查看: 2670|回复: 0
[NI软件套件] LabVIEW myRIO Software Bundle 2021SP1 x64Win10 32bitEng LabVIEW myRIO软件套件8.0
  • 签到天数: 3829 天
    连续签到: 22 天
     楼主| 发表于 2022-8-3 12:07:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW myRIO软件套件
    LabVIEW myRIO软件套件为myRIO学生嵌入式设备提供LabVIEW myRIO工具包和附加软件。
    LabVIEW myRIO软件套件包含了LabVIEW编程环境和其他LabVIEW软件附件和驱动软件,用于在myRIO学生嵌入式设备上开发和部署应用程序。
    发布日期:2022/07/23
    包含的版本:2021SP1 V8.0.0 208Q1完整版
    Windows 11(官方下载虽然写着支持WIN11,但是在Readme中并没有说支持WIN11,如果是使用LabVIEW2021SP1版本,那是没有明确支持WIN11的。LabVIEW2022Q3版本才明确支持WIN11)
    应用程序位数:32位
    语言:英文
    文件大小: 18739615744 字节 (17.45 GB)
    修改日期: 2022-08-02 15:42
    MD5: f0791a0dff9dbc266d78260a84475363
    SHA1: bdfac482cb5cf30d1d3018db0eb558960f9ec5e7
    SHA256: 4b6fdd5f8d6df80a53a2b17d29e6cc89c4888b4473e441e58a7e7621a7ce112d
    CRC32: 3556cf28
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    LabVIEW myRIO软件套件2021SP1.txt (613 Bytes, 下载次数: 5, 售价: 30 圆)
    LabVIEW 2021 SP1 myRIO Software Bundle Readme
    July 2022
    This file contains important information about the LabVIEW myRIO Software Bundle, including supported operating systems, installation instructions, and links to detailed information about included products.
    With the LabVIEW myRIO Software Bundle, one installation gives you access to the LabVIEW myRIO Toolkit and other NI software for developing myRIO applications. The LabVIEW myRIO Software Bundle contains the following products:
    Required Software
    • LabVIEW Development System
    • LabVIEW Real-Time Module
    • LabVIEW myRIO Toolkit
    Optional Software
    • LabVIEW Control Design and Simulation Module
      • Control Design Assistant
    • LabVIEW FPGA Module
    • LabVIEW MathScript Module
    • LabVIEW Robotics Module for LabRIO
    • LabVIEW FPGA Vivado Compilation Tool
    • JKI VI Package Manager
    • Vision Development Module
    • NI-IMAQdx
    Refer to the documentation of each product for specific system requirements and supported operating systems.
    The LabVIEW myRIO Software Bundle supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    To install the myRIO Software Bundle using the installer from ni.com/academic/download, double-click the setup.exe file in the root directory of the myRIO Software Bundle installer and follow the instructions on the screen to install this product.
    NI ELVIS III Software Bundle no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2013–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-18 09:42
