查看: 1649|回复: 0
[NI软件产品] NI Calibration Executive 6.0.1 Win64Eng NI校准执行程序6.0.1下载
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-8-15 17:19:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    校准执行程序
    Calibration Executive用于校准和调整NI测量设备上的I/O通道。
    Calibration Executive是一个用于计量应用的软件工具。Calibration Executive提供了直观的用户界面,提供自动或手动两种模式。此外,该工具还提供了报告功能,用于记录校准和调整结果,同时还可存储和检索数据。借助软件的模块化环境,您可以在可用时添加新的校准程序,并将报告存储在符合ODBC的数据库中,以便从其他程序访问。
    该应用程序6.0之前的版本找不到完整版资源,无法提供。
    发布日期:2020/10/2
    包含的版本:6.0.1完整版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    文件大小: 12305522688 字节 (11.46 GB)
    修改日期: 2020-10-2 4:37
    MD5: dd12c9c49a937600c319e0887634a1d1
    SHA1: 23c9e3c0660b3176cd833aa947072ac70038c642
    SHA256: 6d236676ebaeb32338d001200cd165cc29c97dc289f29ea1f6adc5f0398a4c04
    CRC32: 78d12633
    百度网盘和NI官方下载:
    请注册登录视觉论坛账号,购买附件查看下载地址
    CalExec6.0.1.txt (587 Bytes, 下载次数: 0, 售价: 20 圆)
    Calibration Executive 6.0.1 Readme
    September 2020
    This file contains important information about Calibration Executive, including installation instructions, new features, and known issues.
    Calibration Executive Drops Support for Windows 7, 64-Bit Operating System in 2021
    Upgrade Considerations
    Driver Information
    New Features, Procedures, and Behavior Changes
    Device Support in Calibration Executive
    Calibration Executive 6.0.1 is a patch for Calibration Executive 6.0.
    Calibration Executive 3.6 and later does not support legacy procedures that require the NI Traditional DAQ driver. Calibration support for these devices is available using Calibration Executive for Traditional DAQ Version 3.5.2.
    Calibration Executive has the following requirements:
    • 1 GHz, 64-bit (x64) processor
    • 8 GB of RAM (procedures with a large number of test points might require more memory)
    • 1024 x 768 pixels screen resolution
    • The user must have administrator privileges
    Calibration Executive supports the following operating systems (64-bit OSes only):
    • Windows 8.11
    • Windows 7 SP12
    Calibration Executive will drop support for Windows 7 (32- and 64-bit) and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Note  In 2016, National Instruments dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Calibration Executive will not install or run on an unsupported OS. Additionally, after installing this version of Calibration Executive, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, NI Installer Fails on Windows XP/Vista and Windows Server 2003.
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates.
    Ensure that your system meets the prerequisites listed in the System Requirements and Supported Operating Systems sections. In addition, all instrument drivers must be installed prior to installing Calibration Executive; see Driver Information for more information.
    Before you begin, log onto your system as an administrator or as a user with administrator privileges. Be sure to exit all National Instruments applications.
    To install Calibration Executive, follow these steps:
    • Download Calibration Executive software from ni.com/downloads/products.
      Note  You must save the installer to your local drive. Do not attempt to open the file from its current location or to run the file from a temporary location.
    • Launch the installer and follow the prompts.
    • Use NI License Manager to confirm that software has been activated or to activate the software.
      Note  If you are unable to locate your activated serial number for Calibration Executive, check the following file on your system: C:\ProgramData\National Instruments\Calibration Executive\CalExecLicenseInfo.ini.
    • Launch Calibration Executive, and confirm that the installation completed successfully and that the correct version is installed (Help > About Calibration Executive).
    Note  To conserve disk space, you can delete the extracted files. It is recommended that you keep the extracted installation files in case you need to add features from this distribution in the future.
    Note  Calibration Executive requires Java SE 8 Update 51 or greater, which is available from www.oracle.com.
    Calibration Executive 6.0 has a new installation path, and it no longer launches as an administrator application. These changes can render some application database paths invalid after the upgrade. After an upgrade, you might need to manually move some files.
    Upgrading Calibration Executive 5.x to 6.0
    If your Report and Uncertainty databases are in their default locations, the setup program will automatically move the databases to the new default location and no action is required.
    If databases were moved from their default locations in Calibration Executive 5.x, then Calibration Executive 6.0 attempts to reference the current location. If Calibration Executive cannot write to the files in this location, a warning message will be displayed when you first launch Calibration Executive. In this case, you will need to move the files manually to a writeable location. After you move the database files, follow the instructions in Selecting Database Locations to configure the paths for Calibration Executive 6.0.
    Upgrading Calibration Executive 4.x to 6.0
    The setup program for Calibration Executive 6.0 does not automatically move your Report and Uncertainty databases, even if they are in their default locations. Instead, you will need to move the databases manually to a writeable location. After you move the database files, follow the instructions in Selecting Database Locations to configure the paths for Calibration Executive 6.0.
    To select the location of your Report database:
    • In the menu bar, select Configure»Database options.
    • Click the folder icon in the Calibration Executive Configure Report Database dialog, and browse to find the database file.
    • Select the file and click OK.
    • Click OK to close the dialog box.
    To select the location of your Uncertainty database:
    • In the menu bar, select Configure»Calibration Reports.
    • In the Calibration Reports window, click Manage Uncertainty. The Uncertainty Export/Import window opens.
    • Select Database Options»Select Database Location
    • Use controls in the Select Uncertainty Database File explorer window to locate your uncertainty database file.
    • Select the file, and click OK.
    • In the Uncertainty Export/Import window, click Done.
    • Click Close to close the Calibration Reports window.
    Driver Information
    The following driver is required for specific product support in Calibration Executive. Download NI drivers from ni.com/downloads/ and install them manually.
    • VirtualBench Software 19.0 (required for all supported VirtualBench products). If VirtualBench Version 19.0 is not available from NI Driver Downloads, contact NI support for access to the VirtualBench 19.0b3 beta version installer.
    The following instruments require specific drivers that are not installed by Calibration Executive. To install these drivers, you must download them directly from the manufacturer's website; you can find links to third party instrument drivers at ni.com/idnet.
    Driver versions listed are those tested during development; later versions might be available and should be compatible.
    Instrument
    Required Driver(s)
    Rohde & Schwarz NRP-Z power meterNRP-Toolkit 4.16
    NRP-NI-VISA Passport 2.7.1
    NRP-Z VXI Plug & Play x64 Driver 3.6.0.0
    Rohde & Schwarz SMA100A signal generatorVXIplug&play x64 driver rssma version 2.21.0
    Rohde & Schwarz ZNB20 vector network analyzerVXIplug&play x64 driver rsvna version 2.50.0
    Note  This release does not include an NI-VNA driver. To run the PXI-5691 and PXIe-5632 procedures, download NI-VNA 18.0 and install the driver manually after you install Calibration Executive.
    New Features, Procedures, and Behavior ChangesCalibration Executive 6.0.1Behavior Changes
    The Calibration Executive 6.0.1 patch release changes the following:
    • A critical bug in the Verify ALC Limits Table test is fixed, enabling the following devices to be verified and adjusted:
      • PXI-5650
      • PXIe-5650
      • PXI-5651
      • PXIe-5651
      • PXI-5652
      • PXIe-5652
      • PXIe-5663
      • PXIe-5663E
      • PXIe-5673
      • PXIe-5673E
    Calibration Executive 6.0New Features
    The Calibration Executive 6.0 release adds the following features:
    • Uncertainty and guard band options in custom report configurations
    New Product Support
    PXIe-6349USB-6349NI 9202NI 9252
    The Calibration Executive 6.0 release changes the following:
    • Added adjustment support for NI 9203.
    • Modified audio notifications can only be enabled or disabled; there are no additional options to be configured.
    • Removed support for 32-bit OS calibration procedures.
    You can access the software and documentation known issues list online. Visit Calibration Executive 6.0 Known Issues for an up-to-date list of known issues.
    You can access a list of a subset of issues fixed in Calibration Executive 6.0 online at Calibration Executive 6.0 Bug Fixes.
    Refer to Calibration Executive Help for a list of devices, including traditional DAQ and legacy devices, that are supported in previous versions of Calibration Executive.
    Refer to the Calibration Executive Help, accessible from Help»Calibration Executive Help, for information about Calibration Executive.
    © 2005–2020 National Instruments Corporation. All rights reserved.
    375683AA-01
    GMT+8, 2025-11-19 09:06
