NI RFmx EV-DO 2022 Q3 Win11 32/64bitEng 1xEV-DO蜂窝测试软件22.5
RFmx EV-DO
RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2022/7/23
包含的版本:2022 Q3完整版,版本号22.5.0
32/64位完整版校验和:
文件大小: 822134784 字节 (784.05 MB)
修改日期: 2022-07-23 09:51
MD5: 826d21add1cecbeeaeebda6c0e4c3b1c
SHA1: 98433e4aa2d65f1275a0edcc1269676a70494819
SHA256: 42754d4693e0cef52868951cabb276a1aaa796885f19ccdf6fc7698517a4324f
CRC32: d7adc01c
NI官方下载和百度网盘下载地址:
注册登录视觉论坛账号,购买附件查看下载地址
RFmx evdo22.5.txt
(544 Bytes, 下载次数: 0, 售价: 10 圆)
32位运行版校验和:
CRC32: d7adc01c
NI官方下载和百度网盘下载地址:
RFmx evdo22.5RTE32.txt
(576 Bytes, 下载次数: 0, 售价: 5 圆)
64位运行版校验和:
CRC32: d7adc01c
NI官方下载和百度网盘下载地址:
RFmx evdo22.5RTE64.txt
(564 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx EV-DO 2022 Q3 ReadmeJuly 2022 This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx EV-DO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx EV-DO Manuals: New features, behavior changes, and other documentation
Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information OverviewRFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. New FeaturesRFmx EV-DO 2022 Q3 includes the following new feature: - Support for LabVIEW 2022 Q3 (32-bit and 64-bit)
RFmx EV-DO 21.3 includes the following new feature: - Support for LabVIEW 2021 (32-bit and 64-bit)
RFmx EV-DO 20.0 includes the following new features: - Support for LabVIEW 2020 (32-bit and 64-bit)
- Support for Start trigger, Advance trigger, and Events in RFInstr
- Support to configure RFInstr properties in the context of a signal configuration
- Support for PXIe-5841 with PXIe-5655
- Support for FFT Overlap in the Sequential FFT method of the ACP measurement
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx EV-DO has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx EV-DO 2022 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx EV-DO no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx EV-DO 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx EV-DO 2022 Q3 to an unsupported OS. Additionally, after installing RFmx EV-DO 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx EV-DO | | LabVIEW | 2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx EV-DO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files (64-bit) | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments» RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel. Accessing the APIRFmx EV-DO palette VIs are available from the Functions » Measurement I/O » RFmx » EVDO palette. Accessing the DocumentationDocumentation for RFmx EV-DO is located at Start » National Instruments » RFmx EV-DO Documentation. Finding ExamplesYou can access all the installed RFmx EV-DO examples at Start » National Instruments » RFmx EV-DO Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx EV-DO 20.7 from RFmx EV-DO 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
The following is the behavior change in RFmx EV-DO 19.1 from RFmx EV-DO 19.0. - Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0. - Dropped support for LabVIEW 2015.
- Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Legal InformationCopyright © 2015–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
