查看: 1582|回复: 0
[NI软件产品] NI Data Record AD 1.1 x64Win10 64bitEng 自动驾驶数据记录1.1
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-8-16 15:06:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    数据记录AD
    Data Record AD可帮助您在PXI系统上运行高带宽高级驾驶员辅助系统(ADAS)和自动驾驶(AD)车载数据记录应用程序。
    Data Record AD是支持ADAS和AD数据记录应用程序的应用软件。该软件可与PXI系统连接,以帮助您记录来自摄像机、雷达、激光雷达设备以及车辆网络总线(如控制器局域网CAN、FlexRay、以太网等)的原始传感器和通信总线数据。
    发布日期:2021/8/7
    包含的版本:1.1完整版
    文件大小: 2019133440 字节 (1.88 GB)
    修改日期: 2021-08-07 01:16
    MD5: 6d3bd3cc3a174457c14fba30f0f45037
    SHA1: 626afba10c255a74f43421aa270597860a8ed309
    SHA256: a8a3c810366abcc3c6f1eb13b6e13ddbd73deadaa790129c6af33ea054c32263
    SHA512: 018c30f06dab2b23386b304622b8d79ba2829e15954a1dec2c385b5ee33ed8b57aff066abc1175287c3b5e126046e106b53115c8f0c06ed91772603ef372a694
    请注册登录视觉论坛账号,购买附件查看下载地址
    自动驾驶数据记录1.1.txt (685 Bytes, 下载次数: 0, 售价: 10 圆)
    Data Record AD 1.1 Readme
    July 2021
    This file contains important information about Data Record Autonomous Driving 1.1 (Data Record AD) and the Data Record AD Configuration Editor 1.1 (Configuration Editor), including installation instructions. You can use Data Record AD for developing, executing, debugging, and deploying in-vehicle datalogging configurations on the Data Record System AD (Data Record System). The Configuration Editor provides a utility that you can use to configure the I/O plug-ins, data sources and sinks, and data streams within Data Record AD.
    • Data Record AD Release Notes: Known issues, bug fixes, and other notes about this release
    • Data Record AD Manuals
    Included Components
    Supported Controllers and Operating Systems
    Included Components
    Data Record AD 1.1 includes the following required component:
    • Data Record AD Configuration Editor 1.1 (Configuration Editor)
    Data Record AD 1.1 includes the following optional components:
    • Data Record AD User Interface
    • Built I/O plug-ins
    Data Record AD 1.1 has the following requirements:
    • 2.8 GHz Quad-Core Intel Xeon processor (or equivalent)
    • Minimum disk capacity of 160 GB
    • Minimum 8 GB of RAM
    • Minimum .NET Framework: 4.6.2
    Data Record AD 1.1 supports the following controllers:
    • PXIe-8861
    • PXIe-8880
    • PXIe-8881
    Note  The PXIe-8881 controller is functionally supported, but its high power consumption levels must taken into account during power budgeting.
    Data Record AD 1.1 supports the following operating system:
    • Windows 10 (64-bit only)
    Download the Data Record AD software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • The Data Record AD software installer will automatically install the Configuration Editor. The Visualization Toolkit and the example I/O plug-ins are optional add-ons.
    • Use the serial number that is included with your software to activate Data Record AD 1.1. For more information about Data Record AD software activation, refer to NI Software Activation.
    Refer to the Data Record System AD User Manual system components table for information about hardware supported by Data Record AD.
    Data Record AD 1.1 adds the following major new feature:
    • Async Error Handlers—Data Record AD now logs application errors by default and allows you to introduce custom handling of plug-in-generated errors.
    Refer to the Data Record System AD User Manual, accessible from ni.com/manuals, or the Data Record AD GitHub repository for information about Data Record AD and the Configuration Editor.
    The .NET 4.6.2 installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software.
    © 2021 National Instruments Corporation. All rights reserved.
    378523B-01
    GMT+8, 2025-11-19 09:06
