查看: 3253|回复: 4
[NI驱动程序] NI-Industrial Communications for Ethernet/IP 2022 Q3 Win11 32/64bitEng NI以太网/IP工业通信软件22.5
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2022-8-22 16:31:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 952541184 字节 (908.41 MB)
    修改日期: 2022-07-23 09:54
    MD5: f36a004ffd802c7e193e87192c3e0d16
    SHA1: cc4849fa77c1c649978dd27cba7c5f8436938966
    SHA256: 44dc3618724a063a5aa284935bb137fc948ffd573f3f0fad16deb22263ea3305
    CRC32: 09b000a2
    请注册登录视觉论坛账号,购买附件查看下载地址
    EthernetIP22.5.txt (575 Bytes, 下载次数: 3, 售价: 10 圆)
    NI-Industrial Communications for EtherNet/IP 2022 Q3 Readme
    July 2022
    This file contains new features, installation instructions and compatibility information for NI-Industrial Communications for EtherNet/IP.
    • NI-Industrial Communications for EtherNet/IP Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Industrial Communications for EtherNet/IP Manuals: New features, behavior changes, and other documentation
    Hardware Support
    NI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices.
    In addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements:
    • LabVIEW Base Development System
    • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
    NI-Industrial Communications for EtherNet/IP supports the following operating systems:
    Note   NI-Industrial Communications for EtherNet/IP no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-Industrial Communications for EtherNet/IP 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherNet/IP 2022 Q3 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherNet/IP 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-Industrial Communications for EtherNet/IP
    LabVIEW2019 or later
    LabVIEW Real-Time Module2019 or later
    Hardware Support
    NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
    • CompactRIO
    • Compact Vision System
    • Embedded Vision System
    • Industrial Controllers
    • PXI
    • PXIe
    • Single-Board RIO
    • Smart Cameras
    • Stand-Alone CompactDAQ
    Download the NI-Industrial Communications for EtherNet/IP installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Use NI Measurement & Automation Explorer (MAX) to install NI-Industrial Communications for EtherNet/IP on RT targets.
    When installing NI-Industrial Communications for EtherNet/IP, the "NI-Industrial Communications for EtherNet/IP Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using NI-Industrial Communications for EtherNet/IP with LabVIEW 2022 or later.
    New FeaturesEtherNet/IP 2022 Q3
    • Added support for LabVIEW 2022.
    EtherNet/IP 21.0
    • Added support for LabVIEW 2021.
    • Added support for PXI and PXIe controllers with NI Linux Real-Time through .ipk file installation.
    EtherNet/IP 20.0
    • Added support for LabVIEW 2020.
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory.
    © 2010–2022 National Instruments Corporation. All rights reserved.
  • 签到天数: 2 天
    发表于 2023-11-21 10:32:20 | 显示全部楼层 来自:广东省东莞市 电信
  • 签到天数: 2 天
    发表于 2023-11-21 10:33:44 | 显示全部楼层 来自:广东省东莞市 电信
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2023-11-21 10:38:38 | 显示全部楼层 来自:广东省东莞市 电信
  • 签到天数: 2 天
    发表于 2023-11-21 10:43:31 | 显示全部楼层 来自:广东省东莞市 电信
    GMT+8, 2026-1-14 07:16
