查看: 1340|回复: 0
[LV工具模块] LabVIEW PDM Acquisition Toolkit 2021Q4 Patch1 x64Win10 32bitEng LV脉冲密度调制采集工具包21.4.1
    昨天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2022-8-9 17:43:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW PDM采集工具包
    LabVIEW PDM采集工具包可帮助您从数字麦克风中获取和转换脉冲密度调制(PDM)信号,以评估硬件性能。
    LabVIEW PDM采集工具包是LabVIEW的软件附加工具,可与PXIe-7820 PXI数字可重配置I/O设备结合使用。该附加工具提供了多种工具,可用于采集PDM信号,并将其转换为音频波形,以进行测试。您可以使用LabVIEW PDM采集工具包,采集多种不同速率和采样因子的PDM信号。
    2021Q4
    发布日期:2022/6/22
    包含的版本:2021 Q4 Patch1完整版专业版,版本号21.4.1
    应用程序位数:32位
    文件大小: 3810791424 字节 (3.55 GB)
    修改日期: 2022-06-22 21:52
    MD5: 6a1fc7d6641346c77b2fb3ed7147a723
    SHA1: 2a3d642e7983fef47f346833ff46291dfb248e0b
    SHA256: 0dd32177c75ddd131da708edb91222aceedacad453dc29a26237b5de778e5616
    SHA512: b070d572e9a419c67c84d2532ccfa3ff70cff6eb090f25098667acd220759042f3080c49d6bdd8a69ec8f4f2d94fa9d066e05cd2812aa96151808a810218f657
    请注册登录视觉论坛账号,购买附件查看下载地址
    PDM2021Q4 21.4.1.txt (748 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW PDM Acquisition Toolkit 2021 Q4 Readme
    November 2021
    This file contains installation instructions and compatibility information for the LabVIEW PDM Acquisition Toolkit.
    • LabVIEW PDM Acquisition Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Driver and Add-On Requirements
    The LabVIEW PDM Acquisition Toolkit is a LabVIEW add-on that supports both PDM and I2S signals. This add-on provides tools that you can use to acquire and convert signals into audio waveforms for test as well as generate your own signals. You can use the LabVIEW PDM Acquisition Toolkit to acquire and generate signals at various rates and decimation factors.
    The PDM Acquisition Toolkit 2021 Q4 supports only the Windows 10 (64-bit) operating system.
    The PDM Acquisition Toolkit 2021 Q4 supports the following application software versions, including service packs.
    Versions Supported by the PDM Acquisition Toolkit
    LabVIEW (32-bit only)2018 SP1 Patch, 2019, 2020
    The PDM Acquisition Toolkit 2021 Q4 requires the following driver and add-on versions:
    Note  NI recommends using the latest available version.
    • NI R Series Multifunction RIO 20.0.0
    Download the PDM Acquisition Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  Use the serial number that is included with your software to activate the PDM Acquisition Toolkit. For more information on PDM Acquisition Toolkit activation, refer to Activating a Product.
    The following list details the hardware models supported in the LabVIEW PDM Acquisition Toolkit 2021 Q4.
    • PXIe-7820R/7821R
    • USB-7845R/7846R
    Refer to the LabVIEW PDM Acquisition Toolkit Help, accessible at labview\help\pdmacquisition.chm, for information about the PDM Acquisition Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the LabVIEW PDM Acquisition Toolkit are located in the labview\examples\PDM Acquisition Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2020–2021 National Instruments Corporation. All rights reserved.
    378442C-01
    GMT+8, 2025-6-1 12:14
