查看: 1374|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2022 Q3 Win11 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 22.5
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2022-8-23 12:08:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 3852525568 字节 (3.59 GB)
    修改日期: 2022-07-23 09:50
    MD5: 50c9ab66a741ddd6daaf01e8f7a7fe2d
    SHA1: a47e4983b332bb075ca08d930eff31a6329e0868
    SHA256: fd8de30e4685cf66197bb97dd54b5bdb77e9dd8138c653a5f419f3e44d79895e
    CRC32: 43552018
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFSA22.5.txt (520 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSA 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI-RFSA.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022
    NI-RFSA 21.8 includes the following new feature:
    • Support for NI Linux® Real-Time
    NI-RFSA 21.5 includes the following new feature:
    • Support for RF list mode on PXIe-5840/5841 for LO Source, Downconverter Frequency Offset Mode, and Signal Bandwidth attributes
    NI-RFSA has the following requirements:
    • 4 GB RAM*
    • Windows 10 with all available critical updates and service packs
    NI-RFSA 2022 Q3 and NI-RFSA SFP 2022 Q3 support the following operating systems:
    • NI Linux® Real-Time
    NI-RFSA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for application software installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSA
    LabVIEW2019, 2020, 2021, and 2022
    LabWindows/CVI2018 to current
    LabVIEW Real-Time Module2021 and 2022
    Note  Install any toolkits or add-on software you intend to use with the NI-RFSA instrument driver after NI-RFSA installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation.
    If you are using the NI-RFSA .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. For more information on .NET development using NI .NET drivers, visit ni.com/info and enter Info Code NETAPIdriversupport.
    To install the NI-RFSA .NET Class Library, ensure that you select .NET Framework 4.5 Languages Support or .NET Framework 4.0 Languages Support in the NI-RFSA installer.
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    NI-RFSA VIs are available in LabVIEW from the Functions»Measurement I/O»NI-RFSA palette.
    LabWindows/CVI
    .NET Framework
    You can use the NI-RFSA .NET Class library by adding a reference to NationalInstruments.ModularInstruments.NIRfsa.Fx40 or NationalInstruments.ModularInstruments.NIRfsa.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFSA. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Examples.
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI RF Vector Signal Analyzers HelpHTML/Windows HelpContains primary help content for NI-RFSA products. The help is an HTML version of a traditional user manual that includes the following information:
    • Hardware device overviews
    • The NI-RFSA Soft Front Panel Help
    • A complete reference for all NI-RFSA VIs, properties, and functions, as well as the NI-RFSA .NET Class Library Help
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    举报
    GMT+8, 2025-5-31 11:54
