查看: 1880|回复: 0
[NI软件产品] LabVIEW 2022 Q3 FPGA Module Xilinx Compilation Tools Linux64Eng LV2022Q3 FPGA编译工具(Vivado 2021.1)
     楼主| 发表于 2022-11-15 12:01:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2022 Q3 FPGA Compilation Tool for Vivado 2021.1
    发布日期
    22-10-10
    受支持的操作系统
    Linux
    CentOS 7.4
    CentOS 7.5
    CentOS 7.6
    Red Hat Enterprise Linux 7.4
    Red Hat Enterprise Linux 7.5
    Red Hat Enterprise Linux 7.6
    语言
    English
    校验和
    文件大小: 28545875968 字节 (26.59 GB)
    修改日期: 2022-09-27 09:48
    MD5: fa40c4204ec32d33f654cf64be3cd7e3
    SHA1: 722e9b328df65c9336a8f3d0b608dae7a2bde18e
    SHA256: 3e4c84b02a0e052172ee1a3208d4638d501d18fe21d7fa120e1c1204c35d0bff
    CRC32: 63afe009
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    LV FPGA Compilation Tools2022Q3.txt (577 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2020 FPGA Module Xilinx Compilation Tools for Linux Readme
    March 2020
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2019.1 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2019.1 has the following system requirements:
      • Red Hat Enterprise Linux 7.4/7.5/7.6 (64-bit)
      • CentOS 7.4/7.5/7.6 (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    • Red Hat Enterprise Linux 6.5 (64-bit)
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Use the Xilinx Compilation Tool for Vivado 2019.1 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/905x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-576x/577x/5785/6593/782xR/7846/7856/7857/7858/798x
    • PXIe-5163R/5164R/517xR/5624R/5745/576x/577x/5785/5840R/659x/782xR/784x/785x/786x/786xR/7902R/791x/793xR/797xR/798x/799x
    • roboRIO
    • sbRIO-9603/9608/9609/9628/9629/9638/9651/96x7
    • USB-784xR/785xR
    • USRP-RIO devices
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • IC-312x
    • NI-915x
    • NI CVS-145x/145xRT
    • PCIe-7841R/7842R/7851R/7852R/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • If the media type is DVD, change the current directory to the mount point.
      If the media type is USB, change the current directory to mount point/Linux/Vivado2019_1 or mount point/Linux/ISE14_7, depending on which tool you want to install.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2020 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740L-01
    GMT+8, 2026-1-13 07:55
