configurations for multidevice operation.
    Note The RMX-412x LabVIEW Plug-and-Play Instrument Driver does not support using the instrument with a GPIB interface. The interfaces supported are Ethernet, USB, and Serial.
    RMX-412x Power Supply Driver 2022 Q4 supports the following operating systems:
    Note  RMX-412x Power Supply Driver no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RMX-412x Power Supply Driver 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by RMX-412x Power Supply Driver 2022 Q4
    LabVIEW2022
    Download the RMX-412x LabVIEW Plug-and-Play Instrument Driver installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "RMX-412x Power Supply Driver Support for LabVIEW" package supports applications using RMX-412x Power Supply Driver ​with LabVIEW 2022 or later. When installing RMX-412x Power Supply Driver, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    RMX-412x Power Supply Driver 2022 Q4 includes the following new features:
    • Added support for LabVIEW 2022
    Refer to the RMX-412x Power Supply Driver documentation, accessible from Start»National Instruments»RMX-412x Power Supply Driver Documentation, for information about the RMX-412x Power Supply Driver.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the RMX-412x LabVIEW Plug-and-Play Instrument Driver are located in the LabVIEW\instr.lib\NI RMX-412x Power Supplies\Examples directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW OPC UA Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-8 03:18
