查看: 1773|回复: 0
[NI驱动程序] NI-SLSC 2022 Q3 Driver Win11 32/64bitEng NI开关负载信号调理设备驱动22.5版下载
    昨天 10:01
  • 签到天数: 3599 天
    连续签到: 7 天
     楼主| 发表于 2022-8-23 15:49:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 1255931904 字节 (1.17 GB)
    修改日期: 2022-07-23 10:00
    MD5: 1ded79341cdf567b7a25957df4fbd1e2
    SHA1: d6d5f3f72c05f558af74508c839077d8686b3318
    SHA256: ed5883ebf3fc387650ac8913482d85dae15e855c3ef8cfc8bb1e1ed4a407f851
    CRC32: c37aa55b
    请注册登录视觉论坛账号,购买附件查看下载地址
    SLSC22.5.txt (520 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SLSC 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI-SLSC 2022 Q3.
    • NI-SLSC Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SLSC Manuals: New features, behavior changes, and other documentation
    NI-SLSC supports the following operating systems:
    • NI Linux® Real-Time
    NI-SLSC 2022 Q3 supports the following application software versions, including service packs.
    Versions Supported by NI-SLSC
    LabVIEW2019, 2020, 2021 and 2022 Q3
    LabVIEW Real-Time Module2019, 2020, 2021 and 2022 Q3
    Download the NI-SLSC installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    NI-SLSC 2022 Q3 has added the following new features:
    • Support for LabVIEW 2022 Q3
    The default device reservation timeout for the SLSC Initialize and SLSC Reserve nodes has been increased to five seconds. This change improves the robustness of device reservation in typical scenarios. Previously, the default reservation timeout value was zero seconds.
    For existing code that does not explicitly wire a reservation timeout, this change could cause the program to stall for up to 5 seconds upon an attempted reservation (a stall will occur only if the device in question is already reserved). If desired, the previous behavior can be restored by explicitly setting the timeout to zero seconds.
    Refer to the NI-SLSC Help, accessible by navigating to the Start»National Instruments»NI-SLSC Documentation, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs.
    NI-SLSC no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2016–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-21 05:18
