查看: 1879|回复: 0
[RTE运行引擎] NI RFmx 2022 Q3 Runtime Win11 32bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_22.5
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-8-16 16:13:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期:2022/7/23
    包含的版本:2022Q3运行版,版本号22.5.0
    应用程序位数:32位
    文件大小: 757127168 字节 (722.05 MB)
    修改日期: 2022-07-23 09:59
    MD5: 6cadb39f7a02e75e6fd161870eeacd8f
    SHA1: 670652f854e8e4752a0dc16b1ffc166f1575d828
    SHA256: e733fbbdff09f212824fb68bd0564d0474a9ce4fbb27e81996956fedc85607e5
    CRC32: ce06e6dd
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx22.5RTE32.txt (594 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Runtime (32-Bit) 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx Runtime (32-Bit), including system requirements, and installation instructions.
    • RFmx Runtime (32-Bit) Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx Runtime (32-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (32-Bit)
    • RFmx Demod Runtime (32-Bit)
    • RFmx WLAN Runtime (32-Bit)
    • RFmx for Bluetooth® Test Runtime (32-Bit)
    • RFmx NR Runtime (32-Bit)
    • RFmx LTE Runtime (32-Bit)
    • RFmx WCDMA Runtime (32-Bit)
    • RFmx TD-SCDMA Runtime (32-Bit)
    • RFmx EV-DO Runtime (32-Bit)
    • RFmx CDMA2k Runtime (32-Bit)
    • RFmx GSM Runtime (32-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (32-Bit) has the following requirements:
    RFmx Runtime (32-Bit) 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx Runtime (32-Bit) no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Runtime (32-Bit) 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Runtime (32-Bit) 2022 Q3 to an unsupported OS. Additionally, after installing RFmx Runtime (32-Bit) 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Download the RFmx Runtime (32-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    © 2019–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:31
