查看: 2252|回复: 0
[NI软件产品] NI RFmx NR 19.1 Win32/64ENG RFmx 5G新空口蜂窝测试19.1
     楼主| 发表于 2022-7-14 09:53:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    RFmx NR为5G新空口(NR)蜂窝测试应用提供信号生成和分析功能。
    RFmx NR是一款测量专用软件,旨在扩展NI RF仪器生成和分析5G新空口(NR)蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对FR1和FR2(毫米波)5G NR信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2019/10/17
    包含的版本:19.1
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 1308514304 字节 (1.22 GB)
    修改日期: 2022-03-25 22:18
    MD5: 8da3de868f03b8de2ddcfc9a25d6adb7
    SHA1: 78b0c27d616c627fa4677d8ddb12c2a1bf571b86
    SHA256: 0594002bb853a35c030135e786d4eaa2ef26a2d8a5aac8562179f9c3501a3488
    CRC32: 3f539f90
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR19.1.txt (504 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 573749248 字节 (547.17 MB)
    MD5: 4bcdacece8ea16fda9ff2f242d68cba4
    SHA1: 152d4ba34b09b059b0ef60d20aef6b2fc22e9982
    SHA256: 409a69a16b65e75076832c05bb9cb681f88ad94827c53b8cd251a283c18d8a60
    CRC32: 76a7e987
    NI官方下载和百度网盘下载地址:
    RFmx NR19.1RTE64.txt (527 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 580032512 字节 (553.16 MB)
    MD5: b67e63e23eab45b7d1d0da6bdddb5163
    SHA1: e4e3f6af9fae605eee547b87ca31f9712e792cae
    SHA256: 328d9782fe5653c55defb7deefafb66690a60eac25da8c80adfda188682ddb98
    CRC32: 874ebff7
    NI官方下载和百度网盘下载地址:
    RFmx NR19.1RTE32.txt (535 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 19.1 Readme
    October 2019
    This file contains important information about the RFmx NR, including system requirements and installation instructions.
    Installed Software
    RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 19.1 includes the following new features:
    • Support for PXIe-5830/5831/5841
    • Support for updates from 3GPP NR Rel 15 specification v15.6.0 (June 2019)
    • Support for non-contiguous carrier aggregation
    • Support for power vs time (PVT) measurement for Uplink
    • Support for additional offset channel spacing for carrier aggregation in the ACP measurement
    • Support for auto increment cell id for carrier aggregation
    • Support for PDSCH EVM measurement in the presence of PDCCH
    • Enhanced robustness of ModAcc measurement to analyze filtered waveforms, sequence and group hopping, and impaired signals
    • Added capability to include/exclude DMRS and PTRS EVM in Composite EVM result
    RFmx NR 19.0 includes the following new features:
    • Addition of downlink test models as defined in 3GPP TS 38.141-1 and 3GPP TS 38.141-2 (v15.0.0, January 2019 Change requests R4-1905121, R4-1905122 endorsed in April 2019, to be updated in v15.2.0 when it releases in June 2019)
    • Addition of uplink contiguous carrier aggregation in ACP measurement
    • Addition of EUTRA-NR dual connectivity (ENDC) in ModAcc, ACP, and SEM measurements
    • Support for configurable SSB active blocks
    • Support for uplink spectral flatness measurement for PI/2 BPSK with power boost
    • Support for auto phase compensation based on carrier frequency
    • Support multiple PUSCH configurations
    • Shared Channel symbol power is reported per carrier
    • Removed support for Cell ID control in DL Test Model Examples
    • Improvements in auto-detection of RB allocation
    • Support for PXIe-5830 and PXIe-5831
    RFmx NR 3.0 includes the following new features:
    • Support for modulation accuracy, occupied bandwidth, channel power, adjacent channel power, spectral emission mask measurements for FR1 and FR2 channel bandwidths, and subcarrier spacings as mentioned in 3GPP TS 38.101-x and 3GPP 38.104 (v15.4.0) specifications
    • Support for modulation accuracy measurement of the following physical channels and reference signals as mentioned in 3GPP TS 38.211 (v15.4.0) specification
      • PUSCH, PDSCH physical channels
      • DM-RS, PT-RS reference signals
    • Support for intra-band contiguous carrier aggregation
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5841
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx NR has the following requirements:
    RFmx NR 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx NR dropped support for all 32-bit Windows operating systems. RFmx NR will not install or run on an unsupported OS. Refer to RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx NR. To add support for application software installed after installing RFmx NR modify your RFmx NR installation or launch the RFmx NR installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx NR
    Required Software
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx NR using NI Package Manager. If you do not already have NI software installed, RFmx NR installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.NRMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx NR» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx NR palette VIs are available from the Functions » Measurement I/O » NI-RFmx » NR palette.
    Documentation for RFmx NR is located at Start»All Programs»National Instruments»RFmx NR»RFmx NR Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx NR HelpHTML/Windows HelpContains primary help content for RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx NR
    • A complete reference for all RFmx NR programming functions and VIs
    RFmx NR 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx NR examples at Start»All Programs»National Instruments»RFmx NR»RFmx NR Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following are the behavior changes in RFmx NR 19.1 from RFmx NR 19.0.
    • Change in default value of Transmit LO Architecture property to LO per Subblock. In this mode:
      • IQ Origin offset result for multicarrier configurations is reported in Subblock IQ Origin Offset Mean result property
      • Quadrature error and IQ Gain Imbalance results are not supported for multicarrier configurations
    • Updated nominal spacing definition for carrier aggregation cases as per Rel 15 Specification June 2019 v 15.6.0. For waveforms compliant to previous Rel 15 releases, use user-defined spacing definition.
    • Composite EVM result does not include the EVM of DMRS and PTRS. You must set ModAcc Composite Results Include DMRS and ModAcc Composite Results Include PTRS properties to True to include the respective EVMs in the Composite EVM result
    • Dropped support for ModAcc EVM Exclusion Period property for Downlink measurement as per the 3GPP NR specification Rel 15 June 2019
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and 5831
    • Obsoleted RFmxNR Analyze (IQ) and RFmxNR Analyze (Spectrum) APIs. Use RFmxNR Analyze (IQ, 1 Wfm) and RFmxNR Analyze (Spectrum, 1 Wfm) APIs instead
    • When you set the Frequency Range property to Range 2 , the new enums, FR2 Category A , FR2 Category B , added to the gNodeB Category property are the only valid enums.
    The following are the behavior changes in RFmx NR 19.0 from RFmx NR 3.0.
    • To load and run a Downlink configuration file saved from RFmx 3.0, the user has to explicitly set value of Downlink Channel Configuration Mode property to User Defined
    You can access the software and documentation known issues list online. Refer to the NR Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx NR . This is not an exhaustive list of issues fixed in the current version of the RFmx NR . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following bugs are fixed in RFmx NR 19.1 from RFmx NR 19.0.
    245206Fixed an issue in PDSCH demodulated bits when the signal contained SSB.
    245000Fixed an issue with IBW computation in the ACP measurement to be compliant with 3GPP TS 38.104 specification.
    249283Fixed an issue to report an error when the measurement bandwidth exceeds the instantaneous bandwidth on PXIe-5668 and PXIe-5665.
    234240Fixed an intermittent error occurring at Analyze IQ and Analyze Spectrum APIs when performing a composite measurement with different averaging count for each measurement.
    223248/214747/214717Improved accuracy of IQ Impairments measurements.
    217152/217136Fixed an issue with CHP and OBW measurements when the Acq BW Optimization Enabled property is set to True .
    The following bugs are fixed in RFmx NR 19.0 from RFmx NR 3.0.
    244818Fixed an issue where querying the ACP Results Subblock Center Freq property returned an incorrect value.
    244784Fixed an issue where the trace for demodulated bits is not correct for 16QAM, 64QAM and 256 QAM.
    244721Fixed an issue where RFmxNR DL EVM shows a positive value on selecting unit to dB.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx NR will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2018–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    377911C-01
    GMT+8, 2026-1-13 12:44
