查看: 2489|回复: 0
[NI驱动程序] NI-VISA 2022 Q3 Driver Win11 32/64Eng 美国国家仪器虚拟仪器软件架构NI-VISA22.5
     楼主| 发表于 2022-8-23 16:38:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 1232424960 字节 (1.15 GB)
    修改日期: 2022-07-23 10:05
    MD5: ee3be776d09a7e188a86569a77e0bffe
    SHA1: 7bd359435fd615dc3f0f19cd65c538f176631156
    SHA256: 01f2694a61d6768c67765f5c4cd70bb82e87d4eaea548501d741bd47a1b2b649
    CRC32: fc1a04fc
    请注册登录视觉论坛账号,购买附件查看下载地址
    VISA22.5.txt (520 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VISA 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI-VISA 2022 Q3.
    • NI-VISA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-VISA Manuals: New features, behavior changes, and other documentation
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, Serial, Ethernet, and/or USB interfaces.
    Supported Operating Systems and Hardware
    NI-VISA 2022 Q3 supports the following platforms:
    • NI Linux® Real-Time
    While this distribution targets all of these platforms, you can run setup.exe only on the Windows variants.
    Visit NI-VISA and OS Compatibility and NI-VISA Features and OS Compatibility pages to view supported operating systems for different releases and feature support for various operating systems.
    Note    NI-VISA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-VISA 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-VISA 2022 Q3 to an unsupported OS. Additionally, after installing NI-VISA 2022 Q3 on a supported OS computer, you cannot create any installers containing any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio for an unsupported OS computer.
    NI-VISA 2022 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-VISA
    LabVIEW2019 and later
    LabWindows/CVI2019 and later
    Measurement Studio2019 and later
    Microsoft Visual Studio Support for the IVI-Compliant NI-VISA .NET Class Library
    If you are using the IVI-compliant NI-VISA .NET Class Library, the .NET 4.6.2 Framework (minimum) is required. You can use the NI-VISA .NET Class Library with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or later. You can use the NI-VISA .NET Class Library in 32-bit or 64-bit applications.
    Microsoft Visual Studio Support for the VisaNS .NET Class Library
    Note: The Measurement Studio VisaNS .NET Class Library is being deprecated and superseded by an IVI-compliant NI-VISA .NET Class Library. Refer to the New Features section for more information.
    Installation InstructionsInstalling NI-VISA for LabVIEW
    You can install all of your LabVIEW products—including NI-VISA—using the LabVIEW 2019 or later platform media.
    To request additional LabVIEW platform media, visit ni.com/r/media.
    Note
    Before you install NI-VISA 2022 Q3, NI recommends that you uninstall any versions of VISA prior to NI-VISA 2.0.1.
    After uninstalling NI-VISA, some DLLs and executables may remain in the NI-VISA directories. To complete the uninstall process, you must restart your machine.
    Note: The uninstaller application does not notify you when rebooting is necessary. If you plan to reinstall NI-VISA, you always should reboot the machine after running the uninstaller.
    When installing NI-VISA, the "NI-VISA Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using NI-VISA with LabVIEW 2022 or later.
    Agilent/HP Controller Support
    NI-VISA now works with Agilent/HP GPIB and VXI controller cards. To use this feature, go into MAX, select Tools»NI-VISA»VISA Options, choose the Passports tab, and enable the NiVisaTulip.dll Passport. NI-VISA automatically finds and accesses any GPIB or VXI devices. However, NI-VISA does not configure the Agilent/HP hardware; you still must do that with the Agilent/HP I/O Config utility.
    If you have both NI and Agilent/HP controllers in the same system, you must configure the cards at different system addresses, such as GPIB0 and GPIB1. If both vendors try to use the same interface address, NI-VISA reports an error from viFindRsrc or VISA Find Resources.
    Creating and Digitally Signing Catalog Files
    (Windows 10 or higher) If you generate an INF file using the NI-VISA Driver Wizard, you must create and digitally sign a Windows Catalog (.cat) file before you can install the INF file on a Windows 10 (or higher) machine. For more information about digitally signing a .cat file for Windows 10 (or higher), visit ni.com/r/infwin8.
    For more information about creating and signing catalog files, please refer to Creating a Catalog File for Test-Signing a Driver Package.
    New FeaturesNI-VISA 2022 Q3
    Added support for LabVIEW 2022 Q3
    Refer to the NI-VISA Help, accessible from LabVIEW by selecting Help>>LabVIEW Help, for information about NI-VISA.
    Select Help>>Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-VISA are located in the labview\examples\Instrument IO\VISA directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 1995–2022 National Instruments Corporation. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help>>Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    GMT+8, 2026-1-13 11:28
