查看: 1191|回复: 0
[NI驱动程序] NI RMX-400x Electronic Load Driver for LabVIEW 2022 Q4 Win11 64bitEng NI RMX-410x电子负载设备LabVIEW驱动22.8
    昨天 00:13
  • 签到天数: 3533 天
    连续签到: 3 天
     楼主| 发表于 2022-11-21 12:00:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RMX-400x Electronic Load Driver for LabVIEW为电子负载设备提供LabVIEW支持。
    RMX-400x Electronic Load Driver for LabVIEW是一款驱动软件,可以与RMX-400x系列电子负载设备搭配使用。该软件提供LabVIEW支持,通过将可编程仪器标准命令(SCPI)抽象化来简化常见任务的编程。
    发布日期:2022/10/12
    包含的版本:22.8完整版
    语言:英语
    文件大小: 665968640 字节 (635.12 MB)
    修改日期: 2022-10-13 09:54
    MD5: 843ee11a8111b2f520f68af3db7376ba
    SHA1: d9066936e7b8e8fadf2f862c3e6b7643f94f9f68
    SHA256: 5e2f26bcd795bd85b6232a73739650acc5a5e67ca5e9000ba5c86d9380401ff9
    CRC32: ce8f43d1
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-RMX-400x Electronic Load Driver for LabVIEW 2022Q4.txt (564 Bytes, 下载次数: 0, 售价: 10 元)
    RMX-400x Electronic Load Driver 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for RMX-400x Electronic Load Driver 2022 Q4.
    • RMX-400x Electronic Load Driver Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RMX-400x Electronic Load Driver Documentation: New features, behavior changes, and other documentation
    The RMX-400x Electronic Load Driver for LabVIEW provides LabVIEW support for Electronic Load Devices.The RMX-400x Electronic Load Driver for LabVIEW is driver software that you can use to work with the RMX-400x models of Electronic Load Devices. The software provides LabVIEW support to help you simplify the programming of common tasks with the abstraction of Standard Commands for Programmable Instruments (SCPI).
    RMX-400x Electronic Load Driver 2022 Q4 supports the following operating systems:
    Note  RMX-400x Electronic Load Driver 2022 Q4 no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RMX-400x Electronic Load Driver 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by RMX-400x Electronic Load Driver 2022 Q4
    LabVIEW2022
    Download the RMX-400x Electronic Load Driver 2022 Q4 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "RMX-400x Electronic Load Driver Support for LabVIEW" package supports applications using RMX-400x Electronic Load Driver ​with LabVIEW 2022 or later. When installing RMX-400x Electronic Load Driver, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    RMX-400x Electronic Load Driver 2022 Q4 includes the following new features:
    • Added support for LabVIEW 2022
    Refer to the RMX-400x Electronic Load Driver documentation, accessible from Start»National Instruments»RMX-400x Electronic Load Driver Documentation, for information about the RMX-400x Electronic Load Driver.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the RMX-400x Electronic Load Driver are located in the LabVIEW\instr.lib\NI RMX-400x Electronic Load\Examples directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW OPC UA Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-9 01:24
