NI Calibration Executive 6.4.0 x64Win10 64bitEng NI校准执行程序6.4.0下载
校准执行程序
Calibration Executive用于校准和调整NI测量设备上的I/O通道。
Calibration Executive是一个用于计量应用的软件工具。Calibration Executive提供了直观的用户界面,提供自动或手动两种模式。此外,该工具还提供了报告功能,用于记录校准和调整结果,同时还可存储和检索数据。借助软件的模块化环境,您可以在可用时添加新的校准程序,并将报告存储在符合ODBC的数据库中,以便从其他程序访问。
该应用程序6.0之前的版本找不到完整版资源,无法提供。
发布日期:2021/10/27
包含的版本:6.4.0完整版
文件大小: 13288228864 字节 (12.38 GB)
修改日期: 2021-10-27 23:07
MD5: 531fddf01d4a4f43f0ea8846861860b5
SHA1: ba8cfb21747c56ef18cd09c892510fc06a525291
SHA256: 069984ab321228d362651feb97ccc556d4171277e69f7b77b417a16b39518ba9
CRC32: 7e7265aa
百度网盘和NI官方下载:
请注册登录视觉论坛账号,购买附件查看下载地址
CalExec6.4.0.txt
(587 Bytes, 下载次数: 0, 售价: 20 圆)
Calibration Executive 6.4 ReadmeOctober 2021 This file contains installation instructions and compatibility information for Calibration Executive 6.4. You can find more release information on ni.com. - Calibration Executive Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- Calibration Executive 6.4 Manual: Calibration Executive 6.4 Help
- Calibration Executive Manuals: Other documentation for Calibration Executive
Overview System Requirements Supported Operating Systems Installation Instructions Upgrade Considerations Product Security and Critical Updates Driver Information New Features Behavior Changes Accessing the Help Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems Legal Information OverviewCalibration Executive 6.4 is a minor release that adds or enhances features and functionality to Calibration Executive 6.0. System RequirementsCalibration Executive has the following requirements: - 1 GHz, 64-bit (x64) processor
- 8 GB of RAM (procedures with a large number of test points might require more memory)
- 1024 x 768 pixels screen resolution
- The user must have administrator privileges
Supported Operating SystemsCalibration Executive supports the following operating systems: Note Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Note Calibration Executive will not install or run on an unsupported OS. Additionally, after installing this version of Calibration Executive, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Installation InstructionsDownload the Calibration Executive installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
- Use the serial number that is included with your software to activate Calibration Executive. For more information on Calibration Executive activation, refer to NI Software Activation.
- Calibration Executive requires Java SE 8 Update 51 or greater, which is available from www.oracle.com.
Upgrade ConsiderationsCalibration Executive versions 6.0 and later have a new installation path, and the program no longer launches as an administrator application. These changes can render some application database paths invalid after the upgrade. After an upgrade, you might need to manually move some files. Upgrading Calibration Executive 5.x to 6.0 and laterIf your Report and Uncertainty databases are in their default locations, the setup program will automatically move the databases to the new default location and no action is required. If databases were moved from their default locations in Calibration Executive 5.x, then Calibration Executive 6.x attempts to reference the current location. If Calibration Executive cannot write to the files in this location, a warning message will be displayed when you first launch Calibration Executive. In this case, you will need to move the files manually to a writeable location. After you move the database files, follow the instructions in Selecting Database Locations to configure the paths for Calibration Executive 6.0 and later. Upgrading Calibration Executive 4.x to 6.0 and laterThe setup program for Calibration Executive 6.x does not automatically move your Report and Uncertainty databases, even if they are in their default locations. Instead, you will need to move the databases manually to a writeable location. After you move the database files, follow the instructions in Selecting Database Locations to configure the paths for Calibration Executive 6.0 and later. Selecting Database LocationsTo select the location of your Report database: - In the menu bar, select Configure»Database options.
- Click the folder icon in the Calibration Executive Configure Report Database dialog, and browse to find the database file.
- Select the file and click OK.
- Click OK to close the dialog box.
To select the location of your Uncertainty database: - In the menu bar, select Configure»Calibration Reports.
- In the Calibration Reports window, click Manage Uncertainty. The Uncertainty Export/Import window opens.
- Select Database Options»Select Database Location
- Use controls in the Select Uncertainty Database File explorer window to locate your uncertainty database file.
- Select the file, and click OK.
- In the Uncertainty Export/Import window, click Done.
- Click Close to close the Calibration Reports window.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Driver InformationThe following instruments require specific drivers that are not installed by Calibration Executive. To install these drivers, you must download them directly from the manufacturer's website; you can find links to third party instrument drivers at ni.com/idnet. Driver versions listed are those tested during development; later versions might be available and should be compatible. Instrument | Required Driver(s) | | Rohde & Schwarz NRP-Z power meter | NRP-Toolkit 4.16 NRP-NI-VISA Passport 2.7.1 NRP-Z VXI Plug & Play x64 Driver 3.6.0.0 | | Rohde & Schwarz SMA100A signal generator | VXIplug&play x64 driver rssma version 2.21.0 | | Rohde & Schwarz ZNB20 vector network analyzer | VXIplug&play x64 driver rsvna version 2.50.0 |
Note This release does not include an NI-VNA driver. To run the PXI-5691 and PXIe-5632 procedures, download NI-VNA 18.0 and install the driver manually after you install Calibration Executive. New FeaturesProduct support and new features were added as indicated below: Calibration Executive 6.4- Revised the reporting of guard band values with dB and dBv units on the calibration report.
- Import uncertainties from an Open XML spreadsheet using formulas that result in text values.
- Product support:
| PXIe-5841 | PXIe-5841 (2 yr) | RM-26999 |
Calibration Executive 6.3- Revised formulas for determining measurement uncertainty related to TURs and nominal values.
Calibration Executive 6.2- Product support:
| PXIe-5624 | PXIe-5606 Adjust Only | PXIe-5668 Adjust Only | | | USB-6346 (Screw Terminal) | STS-DIO-01 | |
Calibration Executive 6.1Calibration Executive 6.0- Uncertainty and guard band options in custom report configurations
- Product support:
| PXIe-6349 | USB-6349 | NI 9202 | NI 9252 |
Behavior ChangesThe following procedures, features, and support were modified in Calibration Executive 6.x releases. Calibration Executive 6.4:- Guard band calculation for uncertainties with dB and dBv units has changed.
- The following procedures have changed:
- PCI-4461
- PXI-4461
- PXIe-5654 (10 GHz)
- PXIe-5654 (20 GHz)
- PXIe-5654 with PXIe-5696 (10 GHz) Adjust Only
- PXIe-5654 with PXIe-5696 (20 GHz)
- PXIe-5668 (14 GHz), all bandwidth options
- PXIe-5840
- PXIe-5840 (2 yr)
- NI 9220
- NI 9263
Calibration Executive 6.3:- TUR calculation for uncertainties with dB and dBv units has changed.
Calibration Executive 6.2:| PXI-4110 | PCI-5412 | PXI-5412 | PCI-5421 | | | PXI-5421 | PXI-5441 | PXIe-5442 | PXIe-5653 | | | PXIe-5665 (3.6 GHz) | PXIe-5665 (3.6 GHz), no pre-amp | PXIe-5665 (14 GHz) | PXIe-5668 (14 GHz), all bandwidth options | | | PXIe-5668 (26.5 GHz), all bandwidth options | | | | | Calibration Executive 6.1:| PXI-4110 | USB-5132 | USB-5133 | PCI-5412 | | | PXI-5412 | PCI-5421 | PXI-5421 | PXI-5441 | | | PXIe-5442 | PXI-5622 | PXIe-5645R | PXIe-5654 (20 GHz) | | | PXIe-5654 (20 GHz), with PXIe-5696 | PXIe-5665 (3.6 GHz), no pre-amp | PXIe-5668 (14 GHz), all bandwidth options | PXIe-5668 (26.5 GHz), all bandwidth options | | Calibration Executive 6.0.1:- A critical bug in the Verify ALC Limits Table test is fixed, enabling the following devices to be verified and adjusted:
- PXI-5650
- PXIe-5650
- PXI-5651
- PXIe-5651
- PXI-5652
- PXIe-5652
- PXIe-5663
- PXIe-5663E
- PXIe-5673
- PXIe-5673E
Calibration Executive 6.0:- Added adjustment support for NI 9203.
- Modified audio notifications can only be enabled or disabled; there are no additional options to be configured.
- Removed support for 32-bit OS calibration procedures.
Accessing the HelpRefer to Calibration Executive Help, accessible from Help»Calibration Executive Help, for information about Calibration Executive. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsCalibration Executive no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. Legal InformationCopyright © 2005–2021 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. An NI Partner is a business entity independent from NI and has no agency, partnership, or joint-venture relationship with NI. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375683AE-01 |
