查看: 1585|回复: 0
[NI驱动程序] NI PXI Firmware and Additional Drivers 19.0 Win32/64Eng PXIe-8398固件及其他驱动19.0
    昨天 09:38
  • 签到天数: 3535 天
     楼主| 发表于 2022-8-23 17:33:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    PXIe-8398固件及其他驱动
    PXIe-8398固件及其他驱动支持PXIe-8398 PXI远程控制模块。
    PXIe-8398固件及其他驱动包括PXIe-8398 PXI远程控制模块的固件。该固件可帮助您设置和控制PXIe-8398的运行方式。
    发布日期:2019/1/14
    包含的版本:2019完整版,版本号19.0
    语言:德语,日语,英文
    文件大小: 271243 字节 (264.89 KB)
    修改日期: 2022-07-12 09:47
    MD5: 8cabc3f96cdbc4f3e64125fd9737334a
    SHA1: e4e98c34c0b350070bacc51901d994a6cd6901d4
    SHA256: 08b1a3bbbe1c225cb1454eb7e107a733cc1dc27d4aedcfe4b7d9964c0184594c
    CRC32: 9e621117
    请注册登录视觉论坛账号,购买附件查看下载地址
    PXIe-8398固件及其他驱动19.0.txt (527 Bytes, 下载次数: 0, 售价: 10 元)
    National Instruments MXI Express Firmware Update
    © 2013 National Instruments Corporation. All rights reserved.
    This file contains instructions on how to update a National Instruments PXI Express Remote Controller.
    This readme contains the following main sections:
    • Supported Hardware
    • Software Requirements
    • Upgrade Instructions - LVRT 2010 SP1
    • Upgrade Instructions - General
    • Contacting National Instruments
    • Patent Information
    The following National Instruments PXI Express Remote Controller currently support firmware update:
    • NI PXIe-8360
    • NI PXIe-8370
    • NI PXIe-8375
    • NI PXIe-8381
    • NI PXIe-8388
    • NI PXIe-8389
    Updating the firmware on your MXI Express hardware requires:
    • PXI Platform Services 3.2.1 (or later)
    • Supported Operating Systems
      • Windows XP (x32), Vista (x32/x64), 7 (x32/x64), or 8 (x32/x64)
      • LVRT 2010 SP1, LVRT 2011 SP1, LVRT 2012 SP1
    Upgrade Instructions for LVRT 2010 SP1 Systems
    Follow the instructions below to update your National Instruments PXI Express Remote Controller(s):
    • Download and save firmware image and "PXI Platform Services Firmware Updater.vi" to the host machine.
    • On the system, open the "PXI Platform Services Firmware Updater.vi" VI in LabVIEW.
    • Click the Run arrow.
    • Select the target system where the device to be updated is located.
      • localhost is the local system that is running the VI
      • From the drop down menu you can select a Remote Target that has been identified in MAX.
      • Or you can manually type in the Remote Target IP Address in the box.
    • Navigate to and select the firmware image file saved in step 1, click the OK button.
    • After a few moments, a dialog box should appear:
      • If the box states "X device(s) updated successfully.", power cycle the remote controller(s) by following the additional instructions in the output box.
      • If the box states that an issue occurred, record the error number/message and Contact National Instruments.
    • Click the Exit button.
    Upgrade Instructions for Other Operating Systems
    • Download and save firmware image to the system containing the remote controller(s) to be updated. If the system containing the remote controller is running LabVIEW RT, save the firmware image onto the host machine.
    • On the system, use Measurement & Automation Explorer to navigate to the NI Web-Based Monitoring and Configuration page.
      • For Windows systems: Right click My System and select Web Configuration.
      • For RT systems: Expand Remote Systems. Locate and right-click the target system and select Web Configuration.
    • Each controller must be updated separately. For each controller to be updated:
      • Locate and expand the chassis containing the remote controller to be updated.
      • Select the remote controller in the left most pane, then click the Update Firmware button in the right pane.
      • Navigate to and select the firmware image file saved in step 1, then click the Open button.
        • A dialog box should open containing information about the firmware image selected.
      • Confirm the version number displayed is as you expected.
        • If the version is as you expected, select the Begin Update button.
        • If the version is not as you expected, select the Cancel button and confirm the download in step 1.
        • If the dialog states "The firmware update completed successfully", power cycle the remote controller by following the additional instructions in the dialog box.
        • If the dialog states that an issue occurred, record the error number/message and Contact National Instruments.
    Thank you for your interest in PXI Platform Services. We appreciate communicating with the people who use our products. We are also very interested in hearing about the applications you develop using our products. Our Web site, ni.com, provides advanced support and services and contact information.
    Patent Information
    GMT+8, 2025-5-11 01:16
