查看: 2097|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 2.3 Win32/64Eng LTE/LTE演进蜂窝测试软件2.3
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-13 11:01:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    RFmx LTE/LTE-Advanced为LTE、LTE-Advanced和LTE-Advanced Pro蜂窝测试应用提供信号生成和分析功能。
    RFmx LTE/LTE-Advanced是一个测量API,旨在扩展NI RF仪器生成和分析LTE、LTE-Advanced和LTE-Advanced Pro蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对FDD、TDD和LAA信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2017/5/4
    包含的版本:2.3
    Windows 10
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 748974032 字节 (714.28 MB)
    修改日期: 2022-03-25 22:17
    MD5: 1f342350e0b336d941e29423538482f8
    SHA1: 566dfbf9ae0c4bec96b43ab300ab98a8f65f8519
    SHA256: 91d4fe664ac1f3f2474cfce0fc787219e25c20305f0ac1e588fea877930a1a77
    CRC32: 701b8072
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE2.3.0.txt (498 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 374272008 字节 (356.93 MB)
    MD5: 4def55b8df78eb8e4cfb2a488ed4ff35
    SHA1: 617a7f0d6943cc6c633d18fe4422a1b55d0c57ea
    SHA256: c7fd6e13419c9c2158fdcb49b83c3d45ca0acc5f434d54fe2f58f245ef634ec6
    CRC32: 372698c9
    NI官方下载和百度网盘下载地址:
    RFmx LTE2.3.0RTE64.txt (510 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 378183664 字节 (360.66 MB)
    MD5: 2f77804b406480603b5cefe3cba074ea
    SHA1: 1bf59c4926ba24e4737dd18000ea195fd6a0c6bc
    SHA256: 57685d54f329c0f0d8a45ef960b46c2060e36e9c06b1a48ef7e997dcd05fcfb1
    CRC32: 28e482fb
    NI官方下载和百度网盘下载地址:
    RFmx LTE2.3.0RTE32.txt (510 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx LTE 2.3 Readme
    May 2017
    This file contains important information about NI-RFmx LTE and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx LTE
    NI-RFmx LTE 2.3 includes the following new features:
    • Addition of Slot Phase measurement for Uplink
    • Addition of Slot Power measurement for Uplink
    • Addition of "General CA Class B" and "CA_NC_NS_01" masks for Uplink in SEM measurement
    • Addition of a sequential FFT measurement method in ACP measurement
    • Addition of downlink support in ModAcc, ACP, SEM, CHP and OBW measurements
    • Support for SRS including UpPTS for uplink in ModAcc measurement
    • Support for DMRS with OCC (Orthogonal Cover Code) for uplink in Modaccc measurement
    NI-RFmx LTE 2.2 includes the following new features:
    • Addition of PVT measurement
    • Addition of magnitude error and phase error results in ModAcc measurement
    • Addition of IBE (subblock IBE) across carriers results in ModAcc measurement
    • Addition of 3GPP based EVM result, which is the maximum of EVMs at high and low FFT window positions
    • Addition of RMS and Max averaging for ModAcc traces
    • Support for an immediate trigger for TDD ModAcc
    • Support for ModAcc measurement across non-contiguous slots for the TDD mode
    • Support for auto-detection of DMRS parameters in ModAcc measurement
    • Support for RS-only equalization in ModAcc measurement
    • Support for acquisition bandwidth centering optimization
    • Support for LO leakage avoidance when using vector signal transceiver as the analyzer
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for custom masks for SEM measurement
    • Support for reading the configured properties in spectral measurements
    NI-RFmx LTE 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Installation InstructionsCaution  Before you install NI-RFmx LTE 2.3, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx LTE 2.3 supports the following operating systems:
    Note  NI-RFmx LTE 2.3 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx LTE. To add support for ADEs installed after installing NI-RFmx LTE, modify your NI-RFmx LTE installation or launch the NI-RFmx LTE installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    Note  NI-RFmx LTE does not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\LTE\Examples
    Examples\LabVIEW \examples\RFmx\LTE
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.LteMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Measurement Interactive Panel to launch the NI-RFmx LTE Measurement Interactive Panel.
    Documentation for NI-RFmx LTE is located at Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx LTE HelpHTML/Windows HelpInformation about NI-RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx LTE
    • A complete reference for all NI-RFmx LTE programming VIs
    NI-RFmx LTE 2.3 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    NI-RFmx LTE palette VIs are available from the Functions»Measurement I/O»NI-RFmx»LTE palette.
    You can access all the installed NI-RFmx LTE examples at Start»All Programs»National Instruments»NI-RFmx LTE»NI-RFmx LTE Examples.
    NI-RFmx LTE 2.3 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx LTE drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx LTE 2.3 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx LTE 2.3 to an unsupported OS. Additionally, after installing NI-RFmx LTE 2.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx LTE 2.3 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx LTE 2.3 installation, the following software is installed. To completely remove the NI-RFmx LTE 2.3 installation from your system, you must also remove the following packages:
    • NI-RFmx LTE Runtime 2.3
    • NI-RFmx LTE Runtime 2.3 (64-bit)
    You can access the software and documentation known issues list online. Refer to the NI-RFmx LTE 2.3 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx LTE 2.3.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx LTE. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx LTE. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx LTE 2.3 from NI-RFmx LTE 2.2.
    622407Fixed an issue with configuring SEM custom offsets with a named signal.
    625184Fixed an issue with retrieving the value of the SEM Offest RBW property when the mask type is Custom.
    623095Fixed an issue with the Analysis-Only mode, ModAcc measurement does not require configuration of pre-trigger delay in t0 value of the I/Q waveforms.
    The following items are changes in NI-RFmx LTE 2.1 from NI-RFmx LTE 2.0.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    560176Fixed an issue with the SEM mask chosen while sweeping through thee different center frequencies in a loop.
    562181Fixed an issue with LTE waveform generation where the digital trigger (RTSI 0) and the multiple carrier caused both carriers to overlap in frequency.
    550422Fixed an issue with the NI-RFmx LTE Measurement Interactive Panel where the relative enum value in the Subblock Frequency Definition field, of the subblock cluster, is disabled sometimes when the value of the array element was greater than 0.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2015–2017 National Instruments. All rights reserved.
    375558D-01
    GMT+8, 2025-11-19 09:02
