查看: 1051|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2022 Q4 Win11 32/64bitEng NI-RFSG回放库22.8
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2022-11-21 11:33:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    32/64位完整版校验和:
    文件大小: 477169664 字节 (455.06 MB)
    修改日期: 2022-10-13 09:54
    MD5: f4d7ed3bc9e99ce35a9984eaea6f8717
    SHA1: a852953771cd8014c0a494c3601409b5afd8ae07
    SHA256: 5368ea1b07d0718316935f2994aa3ba19076fb9f07b2e32a3bc7798ad2e09ea1
    CRC32: 3657906f
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSG Playback Library 2022Q4 Full.txt (594 Bytes, 下载次数: 0, 售价: 10 元)
    32/64位运行版校验和:
    文件大小: 383653888 字节 (365.88 MB)
    MD5: 8591ef68136e3431425b987b11c55f33
    SHA1: 95b986d3d95842af7a96379c5b7b57d9f6f63621
    SHA256: a6315946ff454c5cf9ec5946720e1d07f7d8c680358235142b53107d00428ec4
    CRC32: 56679fb2
    NI-RFSG Playback Library 2022Q4 RTE.txt (600 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFSG Playback Library 2022 Q4 Readme
    October 2022
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    Installed Software
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library 21.3 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2022 Q4 supports the following 64-bit operating systems:
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library (64-bit only)
    LabVIEW2019 SP1, 2020 SP1, 2021, 2022 Q3
    Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library Documentation.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-10 09:14
