查看: 1848|回复: 0
[NI驱动程序] NI Linux Device Drivers 2022 Q3 Online Linux64Eng Linux设备驱动程序2022Q3DeviceDrivers在线安装
     楼主| 发表于 2022-8-1 16:51:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Device Drivers 2022 Q3 Online Linux64Eng Linux设备驱动程序NILinux2022Q3DeviceDrivers在线安装
    NI Linux仪器驱动程序
    NI Linux Device Drivers软件为采用Linux操作系统的NI和第三方硬件提供了所需的NI仪器驱动。
    NI Linux Device Drivers软件为各种NI测试和测量硬件提供了Linux桌面支持。该软件提供了一个存储库附加工具,下载该附加工具后,就可以指示Linux软件包管理器安装NI驱动软件包,如NI-DAQmx、NI-VISA、NI-488.2和NI-Sync。NI Linux Device Drivers软件也支持LabVIEW。
    发布日期:
    2022/7/25
    包含的版本:
    2022Q3完整版
    RedHat
    CentOS
    SUSE
    Ubuntu
    语言:
    English
    文件大小: 408540 字节 (398.96 KB)
    修改日期: 2022-07-23 04:45
    MD5: 83a97828dd8906411af56032002adc99
    SHA1: 9e3c46c7f26c88aae124294d0b2ed360ff85dea5
    SHA256: 8f5dd7ecf8360777b61842875f5afb3a1e3d123193c7b46726c914e255e6b701
    SHA512: c72bde70707d9d20e5db518bb95ec686696f1183cf3f7996b6b2cd55f0d4909261ea7b4cd8db552ab6148d1939b0d0746d6d2879b8d0d9058da80546003db191
    百度网盘和NI官方下载地址(在线安装,需要连网支持,且能正常连接NI服务器):
    请注册视觉论坛会员登录后购买附件下载查看,充值请联系在线客服
    NILinux2022Q3DeviceDrivers.txt (655 Bytes, 下载次数: 1, 售价: 5 圆)
    NI Linux Device Drivers 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI Linux Device Drivers 2022 Q3.
    • NI Linux Device Drivers Release Notes: for known issues, bugs fixed since the last release, and other release details.
    Package Repositories
    Supported Drivers
    NI Linux Device Drivers software provides Linux Desktop support for a variety of NI test and measurement hardware. It offers repository registration packages for each supported Linux distribution. Once the appropriate driver software repository is registered for the system, use the Linux distribution's native package manager to install NI driver software packages.
    • NI-RFSA and NI-RFSG adds support for Ubuntu 18.04 and Ubuntu 22.04
    • NI-DMM and NI-SCOPE adds LabVIEW support on Ubuntu
    • NI-FGEN adds support for H/W Configuration
    • Ubuntu repositories adds support for the same products as the RedHat Enterprise Linux and OpenSUSE repositories
    Refer to Download and Install NI Driver Software on Linux Desktop.
    NI Linux Device Drivers are installed from one of the following two options.
    • Static repository registration packages are labeled with a date-based suffix, such as ni-RHEL7CENTOS7-drivers-2022Q3. Software from this repository is not intended to change, and it is updated only for critical patches. Use this kind of repository when you need to reproduce a specific software stack.
    • Stream repository registration packages are labeled with a -stream suffix, for example: ni-RHEL7CENTOS7-drivers-stream. Software in this repository is updated regularly with the latest versions of each driver package as it is released. Running an update/upgrade command with a package manager will update installed NI packages to their latest released version for systems that have registered a stream repository. This kind of repository is the simplest way to keep NI driver software up to date.
    "Firstlook" is present in repository registration package names, for example ni-ubuntu2004firstlook-drivers-2021Q3.deb, to identify a repository that does not contain one or more of the drivers present in the other feeds. This commonly occurs when NI adds support for a new Linux OS distribution and there is a transition period while individual drivers are gradually added or validated on that distribution.
    If you plan to upgrade to a new distribution and you see "firstlook" in its NI repository registration package name, refer to the Supported Drivers table to ensure that the NI products you need support the new distribution.
    Supported Drivers
    For a list of supported hardware, refer to the NI Hardware and Operating System Compatibility page. For details about a specific driver's system requirements, limitations, and so on, refer to the readme for the individual driver (linked below).
    The following table shows driver support for several Linux distributions. Use your Linux distribution's package manager to install the specified add-on files for an NI driver.
    NI Driver Support for Linux Distributions
    Driver
    Packages
    RHEL1/
    CentOS 7
    Kernel 3.10
    RHEL1 8
    Kernel 4.18
    SUSE2 15.1
    Kernel 4.12
    SUSE2 15.2
    Kernel 5.3
    Ubuntu3 18.04
    Kernel 5.4
    First Look
    Ubuntu3 20.04
    Kernel 5.8
    First Look
    Driver
    Release Notes
    NI-488.2
    ni-488.2
    libni4882-devel
    ni-488.2-iotrace-support
    NI-488.2 21.5
    Automotive Diagnostic
    Command Set Toolkit
    ni-adcs
    ni-adcs-labview-20xy-support
    libnidiagcs-devel
    Automotive Diagnostic Command Set Toolkit 21.5
    NI-DAQmx
    ni-daqmx
    ni-daqmx-labview-20xy-support
    ni-daqmx-labview-support
    libnidaqmx-devel
    NI-DAQmx 2022 Q3
    NI-DCPower
    ni-dcpower
    ni-dcpower-daqmx
    ni-dcpower-labview-20xy-support
    ni-dcpower-labview-support
    ni-dcpower-devel
    NI-DCPower 2022 Q3
    NI-DMM
    ni-dmm
    ni-dmm-daqmx
    ni-dmm-labview-20xy-support
    ni-dmm-labview-support
    ni-dmm-devel
    NI-DMM 2022 Q3
    ECU Measurement and
    Calibration Toolkit
    ni-ecumc
    ni-ecumc-labview-20xy-support
    libniemcc-devel
    ECU Measurement and Calibration Toolkit 21.8
    NI-FGEN
    ni-fgen
    ni-fgen-daqmx
    ni-fgen-devel
    ni-fgen-labview-support
    ni-fgen-labview-20xy-support
    NI-FGEN 21.8
    FlexRIO
    ni-flexrio
    ni-flexrio-795x
    ni-flexrio-796x
    ni-flexrio-797x
    libniflexrioapi-devel
    ni-flexrio-modulario-libs-devel
    FlexRIO 2022 Q3
    Hardware Configuration
    Utility
    ni-hwcfg-utilityHardware Configuration Utility 2022 Q3
    PXI Platform
    Services
    ni-pxiplatformservices
    ni-pxiplatformservices-labview-20xy-support
    ni-pxiplatformservices-labview-support
    ni-pxiplatformservices-devel
    PXI Platform Services 2022 Q3
    NI-RIO5
    ni-fpga-interface
    ni-rio-mxie
    NI-RIO 21.0
    NI R Series
    ni-rseriesNI R Series 21.5
    NI-RFSA
    ni-rfsa
    ni-rfsa-daqmx
    ni-rfsa-labview-20xy-support
    ni-rfsa-devel
    NI-RFSA 2022 Q3
    NI-RFSG
    ni-rfsg
    ni-rfsg-daqmx
    ni-rfsg-labview-20xy-support
    ni-rfsg-devel
    NI-RFSG 2022 Q3
    NI-SCOPE
    ni-scope
    ni-scope-daqmx
    ni-scope-labview-20xy-support
    ni-scope-labview-support
    ni-scope-devel
    NI-SCOPE 2022 Q3
    NI-Serial
    ni-serialNI-Serial 21.5
    NI-SWITCH
    ni-switch
    ni-switch-daqmx
    ni-switch-daqmx-config
    ni-switch-labview-support4
    ni-switch-labview-20xy-examples4
    ni-switch-devel
    NI-SWITCH 21.3
    NI-Sync
    ni-sync
    ni-sync-devel
    ni-sync-labview-20xy-support
    ni-sync-labview-support
    NI-Sync 2022 Q3
    System
    Configuration
    ni-syscfg-runtime
    ni-syscfg-labview-20xy-support
    ni-syscfg-labview-support
    ni-iotrace
    ni-syscfg-devel
    System Configuration 2022 Q3
    NI USRP-RIO
    ni-usrp-rioDriver Info
    NI-VISA
    ni-visa
    ni-visa-labview-20xy-support
    ni-visa-labview-support
    ni-visa-devel
    NI-VISA 2022 Q3
    NI-XNET
    ni-xnet
    ni-xnet-labview-20xy-support
    libnixnet-devel
    NI-XNET 2022 Q3
    1 Red Hat Enterprise Linux
    2 OpenSUSE Leap
    3 Ubuntu LTS
    4 LabVIEW support is not available on Ubuntu distributions for current versions of NI SWITCH
    5 Enables connections via the FPGA Interface API to remote RIO devices such as CompactRIO, Single-Board RIO, and Ethernet RIO
    For additional information about supported operating systems, refer to the NI Operating System Support Roadmap.
    © 2018–2022 National Instruments Corporation. All rights reserved.
    Notices are located in the /usr/share/doc//NOTICES directory. EULAs are located in the /usr/share/ni/licenses directory.
    GMT+8, 2026-1-13 09:36
