查看: 2082|回复: 0
[LV工具模块] LabVIEW myRIO Toolkit 2021 SP1 x64Win10 32bitEng LabVIEW myRIO工具包2021SP1
    2 小时前
  • 签到天数: 3705 天
     楼主| 发表于 2022-8-9 16:14:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW myRIO工具包提供了在myRIO学生嵌入式设备上开发和部署应用程序所需的工具。
    LabVIEW myRIO工具包是LabVIEW的软件附件,提供了在myRIO学生嵌入式设备上快速开发和部署应用程序所需的驱动和工具。该工具包为myRIO设备上的每种I/O类型提供了基于配置的Express和Advanced I/O VI,可帮助学生快速构建想法并编写独立的应用程序。
    发布日期:2022/7/23
    包含的版本:2021 SP1完整版,版本号8.0.0
    Windows 11(官方下载页面写着支持WIN11,但是自述文件中没有说支持WIN11,如果是基于LV2021SP1版本,那是不支持WIN11的以及WIN SEV2022)
    应用程序位数:32位
    文件大小: 5736984576 字节 (5.34 GB)
    修改日期: 2022-07-23 09:52
    MD5: 6f8fcfeac2f2eea8e4db07472765070e(官方正确)
    SHA1: 7d3d2a3e5970ab6e16dacc40b2aed57bf1c03b2d
    SHA256: 1e270e283613a937bbd6c376f719c48bfff6279180d52467b24ea5132cde4005
    SHA512: ac86c7c0ab90a81b3883a2abfb2f5d524d42509866242b1b011a1b5b0dd2222a72bda0834db276a9b8822352e71925016137bc15fd3f0e18a307c812d6d15200
    请注册登录视觉论坛账号,购买附件查看下载地址
    myRIO2021SP1.txt (737 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2021 myRIO Toolkit Readme
    July 2022
    This file contains installation instructions and compatibility information for LabVIEW 2021 myRIO Toolkit.
    • LabVIEW myRIO Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW myRIO Toolkit Manuals: New features, behavior changes, and other documentation
    Accessing the LabVIEW for myRIO Environment
    The LabVIEW myRIO Toolkit provides you with tools for creating and deploying applications on the myRIO.
    LabVIEW 2021 myRIO Toolkit has the following requirements:
    • (Optional for C Programming) LabVIEW 2021 SP1 Community, Full, or Professional Development System
    • (Optional for C Programming) LabVIEW 2021 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
    • 1 GB RAM
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2021.
    Note
    • The myRIO Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    LabVIEW 2021 myRIO Toolkit supports the following operating systems:
    Download the LabVIEW myRIO Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Installing the High Throughput Add-On for myRIO
    The High Throughput Add-On for myRIO provides the High Throughput FPGA Personality VIs which support high-speed analog or digital data access. The High Throughput FPGA Personality VIs appear on the myRIO palette only after you install the High Throughput Add-On for myRIO.
    Visit ni.com/info and enter the Info Code ex6g5a to download the High Throughput Add-On for myRIO installer. Double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
    The myRIO Toolkit provides the LabVIEW for myRIO environment to allow you to easily access myRIO-specific features and focus on developing myRIO applications.
    You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the myRIO Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the myRIO Toolkit are located in the labview\examples\myRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW myRIO Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2013–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-11-7 11:15
