查看: 2076|回复: 0
[NI软件套件] NI Test Workflow 2022 Q3 Standard Win11 64bitEng NI测试工作流程22.5标准版-64位英文
     楼主| 发表于 2022-8-12 15:54:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    标准版包含:
    应用程序软件
    LabVIEW完整版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem高级版
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版/标准版 版本号22.3.0
    文件大小: 10083311616 字节 (9.39 GB)
    修改日期: 2022-07-23 10:02
    MD5: 8863a2ec0f6eb686ba9fd763d51acd99
    SHA1: ba206defbcde5f3d28ac0788b18e47fedcf04d87
    SHA256: 53600f0d56bebe154e6dc4c86095b7ae38c1062a90755676d58dd0d4309f8dae
    SHA512: 787830d5e25f804736b6ddfc6c981ac004b1452c7a8d7cc8c5d454d90bfb20ce966e8e34f126faf5a5d4d0333b3769455f8e6217298bc187ae1b8ba7c7d55f74
    注册登录视觉论坛,购买附件查看下载地址
    TestWorkflow2022Q3标准版64位Eng.txt (749 Bytes, 下载次数: 0, 售价: 20 圆)
    Test Workflow Standard 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for Test Workflow Standard 2022 Q3.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Standard Bundle
    Test Workflow is a bundle of select NI software featuring engineering-specific tools that help test professionals accomplish anything from their day-to-day work to overcoming their most challenging obstacles.
    Test Workflow Standard 2022 Q3 supports the following operating systems:
    Note Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Test Workflow Standard 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Test Workflow Standard 2022 Q3 to an unsupported OS. Additionally, after installing Test Workflow Standard 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following products are included in the Test Workflow Standard installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q264-bit
    LabVIEW2022 Q332-bit and 64-bit
    FlexLogger12022 Q264-bit
    InstrumentStudio2022 Q364-bit
    1 Product does not support LabVIEW 2022 Q3.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow Standard 2022 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Test Workflow no longer installs IVI Compliance Package (ICP). Test Workflow supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2021–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-13 11:02
