查看: 2840|回复: 0
[NI软件产品] NI VeriStand Custom Devices 2022 Q3 Win11 32/64bitEng NI VeriStand自定义设备22.5
    13 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2022-8-19 16:47:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VeriStand Custom Devices自定义设备
    VeriStand Custom Devices为VeriStand添加了硬件支持。
    VeriStand Custom Devices是VeriStand的附加软件工具。该附加软件为HIL测试应用的其他硬件和总线类型提供支持。您可以使用VeriStand System Explorer来配置自定义设备,以满足实时测试应用的需求。VeriStand Custom Devices包括以下自定义设备:数据共享框架;嵌入式数据记录仪;发动机仿真工具包;FPGA附加软件;仪器附加软件;路由和故障分析(NI-SWITCH和SLSC开关);扫描引擎和EtherCAT;SLSC 12201;SLSC EDS;同步;以及Telemetry和System Monitor。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 599017472 字节 (571.27 MB)
    修改日期: 2022-07-23 10:04
    MD5: 60dacede016d3ccfdf5f7ff5ed3d2dc4
    SHA1: 63baa0c9d8f7b44a3800dcf10255a38b922c7aa6
    SHA256: f334e870e48720483868c783bb5a33069fb04c749a8d64a7b92e3379ba88d4c9
    CRC32: 3aa917ea
    请注册登录视觉论坛账号,购买附件查看下载地址
    VeriStand Custom Devices22.5.txt (629 Bytes, 下载次数: 1, 售价: 10 圆)
    官方没有针对该软件的自述说明,使用的是Veristand的自述文件。2022 Q3版自述文件暂未更新,参考2021 R2版自述文件。
    VeriStand 2021 R2 Readme
    May 2022
    This file contains installation instructions and compatibility information for VeriStand 2021 R2.
    • VeriStand Manual: New features, behavior changes, and other documentation
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools. Use VeriStand's run-time editable user interface to implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand 2021 R2 installs with the following:
    • NI-DAQmx 21.8
    • NI-VISA 21.5
    • NI-SLSC 21.3
    • NI-XNET 21.8
    • NI R Series Multifunction RIO 21.5
    Simulation Models
    Note  You do not need the full VeriStand environment to generate a compatible model. Instead, you can install VeriStand Model Framework or VeriStand Model Generation Support Toolbox for Simulink.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2021 R2 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 10 64-bit version 21H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2021 R2, select Linux RT System Image 21.8 and enable support for the LabVIEW 2021 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2021 R2.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2021 R2. To access the documents, refer to the VeriStand Release Notes.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2021 R2 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    Beginning with VeriStand 2021, the VeriStand suite installer will include custom devices for both offline and online installation. The following custom devices can be included during installation.
    • Data Sharing Framework
    • Embedded Data Logger
    • Engine Simulation Toolkit
    • FPGA Addon
    • Instrument Addon
    • Routing and Faulting (NI-SWITCH and SLSC Switch)
    • Scan Engine and EtherCAT
    • SLSC 12201
    • SLSC EDS
    • Synchronization
    • Telemetry
    To install Custom Devices separately, see the release page for each Custom Device on the VeriStand Add-ons support page.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2021 R2 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2021 R2 .NET API Help.
    VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.Access this guide from the \VeriStand\\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  Select VeriStand Model Framework when you run the VeriStand installer.
    • VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—VeriStand Stimulus Profile Editor examples are located in the \National Instruments\NI VeriStand\Examples directory.
      Note  On the Windows OS, the default location of the directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2020\examples\NI Veristand directory.
    VeriStand no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit NI Support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and All 32-Bit Windows.
    © 2009–2022 National Instruments Corporation. All rights reserved.
    375380Y-01
    GMT+8, 2026-4-1 13:52
