查看: 1651|回复: 0
[NI软件套件] NI ECU Test System Software Suite 22.1.2 x64Win10 64bitEng NI电子控制单元ECU测试系统软件套件ECUTS22.1.2
    昨天 16:26
  • 签到天数: 3674 天
     楼主| 发表于 2022-11-14 11:28:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    ECU测试系统软件套件
    ECU测试系统套件包含了一套与ECU测试系统(ECUTS)搭配使用的软件。
    ECU测试系统套件是一个软件套件,提供与ECUTS一起使用以测试汽车电子控制单元(ECU)所需的应用软件。该软件套件包括TestStand、Switch Executive、Instrument Studio、LabVIEW基本版、ECU测试系统维护软件、TestStand仪器抽象框架和所有必要的硬件驱动。
    发布日期
    2022/11/6
    包含的版本
    22.1.2完整版
    受支持的操作系统
    语言
    English
    程序位数
    64位
    校验和
    文件大小: 14400311296 字节 (13.41 GB)
    修改日期: 2022-11-06 09:49
    MD5: da30233553042f398bacb2e34dcf8f11(官方一致)
    SHA1: 884b692c93d4f3374962921f4179447f68d2c9b7
    SHA256: a3480c27d0dd66bba584a7b920778730311b4d874f82d6291139c011a0079339
    CRC32: 1425efaa
    注册登录视觉论坛账号,购买附件查看下载地址
    ECUTS22.1.2.txt (647 Bytes, 下载次数: 0, 售价: 25 圆)
    ECU Test System Software Suite 22.1 Readme
    November 2022
    This file contains important information about the ECU Test System Software Suite 22.1, including installation instructions. The ECU Test System Software Suite is a collection of NI software for developing, executing, debugging, and deploying test programs on the ECU Test System (ECUTS).
    • ECU Test System Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Included Components
    New Features and Behavior Changes
    Included Components
    The ECU Test System Software Suite includes the following major components:
    • ECU Test System Maintenance Software 22.1
    • InstrumentStudio 2022 Q4
    • IVI Compliance Package 22.5
    • LabVIEW 2021 SP1 (64-bit)
    • TestStand 2021 SP1 (64-bit)
    • TestStand ECU Software Toolkit 22.1
    • NI Switch Executive 2021
    • NI System Link Client 2022 Q4
    • NI-488.2 22.8
    • NI-DAQmx 22.8
    • NI-DCPower 22.8
    • NI-DMM 22.5
    • NI-FGEN 21.8
    • NI PXI Platform Services 22.8
    • NI-SCOPE 22.5
    • NI-Serial 21.5
    • NI-SLSC 22.8
    • NI-SWITCH 22.8
    • NI-VISA 22.5
    • NI-XNET 22.5
    • RMX-410x Power Supply Driver for IVI-C 1.4
    • Keysight AGN6700 Driver 3.5.1
    The ECUTS is delivered with the ECU Test System Software Suite 22.1 installed. If you need to install the ECU Test System Software Suite yourself, download the installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the ECU Test System Software Suite. For more information on activating the ECU Test System Software Suite, refer to NI Software Activation.
    If you are using NI .NET Class Libraries, .NET Framework 4.0 (minimum) is required. The NI .NET Class Libraries can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Refer to the readme for each component of the ECU Test System Software Suite for more information about new features and behavior changes in the ECU Test System Software Suite 22.1.
    You can access installed ECUTS documentation from the ECUTS Documents shortcut on the desktop, from the %Public%\Documents\National Instruments\ECU Test System\Documentation directory, or online at ni.com/docs. ECUTS Safety, Environmental, and Regulatory Information sheets are only accessible online at ni.com/docs. The documentation set is composed of the following documents:
    Installed Documentation
    Description
    ECUTS-16000 SpecificationsLists the technical specifications for your system.
    ECUTS-16001 Specifications
    ECUTS-16000 User ManualContains primary help content for your system, including:
    • An overview of supported hardware and software
    • Site preparation and bring up information
    • Basic procedures
    • Maintenance and repair information
    ECUTS-16001 User Manual
    TestStand ECU Software Toolkit Help   Explains the functionality the TestStand ECU Software Toolkit adds to TestStand.
    Configuration-Specific ReferenceContains unique information related to the configuration for an ECUTS
    tester. This information is also included in the initial quote for
    an ECU Test System.
    Online Documentation
    Description
    ECUTS-16000 Safety, Environmental, and Regulatory
    Information
    Lists the safety requirements for your system.
    ECUTS-16001 Safety, Environmental, and Regulatory
    Information
    FDT-16041 Safety, Environmental, and Regulatory
    Information
    Lists the safety requirements for the FDT-16041 field diagnostic
    tester.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/docs.
    Note   To view PDFs, you need to have a PDF viewer such as Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
    © 2020–2022 National Instruments Corporation. All rights reserved.
    For patents covering the NI products/technology, refer to the NI Patent Notice at ni.com/patents.
    GMT+8, 2025-10-8 00:15
