查看: 1651|回复: 0
[NI驱动程序] NI-VRTS 2022 Q3 Driver Win11 32/64位多国语言 NI-VRTS车辆雷达测试系统22.5版驱动下载
    昨天 16:26
  • 签到天数: 3674 天
     楼主| 发表于 2022-8-23 16:58:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-VRTS
    NI-VRTS为客户使用车辆雷达测试系统(VRTS)提供支持。
    NI-VRTS是一款NI仪器驱动程序,可帮助您创建从独立障碍物模拟器到全功能硬件在环(HIL)仿真系统等不同规模的软件应用程序。此驱动程序提供一系列操作、属性和示例,可模拟最多四个障碍物。此外,NI-VRTS可以通过测试辐射方向图、等效同位素辐射功率(EIRP)、噪声、频谱占用率、波束宽度和线性调频分析来帮助您评估雷达设备。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 865779712 字节 (825.67 MB)
    修改日期: 2022-07-23 10:06
    MD5: 767f17f4f5ae52a8ae2b93021114e40b
    SHA1: f2d0d66f688773e357ca73f5868d3de71bb48ce0
    SHA256: 6ce8ef8031241a13d8d8cbdffa1af79f5c6c668d59c6b4b21272bb61a5f19c90
    CRC32: eb0e5c14
    请注册登录视觉论坛账号,购买附件查看下载地址
    VRTS22.5.txt (515 Bytes, 下载次数: 0, 售价: 10 圆)
    2022Q3版暂无自述文件,参考20.0版
    NI-VRTS 20.0 Readme
    March 2021
    This file contains important information about NI-VRTS, including supported hardware, installation instructions, and new features.
    NI-VRTS Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    This software installation provides support for customers using the Vehicle Radar Test System (VRTS) with 4 GHz Bandwidth and VRTS with 1 GHz Bandwidth, as specified in the Supported Hardware section. To program your VRTS, use the NI-VRTS instrument driver.
    The getting started guide for your system provides information about how to install, configure, test, and begin using the VRTS.
    NI-VRTS 20.0 has the following requirements:
    • 4 GB RAM
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or higher recommended)
    NI-VRTS 20.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit the PAE Support page.
    NI-VRTS 20.0 supports the following application software versions, including service packs. You should install LabVIEW before installing NI-VRTS. To add support for application software installed after installing NI-VRTS, modify your NI-VRTS installation or launch the NI-VRTS installer again.
    Versions Supported by NI-VRTS 20.0
    LabVIEW2017, 2018, 2019, 2020
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017, LabVIEW 2018, LabVIEW 2019, and LabVIEW 2020.
    Additional Software
    The following NI drivers are required for VRTS with 1 GHz Bandwidth users. They are optional for VRTS with 4 GHz Bandwidth users.
    • NI-RFSA 20.5 or later
    • NI-RFSG 20.5 or later
    • NI-RFmx SpecAn 20.0 or later
    • NI-RFmx Demod 20.0 or later
    • Uninstall NI-VRTS. This step is necessary to avoid using older code inadvertently.
    • Upgrade LabVIEW.
      • NI-VRTS 20.0 supports LabVIEW 2017-2020.
      • Versions of NI-VRTS earlier than 20.0 only support LabVIEW 2016 or earlier for 1 GHz systems.
    • Install these additional drivers, which are required for 1 GHz systems. These drivers are optional for 4 GHz systems.
    • Download NI-VRTS 20.0.
      • Visit ni.com/downloads.
      • Search for NI-VRTS and click the product name in the search result list to visit the download page.
      • Ensure 20.0 is selected in the Version dropdown.
      • Click Download.
    • Install NI-VRTS 20.0.
    Note  NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-VRTS 20.0 includes the following new features:
    • Improved RCS accuracy when VDG gain is configured below -20 dB
    • Added support for LabVIEW 2017, 2018, 2019, and 2020 in both 1 GHz and 4 GHz systems
    For supported hardware configurations, see the getting started guide for your VRTS. The following hardware models are supported in NI-VRTS 20.0.
    VRTS with 1 GHz Bandwidth:
    • NI-5692 Variable Delay Generator for PXI (VDG)
    • PXIe-5840 Vector Signal Transceiver (VST)
    • mmWave Radio Head
      • mmRH-3608
      • mmRH-3609
    VRTS with 4 GHz Bandwidth:
    • PXIe-5551 Variable Delay Generator for PXI (VDG)
    • mmRH-5591 mmWave Radio Head
    Refer to the NI-VRTS Help, accessible from the Help menu in LabVIEW, for information about the NI-VRTS API, using the system with software, and other resources.
    You can access the NI-VRTS known issues online at NI-VRTS 20.0 Known Issues.
    You can access the NI-VRTS bug fixes online at NI-VRTS 20.0 Bug Fixes. This list describes a subset of issues fixed in the NI-VRTS 20.0. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    NI-VRTS ships with the following examples.
    Examples for the VRTS with 4 GHz Bandwidth can be found at \examples\instr\niVRTS:
    • VRTS Basic Single Object Simulation.vi demonstrates how to simulate an object.
    • VRTS Basic Multiple Object Simulation.vi demonstrates how to simulate multiple objects.
    • VRTS Object Simulation and CHP Measurement.vi demonstrates how to simultaneously simulate an object and perform a measurement.
    • VRTS Object Simulation and Interference.vi demonstrates how to use NI-VRTS with NI-RFSG to simulate an object while injecting a single-tone continuous wave signal as interference.
    Examples for the VRTS with 1 GHz Bandwidth can be found at \user.lib\NI-VRTS\API\Examples:
    • NI-VRTS - Obstacle Simulation.vi demonstrates obstacle simulation.
    • NI-VRTS - Obstacle Simulation and OBW Measurement.vi demonstrates how to simulate obstacles and carry out occupied bandwidth measurement on the RADAR sensor.
    • NI-VRTS - Obstacle Simulation and FM Demod Measurement.vi demonstrates how to simulate obstacles and carry out FM demodulation on the RADAR sensor signal.
    • NI-VRTS - Obstacle Simulation and TxP Measurement.vi demonstrates obstacle simulation and performs a transmit power measurement on the RADAR sensor signal.
    Accessing VIs
    To locate the VIs for your system, navigate to the palette location that corresponds with your system type.
    VRTS System Type
    Palette Location
    VRTS with 1 GHz Bandwidth Functions»User Libraries»niVRTS»API»Host»niVRTS»Public
    VRTS with 4 GHz Bandwidth Functions»Instrument I/O»Instrument Drivers»NI-VRTS
    Note  NI-VRTS VIs used to program the VRTS with 1 GHz Bandwidth are incompatible with the VIs used to program the VRTS with 4 GHz Bandwidth.
    NI-VRTS Drops Support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-VRTS will drop support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2018-2021 National Instruments Corporation. All rights reserved.
    377823G-01
    GMT+8, 2025-10-8 00:13
