查看: 1813|回复: 0
[NI软件产品] NI RFmx NR 21.8.2 x64Win10 64bitENG RFmx 5G新空口蜂窝测试21.8.2
     楼主| 发表于 2022-7-14 10:33:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    RFmx NR为5G新空口(NR)蜂窝测试应用提供信号生成和分析功能。
    RFmx NR是一款测量专用软件,旨在扩展NI RF仪器生成和分析5G新空口(NR)蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对FR1和FR2(毫米波)5G NR信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2022/6/30
    包含的版本:21.8.2
    完整版校验和:
    文件大小: 1375709184 字节 (1.28 GB)
    修改日期: 2022-06-30 09:47
    MD5: f4c131641675bbeb59a102afa901d54e
    SHA1: f298373a4568bc55e9063b4926c0fb555abfd7d8
    SHA256: 381f791c4998e7a7524453dd07fd82c961559c086da599b783ffbed20cdde30b
    CRC32: 2b74c209
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR21.8.2.txt (526 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 636772352 字节 (607.27 MB)
    修改日期: 2022-06-29 21:48
    MD5: 10bdd4c27814e3d0717b185dbed16051
    SHA1: 5a38465340591a9e90b1b5580893a5aa2cacbc24
    SHA256: a55cef530e69a057a66952c498407769f533ec6313328f0035bcc6e0690e55e5
    CRC32: eef76e84
    NI官方下载和百度网盘下载地址:
    RFmx NR21.8.2RTE64.txt (554 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 21.8.2 Readme
    May 2022
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    • RFmx NR Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx NR Manuals: New features, behavior changes, and other documentation
    Installed Software
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 21.8 includes the following new features:
    • Support for Half Radio Frame Index to indicate location of SSB with periodicity greater than 5 msec
    • Support for demodulating non-3GPP compliant short frames with Sync Mode as Frame and Trigger Type as None
    • Support for additional phase tracking modes in ModAcc measurement
    • Support for n46 and n96 bands in ACP and PVT measurements and IBE result in ModAcc measurement
    • Support for configurable Cell ID in Downlink Test Models
    • Support for Release 17 specifications of 3GPP NR based on (Dec-2021)
    RFmx NR 21.3 includes the following new features:
    • Support for all trigger types and synchronization modes in ModAcc measurement for downlink mixed numerology SSB/SCH configurations
    • Support for List Mode feature on PXIe-5840/5841/5830/5831/5832
    • Support for TXP measurement
    • Support for SSB Periodicity of 5, 10, 20, 40, 80, and 160 msec
    • Support for PVT measurement in downlink
    • Support for Custom configuration for ACP measurement
    • Support for Intra-band non-contiguous carrier aggregation in FR1 bands for SEM measurement
    • Support for reference symbols input for EVM computation in the ModAcc measurement
    • Support for Auto Level for ModAcc measurement
    • Support for Release 17 specifications of 3GPP NR based on (June 2021):
      • Addition of 35 MHz and 45 MHz BW support
      • Addition of new Bands n13, n24, n67, n85, n97, n98
    • Support for EVM noise compensation in FR1 frequencies for ModAcc measurement with 5840, 5841, and 5831
    • Support for all FFT window types and user-defined overlap (%) for Sequential FFT measurement method in ACP measurement
    RFmx NR 20.7 includes the following new features:
    • Support for all Trigger Types and Synchronization Modes in ModAcc measurement for Downlink mixed numerology SSB/SCH configurations
    • ModAcc robustness improvements for Downlink mixed numerology SSB/SCH configurations
    • Support for user configurable grid size
    • Support for updates from 3GPP NR Release 16 specification December 2020
    • Support for 8-PSK modulation in downlink shared channel
    • Support for custom span in Occupied bandwidth (OBW) measurement
    • Support for IQ impairments compensation per subcarrier
    • Support for traces of IQ impairments compensation results
    • Support for Time Alignment Error (TAE)
    • Support of configuration of empty carriers in In-Band Emission (IBE) measurement
    • Support for Intraband Non-contiguous carrier aggregation in Uplink for the following spectral measurements:
      • Adjacent Channel Power (ACP)
      • Spectral Emission Mask (SEM) for FR1
      • Occupied Bandwidth (OBW)
      • Channel Power (CHP)
    RFmx NR has the following requirements:
    RFmx NR 21.8.2 supports the following 64-bit operating systems:
    Note    RFmx NR no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx NR 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx NR 21.8.2 to an unsupported OS. Additionally, after installing RFmx NR 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx NR (64-bit only)
    Required Software
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx NR installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation.
    Installed Software
      • Windows\system32 for 64-bit programs
    ItemInstalled Location
    Import Library files (64-bit)\Shared\ExternalCompilerSupport\C\lib64\msvc
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.NRMX.Fx40.dll
    Select Start » National Instruments » RFmx NR » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx NR palette VIs are available from the Functions » Measurement I/O » NI-RFmx » NR palette.
    Documentation for RFmx NR is located at Start » National Instruments » RFmx NR » RFmx NR Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx NR HelpHTML/Windows HelpContains primary help content for RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx NR
    • A complete reference for all RFmx NR programming functions and VIs
    RFmx NR 21.8.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx NR examples at Start » National Instruments » RFmx NR » RFmx NR Examples.
    The following are the behavior changes in RFmx NR 21.8 from RFmx NR 21.5:
    • RFmx NR drops support for 32-bit user mode.
    • Deprecated PDSCH present in SSB Resource Block.
    • Deprecated Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following are the behavior changes in RFmx NR 21.3 from RFmx NR 20.7/20.7.1:
    • Updated downlink subblock integration bandwidth for ACP, CHP, and SEM measurements as per 38.104 CR0262.
    • Increased acquisition length for ModAcc measurement in the case of DFT-s-OFDM with SCS 60 kHz, and above with trigger types other than digital and sync mode other than Frame.
    The following are the behavior changes in RFmx NR 20.7 from RFmx NR 20.6:
    © 2018–2022 National Instruments Corporation. All rights reserved.
    377911L-01
    GMT+8, 2026-1-13 12:44
