查看: 1795|回复: 0
[NI驱动程序] NI System Configuration 2022 Q3 MAC64Eng NI系统配置nisyscfg22.5苹果版
    12 小时前
  • 签到天数: 3559 天
    连续签到: 4 天
     楼主| 发表于 2022-8-19 16:11:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    System Configuration系统配置
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    MAC OS
    校验和
    文件大小: 15069332 字节 (14.37 MB)
    修改日期: 2022-07-26 23:54
    MD5: 76921d81d3c68d4007b641a1c0760dda
    SHA1: 0639a0da7d4d3ee80cf914fa71cffff969331503
    SHA256: 9252f5d9e83812b6f8a26f95789520c49c42e3ee22ac1ad5e7c4454f30a048ef
    CRC32: 2005723e
    请注册登录视觉论坛,购买附件查看下载地址
    System Configuration22.5MAC.txt (520 Bytes, 下载次数: 0, 售价: 10 元)
    System Configuration 2022 Q3 for macOS Readme
    July 2022
    This file contains installation instructions and compatibility information for System Configuration for macOS.
    List of Features not Supported in macOS
    System Configuration includes NI Measurement & Automation Explorer (MAX), a configuration utility that provides access to your NI devices.
    System Configuration has the following requirements:
    • OS versions: macOS 11, macOS 12 (x86_64 only)
      Note System Configuration was verified with the specified operating systems.
    • At least 60 MB of disk space
    The following table lists the NI application software versions, including service packs, supported by System Configuration.
    Versions Supported by System Configuration
    NI LabVIEW2019, 2020, 2021, 2022 Q3 and later
    The "System Configuration Support for LabVIEW" package supports applications using System Configuration ?with LabVIEW 2022 Q3 or later. When installing System Configuration, this package will be recommended if you have already installed LabVIEW 2022 Q3 or later and installs to the LVAddons directory.
    LVAddons directory location: /Library/Application Support/National Instruments/LVAddons
    The following VIs in the System Configuration API that are supported with RT targets on Windows are not supported on macOS:
    • Get Available Software VI
    • Install VI
    • Uninstall VI
    © 2014–2022 National Instruments Corporation. All rights reserved.
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    GMT+8, 2025-6-6 20:26
