查看: 1560|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 21.8.2 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件21.8.2
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 16:53:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2022/6/30
    包含的版本:21.8.2
    完整版校验和:
    文件大小: 1035046912 字节 (987.10 MB)
    修改日期: 2022-06-30 09:47
    MD5: f13b23a591ec60d22f7c838b9b97bf35
    SHA1: 880e58743f269f0bdccb0297949a4cb9a0918787
    SHA256: f39b743aa5ccf81cf4cac85169a700b961fdae1855e0435819434ea3e2a0340a
    CRC32: bf4c3658
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 21.8.2.txt (542 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 591464448 字节 (564.06 MB)
    修改日期: 2022-06-29 21:48
    MD5: 0cbc7ba3e9f55d37ef13eabeb8023b74
    SHA1: be49d50c0e4a3143b6661025152cb7b0dbab9a0c
    SHA256: 72012a3a2755f73b1b6b907e7b4143ffcda8c58761913e06783e8ddb4564726c
    CRC32: 8fea1831
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.8.2RTE64.txt (565 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 587057152 字节 (559.86 MB)
    MD5: b9844048b031472b7af2026aa55f41c4
    SHA1: 3d173ecd94a777f1dcdfaab3243deb5c588677b0
    SHA256: 5791e810db88a0c0586f33f02beaa0ca6687484a37d28a4a14d399aea7db688e
    CRC32: 09b3a4d6
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.8.2RTE32.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 21.8.2 Readme
    May 2022
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 21.3 includes the following new feature:
    RFmx GSM 20.7 includes the following new feature:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM 20.0 includes the following new features:
    RFmx GSM has the following requirements:
    RFmx GSM 21.8.2 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 21.8.2 to an unsupported OS. Additionally, after installing RFmx GSM 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    Required Software
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Installed Software
    ItemInstalled Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 21.8.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    375557V-01
    GMT+8, 2025-11-19 09:06
